I love the dell pc764 packs, almost always produce good 2600 or 2550 cells. I will get both of your pulls on the list. Thanks guys.
Last week I got a Dell battery back (here: http://www.amazon.com/gp/product/B000WDRXL4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1)
It had six light-blue/green colored cells in it, no brand name on the wrapper - just a bunch of numbers. Look similar to the LG's in #2 in the OP.
All six tested to 3.88-3.89 volts on my multimeter. I have no means of testing capacity at the moment. I figure the cells have to be pretty new to test with that high of a voltage right?
That is a pack for a Dell not a Dell branded pack. The cells inside could be of lesser quality. I must say the price is right if it is to be used to replace an old worn out pack. There is no sense in spending $100+ for an original replacement for an old laptop that is on it’s way out anyway. It is probably not a good idea to buy these to harvest the cells, for that any NOS (new, old stock) genuine laptop pack from any of the major manufacturers would be better. They can be had for about the same price and will contain name brand quality cells.
The amazon description is all kinds of wrong (says it’s for an Acer?)… the battery pack that arrived was in Dell-branded packaging and the pack itself had a Dell label on it. I figured at $11.xx with Prime shipping, it seemed worth the risk.
That is def. a dell battery, i have torn down a quite a few of that exact model. whether it is an original dell or clone, that i do not know.
Asus AA2-uL50 uL5La a23
5600mah 84wh
samsung 2800 irc18650 28A sdi
4.3v light purple
I’m new to the site, but I have a bunch of these Philips packs (M4605A) out of medical equipment. They get replaced every 2-3 years regardless of use. They contain 9 CGR18650CG (MH12210) each and were exceptionally easy to pull compared to the drill packs I’ve done. Cadex charger primed the cells and all of them reached at least 90% of the rated capacity. As back up batteries they probably haven’t been cycled at all and arrive at full charge to be recycled.
Thanks guys, list updated
Not bad for a free battery pack on this one.
Laptop Battery
Toshiba PA3612U-1BRS
18650 Battery
6 x NCR18650 @ 2900Mah
pictures of new un-welded cells. Is your pack used or old stock?
Forgot to add I have not seen this pack for less than $5 per cell…
yea, i forgot to get pictures of the cells, I will get pics when i get home. it is old stock, i salvaged it from work.
EDIT
Wife sent me the image, i just didn’t read my email. image of cells updated
Wow they look a lot cleaner then mine :_( So much glue I had to bin the wrappers.
Taken out of Panasonic CF-VZSU46U 9xNCR18650
wow that does look pretty bad, but i will get the info updated in post one thanks dru_dragon
Sorta like the picture of the BigMac and what it is you actually get!
Scored these 4 battery packs at Best Buy a few weeks ago:
Here are the details on them individually:
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
9 orange batteries, UR18650ZT R1122
Other codes on battery: Q26C, QF3ZTBD, 065413
All tested at 4.29v right out of the case! :bigsmile:
Toshiba PA3793U-1BRS
10.8V 4200 mAh
6 green batteries with black tops, CGR18650CE, MH12210
Other markings: A19 LXI, B9808, 949 (or 919) 67P EE9
Made in Japan
2 batteries at 3.78v, 2 at 3.80v and 2 at 3.81v
Dell FK890
11.1V “Japan Cell”
9 Lavender batteries with black tops, CGR18650E, MH12210
Other marking: E7810
3 batteries at 4.05v, 3 at 4.06v and 3 at 4.06v :bigsmile:
Dell Ky265
11.1V
9 Pinkish/Lavender batteries
Samsung ICR 18650-26D SDI 972
3 cells at 0v, 3 at 1.4v and 3 at 2.15v
Are the last 3 salvageable at 2.15v???
Wow, awesome pull, you got some nice cells in there kronological.
I will get the 1st post updated.
How tough was the Lenovo battery to open?
I really like the UR18650ZT cells, only have a few of them myself.
The lenovo was not that bad…maybe a little tougher than the others.
The nightmare pack was an HP pack that I tore apart awhile back…sheez!
Oh…and are the CGR batteries Panasonic?
Yea HP packs are a bear and the CG18650E are Panasonic’s
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
All tested at 4.29mAh right out of the case! :bigsmile:
10.8V 4200 mAh
Made in Japan
2 batteries at 3.78mAh, 2 at 3.80mAh and 2 at 3.81mAh
Dell FK890
11.1V “Japan Cell”
3 batteries at 4.05mAh, 3 at 4.06mAh and 3 at 4.06mAh :bigsmile:
Dell Ky265
11.1V
3 cells at 0mAh, 3 at 1.4mAh and 3 at 2.15mAhAre the last 3 salvageable at 2.15mAh???
I think you mean V instead of mAh.
Der…my bad.
Corrected.
