Very floody light?
10 posts / 0 new
Nautic
Nautic's picture
Last seen: 9 months 3 weeks ago
Very floody light?
Need a very floody light to explore big underground very dark places. I have several
xml P60 lights which I use for the moment, but I wonder if one of you guys could
recommend any of the new 1000+ lumens xml-lights for the purpose: Not a shrower
but lots of flood and spill.
Cheap quality is good - Expensive crap isn´t
Budgeteer
Budgeteer's picture
Last seen: 6 years 6 months ago
Get a mrv clone with XM-L such as the 24usd at manafont and remove the reflector. Put back when you need a rather throwy light. Smile
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
mazda96hatch
Last seen: 1 year 11 months ago
This http://budgetlightforum.com/node/3603 is very bright in flood mode with a very even spread without any rings but not so good as a thrower but does give you the option.
VFMaddict
Last seen: 1 month 1 week ago
Might be a bit too big given the OP's likely use.   But the Yezl XM-L zoom in flood mode might be just right and pocketable.
EDIT:  Not sure about the MRV suggested earlier.   I don't own an MRV but if the lens is held in by the reflector then taking the reflector out may be a no go.
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
edc
edc's picture
Last seen: 4 years 5 months ago
Yetzl xm-l zoom has amazing flood.
http://i1193.photobucket.com/albums
mazda96hatch
Just did a quick ceiling bounce test and the Z1 looks about twice the brightness of the Yetzl with both having a similar size beam width.
Langcjl
Langcjl's picture
Last seen: 1 year 12 months ago
The problem with the flood to throw lights is that you lose a lot of the light to the optics/mechanism. If an XML p60 isn't enough, and you can never have enough can you, I would say one of the triple XMLs would work great. OP says he wants 1000 lumens. You are not going to get that from a single XML zoomie. You will not get that from any single XML, that I know of, but you will come close enough that it doesn't matter.
Piers said " ....but who wants enough light, when you have the option for far too much "
mazda96hatch
The three XML certainly lights up a huge area really brightly but run time and heat might be a problem.
gcbryan
Last seen: 4 months 18 hours ago
Take any light and diffuse it and you'll have flood. I suppose one of the 3 XM-L lights diffused would be what you are describing.
Nautic
Nautic's picture
I thank all the posters for their different suggestions. Some of them I have been around
myself. I think a 3xXML are high on the list now. The volume of light will be great and I
can live with the throw, it must have, as a bonus. A diffuser may be an advantage also,
even on my present lights.
