FS: XML2 XPG2 XPL XPL HI MTG2 XHP50/70 Components + Extras inc. mod service RE-DESIGNED
129 posts / 0 new
3Tronics
3Tronics's picture
Last seen: 1 month 5 days ago
You can order by email or from my website:
www.3tronics.co.uk
Emitters:
XPG2
XP-L
XPL HI
XML2
XHP50
XHP70
MTG2
on
10/16/20/26/31/32mm Copper Direct thermal path MCPCB’s.
E-mail: ledjames92@yahoo.com
I’ve added de domed price in as default, let me know if you don’t want the emitters de domed. I can also offer flashlight modifications, you can either send me yours, or I can buy it and modify it then ship to you. (Competitive pricing) I can do most budget lights and some higher end ones, check with me first, driver swaps (mostly qlite 3.04A,direct drive 2 mode and direct drive 5 mode) emitter swaps, copper mounting, dedoming, spring mods, AS thermal, thermal cubes, AR glass if avaliable. I dont tend to modify existing drivers (sense resistors etc.) but may occasionally do it.
I will reserve items for 24 hours only after the 24 hours they will go back on sale or to the next person in line who wants them
XPG2:
De-domed XPG2 16mm- £5.30
De-domed XPG2 20mm – £5.30
De-domed XPG2 32mm- £6.30
XPG2 S2 2B 5700-6000K
XPG2 R5 1A 6500-7000K
XML2:
De-domed XML2 16mm – £6.50
De-domed XML2 20mm – £6.50
XML2 T6 3B 5000-5500K
XML2 U3 1A 6500-7000K
XML2 U4 1A 6500-7000K
XP-L:
De-domed XP-L 16mm – £6.40
De-domed XP-L 20mm – £6.40
De-domed XP-L 32mm – £7.00
XP-L V5 2A 5700-6100K
XP-L V6 2C 5350-5700K
XPL HI:
XP-L HI 16mm – £6.90
XP-L HI 20mm – £6.90
XP-L HI 32mm – £7.90
XP-L HI V2 1A 6500K
XP-L HI V2 1C 6500K coming soon
XP-L HI V3 2B 5700-6100K coming soon
MTG2:
De-domed MTG2 16/20/25mm – £15.00
Q0-5000K
XHP50:
J4 3C 5500K 16/20mm £11.00 (shaved +£1.00)
J4 1C 6500K 16/20mm £10.00 (shaved +£1.00)
XHP70:
N4 3C 5000K 21mm £16.00 (shaved +£2.00)
M2 1A 6500K 21mm £15.00 (shaved +£2.00)
Triple:
De-domed Triple XPG2 20mm – £8.50
De-domed Triple XPL 20mm – £14.50
De-domed Triple XPL HI 20mm –
(32mm triples also available)
FREE 22AWG silicone wire with each order!
Extras:
-x5 XML2/XHP50 GITD insulation gasket 16mm £2.50
-x5 XPG2/XPL GITD insulation gasket 14mm £2.40
- Silicone grease 20g tub (Jetbeam) very nice quality, better that nitecore grease
-Silicone thermal cubes (for driver)
-Silicone pads
-Thermal adhesive squares
-Drivers (mostly qlite 3.04A and direct drive 2 or 5 mode)
-led centering
-small snap bags (for components, also what leds from me are sent in)
- red bubble bags (for components, also what leds from me are sent in)
-scraps (used MCPCBS, Alu boards)
-optics
-sense resistors
-general flashlight parts
-other LEDS (MKR,XHP,XPE etc)
-Orings
-switches/ e-switches
-5mm colour leds
- copper shims 15×15×1mm
Cut to length:
-high quality solder
-silicone wire (18/20/22/24/30AWG)
-copper tape
-aluminium tape
-copper braid
-Kapton tape
I may have other stuff so let me know if you need something specific
As a rule of thumb, the smaller emitter, the better the throw, the bigger emitter the better the flood.
Delivery – PM or Email me with your order and I’ll give you a delivery quote, roughly £2 UK and £4 international
! photo imagejpg1_zps6a6364aa.jpg!
_Remember warmer tint after dedome.
Posted from UK
Prices in GBP
PayPal only
Email or PM me to order as I may not monitor this thread, this is also the PayPal payment email.
This is a perfect upgrade for your light, it helps a lot with heat management which in turn prolongs the life of the emitter the copper MCPCB can be pushed a lot harder than an aluminium one.
Sent In bubble packaging inside a bubble envelope, probably cheaper in an envelope but damage is riskier.
All items tested and confirmed to be in working order before dispatch.
Disclaimer:
Usual rules apply, after postage it is not my responsibility, but I will give you a tracking number if purchased.
I reserve the right to refuse sales.
All emitters are tested at 4.2V and confirmed to be working perfectly before dispatch, they are all protectively packed.
I will not take responsibility for damage caused by wrong installation, reverse polarity etc.
please check the items bought are compatible with the item you are buying them for, check the CREE website if you are unsure of led specs.
The maximum Amperage you can drive the emitter at is the same as if it were a dome on emitter. I will not be liable for overdriven emitters burning out.
Emitters driven at a high current may develop a very small brown spot over time but this does not effect the beam or the emitter.
It is seen in many other de-domed modifications but is nothing to worry about.
The bond wires are left with a small amount of silicone from the dome to offer protection of the bond wires against drops etc. this has no effect on the beam quality after de dome and is purely cosmetic.
I will send a picture of your order before dispatch if requested
Any questions feel free to email me.
(Prices may change without notice, but if I’ve sent you a quote that is what you pay)_
Custom builds | Modifications | Powder Coating
Gallery: Instagram
Edited by: 3Tronics on 08/28/2015 - 14:07
AlexGT
AlexGT's picture
Last seen: 1 hour 21 min ago
Images not showing…
3Tronics
3Tronics's picture
Hmm let me try and sort it, it should be working.
Gallery: Instagram
3Tronics
3Tronics's picture
AlexGT wrote:
Images not showing…
Images added
Gallery: Instagram
FmC
FmC's picture
Last seen: 9 hours 16 min ago
Probably should have this in the Commercial Sellers section….
3Tronics
3Tronics's picture
I don’t know what’s classed as a commercial seller on this forum, but I just do this as a hobby, I’m not a ‘company’ so to speak, just me.
Gallery: Instagram
comfychair
comfychair's picture
Last seen: 2 years 1 month ago
Well whatever it is, it's certainly not a 'featured mod'.
3Tronics
3Tronics's picture
My bad.. I’m new to this forum.. I’m sure someone can move it into the right section for me..
Gallery: Instagram
RaceR86
RaceR86's picture
Last seen: 2 years 3 months ago
You can edit your first post and move it to the "Want to sell" section.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
3Tronics
3Tronics's picture
Ok think I’ve done it, thanks Smile
Gallery: Instagram
Gj
Gj's picture
Last seen: 22 hours 16 min ago
James3 wrote:
De-dome £3.00 De-dome Introductory offer £2.00 Ended 25/07/14
I like the introductory offer that expired 4 days before the OP.  Laughing
3Tronics
3Tronics's picture
Sorry was posted on another forum, forgot to change, I will change it to have a BLF introductory offer, only fair Silly
Gallery: Instagram
3Tronics
3Tronics's picture
__Guys I’m doing a little giveaway to get the ball rolling, an XML2 dedomed 5000-5500K on 20mm noctigon MCPCB
(UK ONLY DUE TO THE INTERNATIONAL SHIPPING COSTS OF 1 ITEM)
if you live in the UK and you want a completely FREE emitter then the first to post gets it
After your post Email me your address to ledjames92@yahoo.com and it’s yours__
Gallery: Instagram
FmC
FmC's picture
Technically, AU is part of the UK, thus you are obliged to send it to me :bigsmile:
j/k….
3Tronics
3Tronics's picture
Unfortunately in the eyes of the post office it isn’t Silly
Gallery: Instagram
DavidEF
DavidEF's picture
Last seen: 17 hours 45 min ago
James3 wrote:
Guys I’m doing a little giveaway to get the ball rolling, an- XML2 de-domed 5000-5500K on 20mm noctigon MCPCB
I don’t live in the UK, but I’d pay the difference in shipping if you’ll send it to me! :bigsmile:
James3 wrote:
Postage depends on how many you buy and where I’m sending too, so just ask for a quote but roughly it would be
UK-£4.30 International £8.80 (roughly, ask for an exact quote)
So… I’d be willing to pay the roughly £4.50 difference. It’s still a “free” emitter, after all! Let me know if I’d qualify, then I’ll send you my address.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
3Tronics
3Tronics's picture
Ok, I suppose that’s fair, email me your address, My email is also the PayPal email so once payment is sent I’ll get it sent out!
Gallery: Instagram
DavidEF
DavidEF's picture
Thanks, James! Email with shipping address has been sent.
-Ayn Rand
3Tronics
3Tronics's picture
Free emitter claimed
Gallery: Instagram
3Tronics
3Tronics's picture
Quick offer for BLF
Next 3 orders will get free de dome on XML2 ONLY
(Max 5 pcs per person)
Gallery: Instagram
HarleyQuin
HarleyQuin's picture
Last seen: 3 weeks 18 hours ago
Hi James3,
nice to see a UK-offer, but I recommend truly specifying the tint.
6500-7000K is a colour temperature, not the tint cree specifies. 6500-7000K consists of different tints (1R, 1A, 1B, 1S). Some of them are nice, others I will never ever put into a flashlight, unless threatened with decapitation… So it would be nice to know which tint you offer. See picture below to see what I’m talking about.
Oshpark Boards:
Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
3Tronics
3Tronics's picture
Yes I know, I put down the K number because it seems easier to me for people to understand, i can put down the tint type if needed, it is also easier to understand after de dome, eg. 6500-7000K de domed becomes say 5500-6000K whereas it would be hard to predict the tint number.
I will add them in if it helps people though, having both can’t hurt!
Gallery: Instagram
HarleyQuin
I understand the difficulty to specify the tint after dedoming.
But in factory state the tint is definitely more significant.
Best regards
Oshpark Boards:
3Tronics
3Tronics's picture
Yes I do understand your point, but most people do go for de-dome when they purchase from me, probably 90%
So if I say XLM2 T6-0D, it won’t be that tint after de dome, I find it easier using temperature anyway. So I assumed other people would.
But I’ve updated to include the tint numbers Smile
Gallery: Instagram
3Tronics
3Tronics's picture
2 more offers left to claim from post #19
Gallery: Instagram
3Tronics
3Tronics's picture
Still 2 left guys! If you buy 5 de domed emitters you save £10!
Gallery: Instagram
3Tronics
3Tronics's picture
I’m going away in 2 weeks for 5 weeks so I will not be doing any orders after 15/08/14 until roughly 23/09/14!
Thanks
James
Gallery: Instagram
3Tronics
3Tronics's picture
XP-L now available!
I’ve got 9 in stock ready to send!
! photo imagejpg1_zps91be707d.jpg!
Gallery: Instagram
Ejected Filament
Ejected Filament's picture
Last seen: 1 month 3 days ago
j/k….
OI! Say what now?
3Tronics
3Tronics's picture
Ejected Filament wrote:
j/k….
OI! Say what now?
Well the next giveaway may be worldwide! Wink
That’s if the orders keep coming in, there lagging a bit lately!
Hopefully with XP-L now available there will be more interest
Gallery: Instagram
DavidEF
DavidEF's picture
Okay, so the original tints have been added to the OP, but can anyone give a clue about expected tint shift for de-doming? I’ve read that it usually gets warmer and shifts toward green, but how much of each is expected? One block? Two? I’m trying to learn about tints, as I’ve never really bothered to know. Until I joined BLF, all I knew were WW, NW, CW. Now, there’s this whole spectrum graph and I haven’t a clue! But, I have “an XML2 dedomed 5000-5500K on 20mm noctigon MCPCB” coming to me from the GAW here (thanks James, I’ll update when it gets here) and for reference, I’d like to know what the tint should now look like. OP now says the 5000-5500K XM-L2 is a T6-3B. What should I expect to see?
-Ayn Rand
