Ric rarely answers questions here, he just uses this forum as free advertising.
Thank you ric, i canāt wait to get this now.
Too bad your efforts to stuff in more emitters didn't work. I hope the price for the actual version is a lot lower than concept.
I personally HATE any āhold to turn onā delay and see no point in it as long as a light has a good mechanical lockout available. When I press the button I want the light to turn on immediately. I also do not like a instant on where you then have to hold the switch for some time before the light stays on when the switch is released like the Solarstorm T3 and T4 are. Such user interfaces are to me DUMB. At least for the turn on function I want instant response. Fumbling around with time delays and holding switches for some time are distractions in an emergency situation.
1/2 second delay for on and off would have been better but I am really looking forward to this little gem of a light!
Same with others, I prefer 1/2 second, but 1 second still better than version 1.
180 seconds on turbo vs 30 seconds. Now waiting for the final price and may be additional discount for promotion
Gen 1 is one of my favsā¦
Gen 1 | Gen 2 | |
On | Momentary Push | 2 Second Push |
Off | 2 Second Push | 1 Second Push |
H2O | No no no! | Water-proof (glowing) switch |
Does that sum up the difference? Did Gen 1 have copper?
Iām prob not going to make the jump. As much as I despise the 2 second āoff,ā a 2 second āonā might be even more frustrating (How do I turn this thing on? versus How do I turn this thing off? from my wife).
What is the configuration of the LEDs in there? If in parallel, doesnāt the Vf of the G2 level out around 3.25? So why the boost driver? I honestly donāt know, not trying to be snarky.
Oopssā¦ +100
I have the original, and the only problem with it ā a significant one in my experience ā is that it gets turned on easily whether in pocket or pack or hanging on a belt hook. Iāve been trying to come up with a rotating shield for the button. Maybe mineās just unusually twitchy.
Is there a retrofit to put an O-ring under the switch to water proof the Gen1?
Nevertheless, itās my first choice to grab at this point, to take out any time I need light outdoors.
Ditto.
I turn the tail to lock it out, but this means 2 actions to turn it back on.
Hmm there must be some way to hack the on off durations ?
Ric is behind development, so he probably could get that changed, but there's no reason to do that if you guys are going to buy it anyway.
The Gen1 has LEDs in series. This is the only single cell boost driver I know of that will do that (it will also run a single MTG2 from a single 4.2v cell, of course, but there's no way to fit that combo into the Gen1 host unless you just make it a mule).
I wonāt be buying this one, i canāt see any major improvements besides turbo. Have I missed something?
Hey comfy, what about this At only 14.3mm in height, Iām pretty sure you can find a way to cram it all in thereā¦ Seriously giving it thought myself. The triple optics are what, 11mm? Not sure which optics this light uses in stock form, might be even taller.
Things getting a bit more interesting?
My bad, the 10507 is only 6mm tallā¦
Copper MCPCB, shorter long-press times, new outside design. If you can't see any difference you aren't looking.
Yes overlooked the copper bit.
THe press times have been extended. Old - instant on 2 sec off. New - 2 sec on 1 off. +1 sec overall.
I'll be getting one, for sure.
which price are you planning to call?
Iād prefer instant on/off and hold to change modes.
