Decent light for 70$ max, for more they can keep it
Great review anyway….
Ok.. I need some help:
In my 2nd post, you can see that changing the wires to 18AWG didnt improve the output much..
So I want to do a resister mod!
THis is the pic with the current smd resistors.
1. Can this be resistor modded?
Stock I got 7.6V and 3.07A to the LED.
According to the picture below, the R240 would be 0.240 ohm,
so I used this website: and 4 times 0.240 ohm makes it 0.0600 ohm.
2. Is this correct?
3. Using THIS website, I calculated that 7.6V and 3A equals 22.8W
is that also correct?
4. but the same calculator shows 2.53 ohms....
where did I go wrong?
Ok, I got some info about calculating the A from the LD29 mod thread
So I will just enter my own values, and see if it makes any sense.
Quoted from the mentioned thread.
The ouput amps to the LED is 3A, so therefor the sensing voltage is V = I x R = 3 x 0.06 = 0.18V. The sensing voltage will stay constant, so if you want 5A output to the LED, your sensing resistor should be: R = V/I = 0.18/5 = 0.036 Ω. So your best bet would be to Remove the 4 SMD resitors, and put a R036???? resistor. Unfortunately, it is not always possible to get the exact resistor in small quantities. Thus we stack resistors to get to the desired overall resistance.
I can`t follow the following numbers yet.. I tried, and think its correct... but please let me know if I do something wrong.
- 2 x 0.1Ω in parallel = 0.05Ω, put that in parallel to the original 0.06Ω = 0.0273Ω = 6.5A?? correct? (0.18/0.273)
- 3 x 0.1Ω in parallel = 0.03333Ω, put that in parallel to the original 0.06Ω = 0.0349Ω = 5.15A?? (0.18/0.0349)
- 4 x 0.1Ω in parallel = 0.02500Ω, put that in parallel to the original 0.06Ω = 0.0484Ω = 3.71A?? (0.18/0.0484)
Forget all the math, there's no way to know if it's correct from one light to another until after you change the resistors and see how much difference it makes. Just stack one resistor at a time, something reasonable that won't whack it too hard in one go, like 1/2 ohm (R500). The higher your added resistors are, the less increase each one will give. Adding a really low one like a R020 could be too much, using a bunch of higher value ones gives you a lot more control and won't suddenly do something bad on you.
Bookmark this page, it'll decode anything: http://www.hobby-hour.com/electronics/smdcalc.php
Thanks..
I have this pack from fasttech. But none of them have the R in front of the numbers, so I guess they are really big.
and thanks for the link. I also just found that one during my search.
edit; just checking my SMDs, but all are really really big.. strange because it shouldnt be , looking at the details at fasttech.
Dude, you live in Tokyo. There are probably thirty SMD resistor vending machines within a half mile of you right now. :D
No, we only have vending machines for flowers, birds andbatteries, and I think I`ve even seen one for drinks and cigarettes.
https://www.fasttech.com/p/1234412
Click the drop-down box for other values. They have a not too bad selection, though only in 0805 size.
oh, that`s 0.5 ohm? Mmm, again the smallest I have seems like around 10ohm
Yep, that's the giant assorted pack of uselessness. :P
You now are part of the "we did that too" club. :D
Great!.. not
someone mentioned this to me, and I just bought it... left it somewhere in my closest, took it out a few hours ago.. and now realized its not any better than the spoon I just used.
edit: I found the crook here
Naughty, naughty, Pulsar13! :p
Yes, at least I now have 400 of them :)
And it takes a while before receiving the ones I need, so I will hunt for some boards and see if I can find any useful resistors.
Edit:
I'm checking mouser.jp and they have many. But I just want to make sure if I need a 1/8 or 1/4 watt
Some are like 10 cents, some are 70 cents per piece.
Link here:
Doesn't matter for this, with multiple resistors the current is divided between them, and more of the current will go through the lowest value resistors. If it were some other application, or if you were replacing the bank of original resistors with a single resistor, then it might.
Tolerance also really doesn't matter since you're just adding pieces until you reach some arbitrary current. Doesn't matter if one resistor is .52 ohm and another is .45 ohm.
Are you sure you need 0805s? They're pretty tiny, have you measured the originals? 1206 is more common for sense resistors.
Oops, I just saw that number in your earlier post... Will search for th bigger one..
So the 1/4 or 1/8 watts don't matter?
If you can find one that's rated for higher wattage and it's similar price, sure, go for it, you may do something later that needs the higher rating. But if it's $0.03 each vs. $1.20 each... don't bother. Same for the tolerance %, if the better parts are close to the same price it only makes sense to get the better ones, even if it's not strictly necessary.
I find myself wanting a light like this, but the price is hefty and the UI isn’t really desirable.
We could use some beamshots in practical settings.
Don't you think that wall was in a practical setting?
I don't know what I can do, maybe go to the little playground near my house?
No woods here.
Wow, ridiculous shipping cost at mouser!!! $20 for a $2 order.
Same for digikey, $20
