Ok, guys and gals. I received this light a little over a week ago from Acebeam as part of their global testing campaign. They wanted a “professional video review” so I tried to make one. Inside the video you’ll see plenty of outdoor night shots, real video runtime tests, bad jokes, and nice crisp, 1080p video. I was told my audio was a bit low last time, so I tried to bump it up this time. Tell me what you think. Thanks for watching everyone and subscribe to my youtube channel for more videos like this.
While all my beamshots are in the video, I’ll post a few stills I took of this awesome light here. Oh and by the way, no mis-matched anodization was to be found on my sample. Oh and yes, the Acebeam Logo is supposed to look like that… it’s on the case that way too- so it’s not flaky etching. And it’s a fairly nice NW tint, which you can kind of see in the Moonlight mode comparison late in the video. And I could not detect any visible PWM on any mode by using the running water/fan blade trick.
Great review .
Thanks for sharing .
My Paracord Stuff
Hi mHanlen . May I ask… Your photo shows that the K40M has what appears to be a light orange-peel reflector.
Is this so? I ask because mine has a smooth reflector. Btw, mine was ordered when it was still “Supbeam”. Just wondering if they (Acebeam) have made the change.
Lights out! That's when things get interesting...
Quite an entertaining video review.
Thanks again for another interestingly amusing review. Did I miss the drop test?
djozz quotes, "it came with chinese lettering that is chinese to me".
Thank you for the awesome review. I might have missed it, but which battery did you use for the run time test?
Lovely video review and very nice audio levels.
I really appreciate your efforts as well as your humor, keep up the good work.
BLF ≠ B-grade Flashlight Forum
Great review, mhanlen. Thanks.
I’m happy to see that:
Question: did you have a fan blowing on the light during your level 6 runtime test? If not, did you get a chance to feel how hot the light got?
Nice review!
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
very good and entertaining review!
thanks!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
I umm didn’t want to damage the sidewalk this time…. Yeah….
I had to look at a few other lights, but you’re right. You might not notice it depending on the angle, but my shots clearly show it. It’s way more subtle than a typical orange peel.
I didn’t say… ooops. Sanyo 2600mah
http://www.fasttech.com/product/1143802-sanyo-ur18650f-18650-2600mah-pro...
No fan. It got hot, uncomfortably hot- but not to the point you couldn’t hold it. That Sky Ray King on the other hand will make you play hot potato if you leave it on high. I found this out the other day when a co worker tried to pick it up and wound up throwing it across the room.
Later today I’ll upload a slightly less sped up version of the video runtime tests that lasts a little over a minute The light does fluctuate in brightness- which you can see if you look carefully at the video here. But it seems to go down slightly and then get brighter again. I’m inclined to believe it’s temperature controlled. I’ll post this video here for all curious parties later.
My YouTube Channel- Flashlight and Headlamp Reviews
Good Day mhanlen,
VERY Good review...
Thank You Very Much,
George
Ok here’s level 6 only sped up 3000x. I’ll throw up level 5 a little bit later. It’s suuuuuper boring, but you can see where it steps down a little and gets brighter. Don’t fall asleep!
Hi. Thanks for the reply.
I reason I asked is that I wrote to Supbeam (Acebeam) soon after I received my K40M .
Told them that it’s a really good flashlight, my only suggestion being that it could benefit from using a (very) light orange-peel reflector .
It is generally thought that the MT-G2 emitter is more suited to that, and I felt the K40M could stand to lose a tiny bit of throw to gain a slightly smoother beam pattern.
I measured mine at 10m to be about 66kCd – which is about right according to the specs. In any case I bought mine for the flood mainly, as I already have the de-domed K40.
And here’s Level 5 folks. That should do it.
Well it worked, it’s pretty artifact free unless it’s on super low, and you can see a honeycomb or two from the emitter. It’s a nice smooth pattern. I happen to like orange peel reflectors, and while I like a good thrower, I don’t see how I’d really need any more than this.
My sentiments exactly
Thanks for the review and the time lapse beamshots. They tell the story.
Very interesting video review. Keep up the great work.
some of my actual experiments and reviews:
UF-T20 review and mod —->http://budgetlightforum.com/node/30186#node-30186
My EBRZM, over 1 million cd thrower—-> http://budgetlightforum.com/node/30274#node-30274
Ervin’s try (2nd. Annual BLF Scratch Made L
