Fair enough
There's plenty of room for everything, it looks worse than it is. Like I said there's even room for the programming clip with the LED wires still in place. The only tweak I do, which probably isn't necessary, is to trim off the corners of the switch bracket.
For the copper spring plate, I clamp the copper to the plug and chop off the excess with tin snips, then smooth out with a file. The plug is already the same size as the disc needs to be.
Yeah, that makes sense to me. It works better as a status indicator than any kind of warning. As you pointed out, the step down and flashing will handle that.
“For the copper spring plate, I clamp the copper to the plug and chop off the excess with tin snips, then smooth out with a file. The plug is already the same size as the disc needs to be” -Comfychair.
I don’t have an adjustable-voltage power supply, but I think I can still get the voltage levels by using a real battery and a DMM. I also have a small variety of cells to try, including 20R for maximum output and protected regular-amperage cells.
For the beacon, it may be feasible to blink green for > 3.3V and red for < 3.3V. Depends on how much power it costs to check the voltage, and how much code space is available.
Provided that there is enough code space the battery voltage could be checked periodically (using a counter) rather than every time. Approximately once per hour might be sane to allow for ~15min of recovery. To get totally unnecessarily complicated you could do one check ~15min after the MCU goes to sleep using the counter and then set a flag and start doing the check ~daily until the light was turned on again, resetting the flag. Wow that’s a bunch of extra stuff for little benefit though…
I removed all the resistors on the stock driver second version. And I also added copper braid to the steel spring. This F6 heats up fast now. Gets very hot after just 15 seconds of running on high. I’m still using the stock XM-L2 led. The light definitely has greater output now but I have no way of measuring how much.
The stock LED is on a cheap aluminum MCPCB, be careful. You've got a direct drive light with the LED not on copper. Risky.
Thanks for the advice. I will get an xml2 noctigon to install. The led remains much brighter than stock for about 1 min and then starts to really dim as the light gets very hot.
Nice!
Nice indeed! Thank you. Now I just have to figure out which light to use this in.... (Dont own this particular light)
Roche X3 should use the same driver (scroll down for the 'user pics') http://www.banggood.com/ROCHER-X3-CREE-L2-800-Lumen-White-Light-LED-Flashlight-p-916697.html
I don't think it has a window/lens for the status LEDs, but that can be added without huge drama.
What about using clear fingernail polish or Norland that both cure with UV light and would be very clear?
It would probably work best with slightly diffused plastic, not perfectly clear. I'm sure there is something in the hobby world that would be exactly right.
If the right kind of plastic rod around the right size can't be found, an alternative would be something like clear Epoxy 330, sanded on the inside face to act as a diffuser.
http://www.ebay.com/itm/360884112895
Available in other sizes/styles (end glow = has an outer cover, side glow = nekkid along the whole length).
Hmm… that might be useful for a totally different project I have in mind… Either that or electroluminescent wire. I still haven’t figured out how to make the thing though; I want it to light up at least a dozen wires quickly in a rotating sequence.
How far is the the software for using the voltage indicator LEDs?
I got a yezl y3 today and the eswitch boot looks semitransparent so I thought that it might be cool to use a extra indicator led?
I don’t have firmware working for the voltage indicator LEDs since I have no hardware to test on. My only flashable e-switch light is a SRK.
The Yezl Y3 might be a good host for this too, after adding the extra LEDs inside. I don’t have one of those, but have sometimes been tempted to get one or a HD2010 to mod as a thrower.
I only care about the voltage indicator window thing because the fancy replacement driver has the provision for two onboard LEDs, and with a easily reflashed controller and two LEDs you could make it do some very interesting things. Well, someone who understands how to code for these things could, though I am not that someone. I only do the nuts & bolts stuff.
Where can I order this driver?
Now I tried to improvise something with Nanjg 105c and STAR Firmware by JonnyC but it took me too much room there and I can’t close the torch well.
I need a driver with a short press for on/off
