Consider buying a external shunt modified DMM from me ($10 shipped), you can take accurate current readings up to 20A!
If you don’t you’ll need to, at the very minimum, upgrade your DMM leads, factory ones (even high quality Fluke leads) are only reliable to ~1A. Its best to use >14AWG stranded wire and solder them to the inside of the DMM (but this will make it only usable for current measurements) that’s why I sell the ones I do, so you can have an accurate current measuring DMM without having to make yours useless for other readings.
Also note, even tho the sheathing of your stock leads appear to be ~22AWG in size it’s most likely that there are only around 30 strands inside making it ~28+ gauge.
Those Samsungs are great for the price considering I got mine for under $3/each, but my protected NCR18650B were the same price as my VTC5 ($11/each), which is why I regret buying so many NCR18650B. The NCR18650B are providing under 2.4A in the same light that the VTC5 are providing over 2.8A…
So most people think it is the cables that are causing the fluctuations in current? I would understand if the cables aren’t giving accurate reading, but I don’t really get why the current would fluctuate more with all cells besides VTC5…
I guess most people just don’t see these current fluctuations when taking tailcap currents…
3A current is not a big deal for NCR18650B, so don't blame the cells. Fix the cable, or current measuring system. Don't ever forget that anything through a current has to pass will drop some of it. X3 for example has a contact board then these some wires to the driver, just a bit of waste there too, we can easily call this a not so perfect concept for low voltage circuits and high currents.
your are seeing poor contact as mine are normally steady. Make sure battery post are clean and good contact on tube. Your meter may be in question, CK’s meter may be a good option if any doubt. Check your leads, on ohms, is the reading steady? What about measuring battery voltage at rest, should be dead steady on first 3-4 digits.
Meter is in question here like many poor measurements that are talked about on the forum. You do not measure current over 2meters at 22AWG, the voltage will drop to 3.78V from 4.2V only because of the 2meters 22AWG wires, not counting other loses like springs, etc. Important to remember that an uncompressed spring is not going to have as low resistance as a compressed spring that will also create what some call "unknown variable", so the numbers bouncing has at least one clear explanation, the one one would be poor contact or dirty contact.
These are 1m cables and voltage readings match the OPUS BT-C3100 within .01v every time.
The numbers I mentioned here were from the XinTD X3, but I reproduced the same pattern in other lights such as the Nitecore P12 (under 3A, but the VTC5 pulls .5A higher than the NCR18650B.
I do not think you quite understand some basic stuff, I am only trying to help you.
1meter is in one direction there other direction is another 1 meter, so it is 2 meters that is how current travels. Reading battery voltage has nothing to do with reading the current you want to read on the same multimeter.
Get 2pcs of 1feet of 12-14AWG wire and use those as leads for your multimeter when measuirng current. You will see a big difference with the NCR18650B, also do not forget to chek how pressing the cell (compressing the spring) will change the current reading slightly, but since the cables are so thing now, the compression will not cause a big difference in current reading.
A real problem with measuring tail cap currents on multi-emitter lights is the total resistance introduced in the meter path. Most meters use a .01 ohm shunt resistor and even if one solders 2 - 1 foot 14 gauge copper wires to the insides of the jacks, there is an added .015 ohms in the path. (2 feet of 14awg copper is .005 ohm) Pass 15 amps through that setup as I do through my modded 6-XM-L2 SKR, and you will drop (V=IxR) 15 x .015 = .225 volts. That is a HUGE amount.
It’s just like running the light on 4.2V cells that are discharged to 3.975V. Couple that with the fact that LEDs when running in DD or with FET drivers on high and you will measure much less current than it would pull without that added resistance. Also remember that LEDs are non-linear in their current demands. Slightly increasing, or decreasing, the applied voltage will disproportionately affect the current draw. In other words a sight increase in voltage can greatly increase the current draw.
Of course when measuring smaller lights, as is the case in the OP, or current regulated drivers, the added resistance in the meter circuit does not matter so much.
The point I am trying to stress here is that NCR18650B are definitely capable of 3A if that is the load. You don't need VTC5 for 3A, if you got them that is good, useful cells, but NCR18650B has no problem delivering 2.8 - 3A, since X3 is using a Nanjg 105C driver.
Does the driver produce a PWM output? I’m wondering what would happen if a digital sampling meter, taking a sample at brief intervals, runs into that situation.
Hi ,
What is the Typical Resistance in a Flashlight Switch , I just measured the resistance in my Flashlight switch and it was 1 ohm ?!
is it really 1 ohm or my multimeter is wrong ? (DT830D Multimeter)
Hi thulfiqar, in my signature line below you can my tests, and one of them is about switches. If I remember well, the typical small Omten switch should have roughly 0.01 Ohm resistance. These are values that normal multimeters will not measure well.
