No, but again using the exactly same parts as other user who reported 4.7A, so i guess its 4.6/4.7A?
I will measure both of them in few days, and report back.
Looking forward to hear the results.
And I’ve managed to Poof! 5 XM-L2 U2 1D emitters so far. Tried everything to keep it all under control, had it down to 4.83A and did the math on resistors, bumped it just a wee bit….Poof!
So now I have it running an Luminus SST-50. I put resistors on it that have actually lower resistance than stock but the emitter is “only” getting 5.60A. Not a throw monster by any stretch of the imagination, but a decent light nonetheless set up this way. Have some parts on the way, will try again later. Tired of frying XM-L2’s though.
Can you share all details on your setup Dale, and what you have tried. (Preferably in the HX1175B thread...)
You’re blowing up XML2s at 4.83A?
Probably current spikes. Ive started a suitable thread for that too. :D
"At what current do you kill LEDs - Which driver was used"
Its not the current that kills them.
Thanks for the link, you’ve made an interesting thread. I’ll give it a read.
This driver seems to make big jumps with small changes. The bump up from 4.83A is what killed it. I had one running at 7.13A that seemed reliable, but I wasn’t able to get the throw on it that I thought it should be making, so I changed the emitter and poofed a few more.
Man, that's alot of xml2's to lose. I lost a bunch to a FT "3T6" driver once. It really hurts.
I know we are talking about it in the other thread, but whiles I'm thinking about it. Have you tied a different HX-1175 in any of these attempts?
I got 2 of these drivers. I’ve built 4 different control boards, was having all kinds of issues. Primarily at first it simply wouldn’t work at all. Then I discovered that the wires from the 2 e-switches break the standards. One switch has 2 red wires, the other has 2 black wires. I had it wired wrong. Then I started blowing emitters. Tried changing current and all that but of course I bought it BECAUSE it could run higher currents.
This isn’t the first time I’ve had something working and went for that little bit more… should have left it alone while in the 500’s in Kcd.
The problem lies in the top end output, as the other modes work fine and there’s simply not an issue until Turbo is clicked. Then it’s either making way too much power or it’s spiking and popping the emitter instantly. I don’t see fried bond wires like a massive overload, so it’s got to be a spike or surge. (Doesn’t have to be of course but that’s the way it seems)
I got some new sense resistors in the mail today so I redid the TK61 yet again. I cut a 40mm disc .9mm thick to go under a 20mm Noctigon with a de-domed XM-L2 U2 1D. Removing the stack of resistors I had on the driver, I put 2 of the new R070 that are even larger than the ones originally on the board (it came with 2 R068)
After firing up in Turbo at 6.98, it climbed to 7.13 and seemed to stabilize. I backed it down then came back at it and it hit 7.2A. With the light assembled, this makes 565Kcd and 1611 lumens at start with the light hot. Having the base of the reflector cut out to be able to fit over the 20mm Noctigon is nice, I simply dial the head up or down to find focus. Works really well!
And here’s the inevitable “but”…I see a tiny black spot on the phosphor, so it’s gonna die.
Here's a mouseover of the TK61 with XP-G2 de-domed at 5.5A (557Kcd) vs. XM-L2 de-domed at 7.2A (565Kcd).
Same camera setting, same spot...97 yds to red oil drum. Canon G1X at 28mm, ISO 1600 f/5.6 at 1/2 sec exposure.
(Edited XP-G2 numbers, I had 525 down when it made 557)
That is a great comparison Dale! Thanks for sharing..
Nice mouse over, what were the original tints you were using? Did you use the gasoline method for the dedome? Love how the tints came out in the pic.
Edit, I see you used 1D tint
7.2A and only 565KCD?
My TK 61 with only dedome is doing ~ 300kcd - 3A. Should i get to at least 500kcd - 5.7/5.8A?
The XP-G2 is an S2 2B, gas de-domed. The XM-L2 is a U2 1D heat de-domed. In each case the tint stayed quite nice.
dazed1, I'm a bit perplexed as well. I'm using the HX1175b1 driver to get that 7.2A (well, both numbers but with different resistors) I have a 40mm disc of copper .9mm thick under the 20mm Noctigon. Heat dispersal is near immediate into the head, you feel it and know it's working properly.
I do believe my reflector is off somehow. It seemed warped or something and would not center which is what led me to cut the entire bottom out of it to fit over a 20mm Noctigon. Check out this pic, the base of the reflector is clear...not touching anything at all. The reflector is held into the head by the lens and bezel and is snug. So why the obvious distortion to the left?
dazed1, I’m a bit perplexed as well. I’m using the HX1175b1 driver to get that 7.2A (well, both numbers but with different resistors) I have a 40mm disc of copper .9mm thick under the 20mm Noctigon. Heat dispersal is near immediate into the head, you feel it and know it’s working properly.
I do believe my reflector is off somehow. It seemed warped or something and would not center which is what led me to cut the entire bottom out of it to fit over a 20mm Noctigon. Check out this pic, the base of the reflector is clear…not touching anything at all. The reflector is held into the head by the lens and bezel and is snug. So why the obvious distortion to the left?
Hi
Its reflector seems out of focus in height…
How can you possibly tell the height positioning looking at a picture taken straight down on the emitter?
The focus is perfect at that height. 557.5Kcd with this XP-G2 you see.
It was adjusted actively, tuning in each direction past this point then back to what works best for this light. Meaning, while it was on, shining at a target 35 yards away, the height was adjusted to optimize the hot spot. And right where you see it is what works best. The chrome looking surface of the flat at the bottom of the reflector is approx 1mm above the star. The donut hole in the beam merges at about 1M when shining it at a wall.
I think, because he cannot see the yellow phosphor in the reflected image… bit it is just a guess on what he is looking at.
