[quote=InfinitusEquitas]
Very nice mod! You weren't kidding when you said it was different from the standard Vinh mod.
I'm very curious to see what numbers you will get when you get your X60 though.
[/quote]
Thanks! Yeah, im not sure of anything around this size that puts out the throw/ lumens combined with sophistication and built quality in a nice to use package.
Why do I still need X60? Please talk me out/into it. :D I like lots of flood for walking around, but if I need a ton of flood in a 6x18650 sized light. I can just use my retarded 12 XM-L light if I want big output (still need some changes to it.) That will outperform a modded X60M.
I got a Solarstorm/Fandyfire L3 (6x18650) light, and Im planning on making it into a 3x18650 light. I feel its just too long.
Compared to my TK75 Im quite sure that X60 will be very similar or marginally brighter before stepdown. Less throw, especially after step down. Id rather have 4 batteries in the light, and 4 spare batteries on my body (jacket/backpack), then to walk around with a light that is much larger and heavier.
Thanks. How you been able to set up the taskled H6flex to your liking? What setup are you using?
I gotta say, having a power switch and a battery LED made it much easier (less difficult) to understand the driver when not being used to it and setting it up. There are still features I have not tested, and maybe some more fine tuning to the battery voltage warnings.
+1 to what you and the cat said. :D
The taskled driver is one of those drivers that I feel seemed quite expensive, but once Ive learned its features better. It offers so much more compared to pretty much everything that is supposed to rival it. Does anyone know if there are any other "high-end" driver options like that out there? Just curious if I have missed out on something.
I would have preferred to see some changes to the default UIP UI. But the hardware, performance and the ability to customize so much is nice.
Its my first light with a taskled driver, and Im pleased with what I got. :)
Yupp!
