Thanks guys, list updated
Not bad for a free battery pack on this one.
Laptop Battery
Toshiba PA3612U-1BRS
18650 Battery
6 x NCR18650 @ 2900Mah
pictures of new un-welded cells. Is your pack used or old stock?
Forgot to add I have not seen this pack for less than $5 per cell…
yea, i forgot to get pictures of the cells, I will get pics when i get home. it is old stock, i salvaged it from work.
EDIT
Wife sent me the image, i just didn’t read my email. image of cells updated
Wow they look a lot cleaner then mine :_( So much glue I had to bin the wrappers.
Taken out of Panasonic CF-VZSU46U 9xNCR18650
wow that does look pretty bad, but i will get the info updated in post one thanks dru_dragon
Sorta like the picture of the BigMac and what it is you actually get!
Scored these 4 battery packs at Best Buy a few weeks ago:
Here are the details on them individually:
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
9 orange batteries, UR18650ZT R1122
Other codes on battery: Q26C, QF3ZTBD, 065413
All tested at 4.29v right out of the case! :bigsmile:
Toshiba PA3793U-1BRS
10.8V 4200 mAh
6 green batteries with black tops, CGR18650CE, MH12210
Other markings: A19 LXI, B9808, 949 (or 919) 67P EE9
Made in Japan
2 batteries at 3.78v, 2 at 3.80v and 2 at 3.81v
Dell FK890
11.1V “Japan Cell”
9 Lavender batteries with black tops, CGR18650E, MH12210
Other marking: E7810
3 batteries at 4.05v, 3 at 4.06v and 3 at 4.06v :bigsmile:
Dell Ky265
11.1V
9 Pinkish/Lavender batteries
Samsung ICR 18650-26D SDI 972
3 cells at 0v, 3 at 1.4v and 3 at 2.15v
Are the last 3 salvageable at 2.15v???
Wow, awesome pull, you got some nice cells in there kronological.
I will get the 1st post updated.
How tough was the Lenovo battery to open?
I really like the UR18650ZT cells, only have a few of them myself.
The lenovo was not that bad…maybe a little tougher than the others.
The nightmare pack was an HP pack that I tore apart awhile back…sheez!
Oh…and are the CGR batteries Panasonic?
Yea HP packs are a bear and the CG18650E are Panasonic’s
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
All tested at 4.29mAh right out of the case! :bigsmile:
10.8V 4200 mAh
Made in Japan
2 batteries at 3.78mAh, 2 at 3.80mAh and 2 at 3.81mAh
Dell FK890
11.1V “Japan Cell”
3 batteries at 4.05mAh, 3 at 4.06mAh and 3 at 4.06mAh :bigsmile:
Dell Ky265
11.1V
3 cells at 0mAh, 3 at 1.4mAh and 3 at 2.15mAhAre the last 3 salvageable at 2.15mAh???
I think you mean V instead of mAh.
Der…my bad.
Corrected.
I joined late last week so I could post this harvest album; Only now do I decide to post it :P
Notes on opening packs/VDCs in the descriptions for the images. Image thumbnail is a link, otherwise here
Batteries (Not in Order):
DELL branded C6017 (14.8v 4800mAh 71Wh) --> 8x Samsung ICR18650-24E
HP branded 416996-163 (14.4v 63Wh) --> 8x Sony US18650GR
DELL branded JKVC5 (11.1v 48Wh) --> 6x LG LGDAS31865
Generic HP (Barcode: HP8028LH121105070048; Warranty Sticker: 00761E07B) [14.4v 5200mAh] --> 12x Lishen LR1865AH
Sony branded VGP-BPL2 (11.1v 7200mAh) --> 9x Sanyo UR18650P
Generic HP (Warranty Sticker: 00761D14B) [14.4v 7800mAh] --> 8x Lishen LR1865SF
Tools Used:
Needle Nosed Pliers
Wire Cutters
Chisel
Cheapo Harbor Freight MM
2x Nitecore 2014 i4s
1x HZS-002
1x FT charger
Electrical Tape (I was brutal on the shrinks)
DELL C6017
HP 416996-163
DELL JKVC5
Sony VGP-BPL2
Tools Used:
Needle Nosed Pliers
Wire Cutters
Chisel
I am interested in what cells these batteries produced. Thanks for the post.
Otanacious:snip
The thumbnail image is a link ;)
2004 Toshiba laptop.
18650 cells
Battery Pack: PA3382U-1BAS
DC 14.8V - 6450mAh
12 Sony US18650GR 2150mAh Green with Black washer
6 cells read 0V, 3 cells read 1.50V, 3 cells read 2.60V
17670 cells
Battery Pack: PA3481U-1BAS
DC 10.8V – 1200mAh
6 Sony US17670GR 2150mAh Green with Black washer
5 cells read 1.50V, 1 cell reads 2.70V
I’m new to the site, but I have a bunch of these Philips packs (M4605A) out of medical equipment. They get replaced every 2-3 years regardless of use. They contain 9 CGR18650CG (MH12210) each and were exceptionally easy to pull compared to the drill packs I’ve done. Cadex charger primed the cells and all of them reached at least 90% of the rated capacity. As back up batteries they probably haven’t been cycled at all and arrive at full charge to be recycled.
I also had 2 of them (another 7 had a friend)
Philips actually have a recall running due to capacity loss before 3 years change cycle!
we measured them between 950 and 1200 mAh …
into the bin!
IBM branded 92P1011/1062 (10.8v 4400mAh) --> 6x Sony SF US18650GR
Lenovo branded 42T5229/5230 (10.8/14.4v 5200mAh) --> 7x Sanyo UR18650FM
IBM branded 08K8193/92P1064 (10.8v 4400mAh) --> 6x unmarked Sanyo UR18650FJ
