See how that warp in the outer edge of the lens remains consistent? I believe this is what is keeping this light from being far up into the 600Kcd territory.
Also notice how the reflector has an appearance like it’s Orange Peel? This is a smooth reflector. These are reasons why I dislike plastic reflectors.
I also think that it should be within that territory…. I think the poor finish of this reflector is the cause, you did something? try to clean it? does not look like std TK61 reflectors
No, I didn’t do anything to it, other than cut the bottom out.
Ordinarily if an aluminum reflector has ripples or lines in it I’ll hand polish it out. I’ve had great success with this. Again though, can’t do that with a plastic reflector. Beats me. I’m planning to search for a good reflector that will fit in here and see if I can get a better result.
Anybody know where a TK61 reflector can be found? Or one from another light that will fit this one?
Stock TK61, dedome only, current bump + dedome, how much cd does it increase with current, is it linear or at least close to it? based on this, it should be 1700 lumens or lets say 1650, does this means around 60% throw increase? thanks.
Just an FYI- I’ve already corrected the issue tterev3 pointed out in the .sch, just need to fix the board (I added a gate resistor, series / limit resistor (or whatever the name for that would be) and BJT to facilitate the P-FET shutting down all the way.
This is high on my priority list but not at the top and I till I can secure a TK61 for testing I seem to be lacking motivation with all the other crap I have to do (hey I just posted the project 3 days ago, cut me some slack lol).
My TK61 arrived today. Batteries took a couple of hours to come up to 4.2.
For my short available range it lights up well. This weekend I’ll give it some distance over water.
Voltage regulator fried, I think it is that same type like the regulator near, type “C01C”. Can anyone help checking his tk61’s driver?
Before I removed it only lowest mode was working, after removing flashlight is dead (pretty normal?).
I found some components in aliexpress and I plan to buy some. If I bridge the spot over there, what will be the results? Do you have any idea if I can find one of these regulators in other drivers?
I just bought some Fenix TK61 that I want to control from a arduino chip. Has anyone here tried to do that? I want to be able to start a special light sequence that the arduino will trigged in a stage performance I’m creating. In the best of worlds I would love to be able to dim the light form 100-0% be able to strobe it and have total control over the light. Is it possible to just let the arduino control the power button, and do fades of the light beam through pulses in 100% brightness mode? And where on the torch’s circuit board would you guys solder the chip on (pre or post the power button, or somewhere else)? Hope that the purpose of the project is clear enough for you so you can imagine what’s needed to be done. Looking forward for some answers form the Pro’s : )
It’s not that easy as it may look. You can control power button on the flashlight if the button is an electronic “switch” but if that button is only used for power on and off or mode 1 mode 2 and mode 3 that’s all you will be able to get using arduino, ona and off…
To have absolutely full control over the flashlight you have to find PWM pin of the MCU used in the flashlight, lift it from the board or unsolder it and use arduino PWM pin to control the LED, of course, for that you will have to write the code that you will run on arduino board.
