Not showing in any of the links BG posted.
Hi neil
Olight SR51
i like the standard one with aluminum box is it same price $49?
Deal 20/08
1*30 Reflex Laser Sight Rifle Scope With Red+Green Laser Configurable
CODE:LSRS Price:$20.99 Original price:$23.69
Maybe someone need this one for hunting.
Specification:
Product name:1*30 Reflex Laser Sight Rifle Scope
Material:aluminum alloy
Waterproof:Yes
Light color:Red and Green
Power supply:CR2032 cell batteries (included)
Size:14.2cm x 5.5cm x 5cm
Weight:about 276g
Deal 21/08
2PCS INR18650-25R 2500mAh 3.6v 20A Rechargeable Li-ion Battery
CODE:IN25R Price:$11.25 Original Price:$13.69
Specification:
Product name: INR18650-25R 2500mAh Rechargeable Lithium-ion Battery
Brand: Samsung
Nominal Voltage: 3.6V
Discharge cut-off voltage: 2.5V
Nominal Capacity: 2500mAh
Standard Charge: 1.25A, 4.20V,CCCV 100mA cut-of
Discharge: 0.2C, 2.5V discharge cut-off
Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
Weight: 45g
Size: 18mm x 46mm (body diameter x length)
Quantity:2pcs
sumsung 25R deal today!
Deal 22/08
Dipper D19 Cree XM-L2 U2-1A 5-Mode 1000 Lumens 26650 LED Flashlight
Code:DD19 Price:$36.99 Original Price:$45.09
Emitter: Cree XM-L2 U2-1A
Mode:1.5%Low-40%Middle-100%High
2.5%Low-40%Mid-100%High-100%Strobe-100%SOS
Protection: reverse polarity protection, low voltage protection
With stainless steel attack head and memory mode
Deal 25/08
Smiling Shark 3W SS-5049 Mini LED Bright Hand Torch Flashlight
code:DBLF04 Price:$1.9 Original price:$2.99
Features:
The product is a mini LED flashlight
It with 1 bright LED and comes with a clip, which can easy to carry.
Clipe design, easy to carry and use
LED light will practically not burn out
Fits Comfortably in Hand
How about this zoomie that was being talked about a few days ago
http://www.banggood.com/JAX-Z1-Cree-XM-L2-U2-Zoomable-1100LM-5-Mode-LED-Flashlight-p-940891.html
Maybe the battery tube extension too.
i just send out one to unkown00100, will after a good review, then make a deal better?
Not really flashlight related but a nice (foldable) Solar Panel (like SKU091976, SKU155263 or SKU091966 or eventually all 3 to cover different needs ), if possible with a nice storage battery or battery enclosure, would make a nice all-in one package for the camper/hiker amongst us or a SHTF scenario.
How about a Roche F6. It looks like a fun light to play with. https://budgetlightforum.com/t/-/26078
Found 1xAAA lights are too small and often too small to find, but found this 2xAAA light just right size for handling and locate.
this just isn’t fair. have you been going through my wishlist? i am going to be broke if you keep going down the line of items I want. :bigsmile:
Deal 28/08
Outdoor Sports Cycling Polarized Sunglasses Goggles UV400
code:8926a1 price:$11.99 original price:$13.99
Features:
This Cycling Polarized Sunglasses is made of thermoplastic whose excellent flexibility and durability make it the perfect material for performance eyewear.
It is incredibly lightweight, which contributes to the comfort of our eyewear and the tendency to forget you're wearing it
Lenses are made of polycarbonate which is used in bullet proof glass, riot shields and astronaut helmets with the function of high impact resistance, inherent UV protection and light weight
Block 100% of UVA, UVB and UVC rays, and harmful blue light to 400nm
Polarized lenses are made with an injection process, ensuring they're optically correct, decreasing eye fatigue and increasing comfort
Adjustable nose pads are available to customize the fit of your glasses
Suitable for riding, cross-country, outdoor, mountaineering, tourism and other projects
Interchangeable lens. The different lens, different shades and colors which allows you to choose one that fits you best
Mirror back on the set of antiskid foot sleeve, streamlined design
tomorrow's deal?
anyone agree?
sorry
I can't see your wishlist, but you can PM me
I would prefer the 5200 Evva 26650 you mentioned last week! That never came up.
Yes, and the charger head?
Roche f6
