I’m interested in either panasonic 18650 PF 2900mah and 18650-25R, offer in either will be nice :bigsmile:
can you give us the world?
I can't, but I can give u a flashlight to light up the world.
Deal 16/08
EVVA 26650 4500mAh 3.7v Protected Rechargeable Lithium-ion Battery
Code:EVVA26 Price:$10.99 Original price:$12.99
- Use quality King Kong lithium ion cell, highest capacity cells, high performance
With Protection circuit Board: SEIKO IC, three Mosfets which can stand higer current
Small internal resistance
High energy density, low self-discharge
Pollution free, long cycle life
No memory effect
Ordered 4, thanks!
Deal 19/08
Olight SR51 Intimidator CREE XM-L2 1080lm LED Flashlight
code:SR51 Price:$49 original price:$64.99
if u like the standard one with aluminum box, pls PM me
Your link directs to an ebay auction.
Also, bg’s has 3400 mah batteries & xml2 too.
BG doesn’t include batteries but it is international. The ebay link is $40 postage to Aus
Not showing in any of the links BG posted.
Hi neil
Olight SR51
i like the standard one with aluminum box is it same price $49?
Deal 20/08
1*30 Reflex Laser Sight Rifle Scope With Red+Green Laser Configurable
CODE:LSRS Price:$20.99 Original price:$23.69
Maybe someone need this one for hunting.
Specification:
Product name:1*30 Reflex Laser Sight Rifle Scope
Material:aluminum alloy
Waterproof:Yes
Light color:Red and Green
Power supply:CR2032 cell batteries (included)
Size:14.2cm x 5.5cm x 5cm
Weight:about 276g
Deal 21/08
2PCS INR18650-25R 2500mAh 3.6v 20A Rechargeable Li-ion Battery
CODE:IN25R Price:$11.25 Original Price:$13.69
Specification:
Product name: INR18650-25R 2500mAh Rechargeable Lithium-ion Battery
Brand: Samsung
Nominal Voltage: 3.6V
Discharge cut-off voltage: 2.5V
Nominal Capacity: 2500mAh
Standard Charge: 1.25A, 4.20V,CCCV 100mA cut-of
Discharge: 0.2C, 2.5V discharge cut-off
Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
Weight: 45g
Size: 18mm x 46mm (body diameter x length)
Quantity:2pcs
sumsung 25R deal today!
Deal 22/08
Dipper D19 Cree XM-L2 U2-1A 5-Mode 1000 Lumens 26650 LED Flashlight
Code:DD19 Price:$36.99 Original Price:$45.09
Emitter: Cree XM-L2 U2-1A
Mode:1.5%Low-40%Middle-100%High
2.5%Low-40%Mid-100%High-100%Strobe-100%SOS
Protection: reverse polarity protection, low voltage protection
With stainless steel attack head and memory mode
Deal 25/08
Smiling Shark 3W SS-5049 Mini LED Bright Hand Torch Flashlight
code:DBLF04 Price:$1.9 Original price:$2.99
Features:
The product is a mini LED flashlight
It with 1 bright LED and comes with a clip, which can easy to carry.
Clipe design, easy to carry and use
LED light will practically not burn out
Fits Comfortably in Hand
How about this zoomie that was being talked about a few days ago
http://www.banggood.com/JAX-Z1-Cree-XM-L2-U2-Zoomable-1100LM-5-Mode-LED-Flashlight-p-940891.html
Maybe the battery tube extension too.
i just send out one to unkown00100, will after a good review, then make a deal better?
