I do not pot my drivers, but my mods are almost always small lights with either lineair drivers that have 7135's close to the edge, or recently 105C-based FET-drivers that produce hardly any heat al all. I did extra heatsink a lineair driver once using copper rings soldered over the outer ring that drove an infrared Oslon led, because the ledvoltage was under 2V and the 7135's had to burn 700mW each.
Do you use silicium carbide because it has particularly high thermal transfer properties, or is it just a filler to get the right consistency?
I bought it in the first place just for the thermal transfer but because you can turn it into a putty it makes working with it really easy. One thing I didn’t state that I should have is that as long as you use glass and clean up right away you can re-use the same bowl over and over. I messed up one night and forgot, so now I need to make another trip to the second had store to pick up another glass bowl.
I wonder how much different this is than Arctic Silver 5? I know that arctic silver also has silicon carbide. I looked up all the numbers on the different ceramics and silicon carbide was a lot better for heat transfer than alumina that they use in arctic alumina and others. Also the hotter it gets the faster it transfers heat and over time it will transfer heat even more. I guess it doesn’t even max out until it’s been used for 200 hours.
No JB Weld? How on earth do you ever fix cars, motorcycles and snowmobiles?
On the colors that's a good idea you could make a million bucks. Kinda like duct tape used to only come in grey. Between duct tape, JB weld and a hammer you can fix anything.
I'm a mad potter too 18650. Even if it just pulls out a few degree, they're the most important ones to get out. Just my opinion which may not be based on fact.
I’ve yet to start potting, considered it but I just mess with the FW to much. One thing I’m thinking about is finding a tiny 5 pin M/F connector and start adding those to my lights I need to reflash a lot, then I could pot them but still be able to flash, just leave the head of the connector sticking out of the pot.
I’ve seen someone pot a driver entirely with Fujik. Would it even benefit from that stuff?
I like the idea of filling in gaps to maximise heat efficiency, although it means that you are no longer able to replace or make adjustments to the potted driver.
anything conducts heat better than air, so Fujik will help. But while you're at it it doesn't harm to use something better and this recipe sounds good.
Nah. But I´ve used it before but based on ordinary silicone from the hardware store and mixed in lots of the silicon carbide dust you also use.
Gives you a few hours to work with it. And it mixes quite well. I put a few drops of silicone oil in it to make the mixing better. Also seemed to keep the air out of it better.
This compound can be remowed btw. If you know you might remove it later you can spray the driver and cavity in a thin film of silicone oil before applying it. Then it is quite easy to get out.
try “depleted fujik”. spread it thinly on paper and let the paper absorb the silicone oil. scrape it off then spread again on another sheet. the consistency of putty
well there’s still convection and radiation of heat. so styrofoam is worse than air
Great tip. I will be trying this. I've just been using my potting recipe that I have a thread on. It's great because there is not curing time, but it's a hassle to remove.
I noticed reading up on Arctic silver 5 that they actually use different grits in their mix. I’ll be ordering more silicon carbide soon in various grits. Makes sense to mix the smaller particles with some larger depending on what you are using it for.
