Look what I found in the recycle bin
I’ve only ever been questioned once and I explained that the likely destination for the vast majority of the cells inside the packs I was taking was in a hazardous waste dump but that I would take them home for private use, disassemble them myself (not some chineese kid for $.02 a day) and the cells would be used on my personal equipment and the plastic trash recycled. They were more than happy with that answer and I’ve never so much as been approached again.
Here is a pic of the older Makita Li-Ion pack, the one I believe you have. There is no BMS and no leads to each cell. This is a 10 cell, 3Ah pac that was not used very much when apparently a pair of cells failed.
The 8 cells that were still good are in excellent condition and each test at over 1500 mAh each.
This next pack is also a Makita, but one of the newer improved packs. It also is a 3 Ah pack. Notice this pack has a BMS circuit and leads going to each individual cell. These newer packs can be identified by the star.
Now the 2 different packs side by side. The newer pack is on the right.
Tool batteries seem to work just fine in my lights at the beginning of the use cycle. In other words, 1250, 1400, 1500, etc samsungs/sonys are the exact same brightness with most of my one-emitter lights that are not high demand or direct drive —— compared to testing the same light with a 2400-2* cell. Even tested a bunch with my light meter. The tool batts don’t just last as long at full brightness, which is just fine for me for around-the-house lights. And they seem to charge faster.
I find so many of the Ryobi, makita and other tool packs that I sure wish they used 2800 samsungs or 2900 panasonics!! I did see some new packs that said they contained 2400 and 2600 mah batts. They are just too new to make it to the recycle bins yet, so I don’t know what’s in there. When I do find one, BLF will be the first to know what they contain!!!
Tool pack cells are IMR type and generally have lower capacity, but can deliver more amps. For very high powered lights with multiple emitters in parallel, they may be preferred.
I somehow missed your post…
Thanks for the pictures! The first pack looks exactly like mine… no balance leads.
That second Makita pack, with the star, has the same cells and the balance circuits. 2 weeks ago I charged and discharged each pair of cells individually with my B3100 and some alligator clips. Each pair of cells measured in the 2900’s mAh. Almost as good as new! When I was finished with my tests, I fully charged them each to 4.20V. Now 2 weeks later they are each sitting at 4.15V. I don’t know why that pack was discarded, the cells are healthy, maybe the BMS circuit is faulty and it will not charge on a Makita charger. Maybe the pack is bricked.
I am not yet ready to believe that the Sony’s self balance. On the other hand, how does that Ridgid and older Makita pack get away with not having one?
I guess the self-balancing is fine when new - it’s when the resistance levels of the cells vary that it would possibly become a problem -> try not to bang my batteries around.
I had an old 5 cell Makita pack go bad with less than 10 charges (one cell reportedly will self drain and then the pack will not recharge you don’t regularly recharge them). Perhaps the balance updates help avoid the non-recharge problem? Anyway, took it by one of their factory shops where they can read recharge info on their packs - they did a free exchange with a 10 cell - happily I now know it has the star and new wiring - thanks for that info! Will be interesting to compare old and new 10 cell packs as they age.
I just read through this thread and wanted to say that I have some Sony US18650GR 18650 laptop pulls (N.O.S. HP 9 cell Pack) that seem to discharge down to about 4.1V after I charge them up to 4.2V. I just noticed this behavior a week ago. I wonder how much capacity I'm losing with them self-discharging down to 4.1V. I did a capacity test (from 4.2V) on my new OPUS and got about 2600mAH on two of them. Interesting that others are seeing the same behavior on similar Sony's.
-Garry
I’d definitely like to hear the results of your capacity test from a rested 4.1v.
Nice of you to join the thread Garry.
I must point out though that the Sony’s we’re talking about are drill pack IMR’s
wight you asked me earlier how I handled rummaging through the recycle bins and I gave you my answer. However, a couple of days ago I got caught off guard. While I was poking around in one at HD, I heard one of the girls behind the returns desk ask me what I was doing.
I looked up and dead panned “I’m looking for an old sandwich or something, I haven’t eaten in a couple of days!” She looked at me and laughed and said “Oh there was a half in there earlier, but I already ate it” We both laughed and I went back to my business. :bigsmile:
I pulled out these 2 brand new Ryobi packs, thrown in the bin by HD. I haven’t taken the 10 cell pack apart yet, but it reads 17.65V or an average of 3.53V per cell. The 5 cell pack had 1 dead cell, the other 4 at 3.61V. I don’t know if it was just a bad cell, or that channel on the BMS leaks. I see either all the time.
2 days ago at Lowes I found an unopened 8 pack of Duracell AAA’s. The date on the pack was 2012 and they are 7 year cells. The only thing I can think of is that someone thought that date was an expiration date, like on food. Got them just in time, yesterday 2 of my remotes needed new cells’ :slight_smile:
That is Lowes parking stripe in the background, shot this outside in the lot.
Wish I knew of places in ga I could go thru these bins
home depot has no stores in its headquartered state?
Do they just let you go thru the recycle bins or do you have to ask? Only real recycle bin for battery packs round here is best buy
i’ve never done it so i don’t know, i’ll defer to other members who have
It seems the drill packs from all the manufacturers have a recycle number on them
1-800-822-8837. I used that number to find this site.
Type in your zip code and all the recycle bins in your area show up.
In my area, all the Home Depots and Lowes use this same service.
That info is awesome! Been dumpster diving for over 30 years and wish there was a site I could just type in a zip code and “Gold ” could be found.
As I said before “There’s Gold in them thar bins” :slight_smile:
http://dlg.galileo.usg.edu/dahlonega/
Fellow dumpster divers,
I recently came up with a lion Makita battery pack while diving in a Home Depot recycle bin. While researching the Sony 18650v batteries inside I came upon some good reading on these "konion" Sony IMR cells and their rumored self balancing properties. I don't understand it fully so I will just suggest any interested parties google search "konion self balancing" and read what the folks at endless-sphere.com have to say on the subject.
Brian
i found a toshiba pa3612u-1brs
I have found these in the past and they produce NCR18650 2900Mah batteries
I will update when i i open it.
I’m jealous.
The Best Buy near me has elaborate recycling bins, with a rubber flap “valve” and a sloped baffle, and its right by the front door 6 feet from the loss-control guy. I need to find some places with more accessible bins. I haven’t seen any at Home Depot, and they aren’t listed on the county’s list of battery recycling locations.
