__Guys I’m doing a little giveaway to get the ball rolling, an XML2 dedomed 5000-5500K on 20mm noctigon MCPCB
(UK ONLY DUE TO THE INTERNATIONAL SHIPPING COSTS OF 1 ITEM)
if you live in the UK and you want a completely FREE emitter then the first to post gets it
I don’t live in the UK, but I’d pay the difference in shipping if you’ll send it to me! :bigsmile:
So… I’d be willing to pay the roughly £4.50 difference. It’s still a “free” emitter, after all! Let me know if I’d qualify, then I’ll send you my address.
nice to see a UK-offer, but I recommend truly specifying the tint.
6500-7000K is a colour temperature, not the tint cree specifies. 6500-7000K consists of different tints (1R, 1A, 1B, 1S). Some of them are nice, others I will never ever put into a flashlight, unless threatened with decapitation… So it would be nice to know which tint you offer. See picture below to see what I’m talking about.
Yes I know, I put down the K number because it seems easier to me for people to understand, i can put down the tint type if needed, it is also easier to understand after de dome, eg. 6500-7000K de domed becomes say 5500-6000K whereas it would be hard to predict the tint number.
I will add them in if it helps people though, having both can’t hurt!
Well the next giveaway may be worldwide!
That’s if the orders keep coming in, there lagging a bit lately!
Hopefully with XP-L now available there will be more interest
Okay, so the original tints have been added to the OP, but can anyone give a clue about expected tint shift for de-doming? I’ve read that it usually gets warmer and shifts toward green, but how much of each is expected? One block? Two? I’m trying to learn about tints, as I’ve never really bothered to know. Until I joined BLF, all I knew were WW, NW, CW. Now, there’s this whole spectrum graph and I haven’t a clue! But, I have “an XML2 dedomed 5000-5500K on 20mm noctigon MCPCB” coming to me from the GAW here (thanks James, I’ll update when it gets here) and for reference, I’d like to know what the tint should now look like. OP now says the 5000-5500K XM-L2 is a T6-3B. What should I expect to see?
David
The tint goes warmer yes, it’s not an exact science, ie. I could de dome identical emitters and both might have slightly different tints, but both will be warmer than the original tint, the tint can go blue if the phosphor layer is removed whilst de-doming.
I’ve noticed green tints when the emitter is driven at lower Amps when the emitter is driven hard the tint restores to the right tint.
In simple terms I go for after de dome are:
Cool white = neutral white
Neutral white = warm white
Warm white = extra warm white
Etc etc
Basically drops a “category”
I’d say at a guess the de dome loses 1000-1500K maybe
So 6500-7000K becomes 5500-6000K
I’ve sent you a de domed 5000-5500K emitter T6-3B ( as I said in an earlier post I don’t go off this it use colour temperature {K})
So in theory the tint will drop from neutral to warm as a rough guide, (5000-5500K to 4000-4500K) if you want a neutral white tint after de dome then you go for a cool white emitter, make sense?
I don’t like going into technical words and I like to keep it simple so I hope that’s helped?
