Solarstorm SC02 mod with R,G,B,W,UV. So many 7135s!
32 posts / 0 new
tterev3
Last seen: 6 days 21 hours ago
EDIT 7/30/2015: I made a build video here: https://www.youtube.com/watch?v=bg5njtFVszA
Here’s a mod I did this week on a Solarstorm SC02, which is an Olight S20 clone. This is a pretty nice light for $15: nice machining and good overall build quality. But the UI is awful! I know my mods are getting a bit repetitive, but I’ve reached the point where I can’t stand to use any light that can’t do absolutely everything, so I had to put MELD firmware into this one as well. The big difference here is that I build up the hardware from scratch instead of using a PCB, since this one is for rechargeable cells only. So here’s the story of how to pack way too many 7135s into a tiny space:
First I gutted the light and stripped everything except the capacitor off of the driver
Then I glued my PIC16F1825 upside-down on the board
And started tacking wires on. The PIC needs 7 connections to it: power, ground, switch input, and four PWM outputs.
I started stacking up the regulators and wiring them in. This set of four is for the color channels, which get just one regulator each.
And this set of 6 are paralleled to run the white LED. They’re arranged in two sets of 3 to share current between two sets of wires and for mechanical flexibility
Here’s everything wired up, insulated, and the wires bundled to go through the holes in the pill
For the LED board, I build one up from and aluminum XP star and one of my custom PCBs, using the two-layer technique I came up with for my Blackshadow mod. This gives the white LED (an XP-L) plenty of heatsinking but still fits in the colors in a very small space.
Here are the wires feeding through the pill and LED board, with some thermal grease in place.
And here’s the result of the (tedious) wiring process
Finally, I cut up the original LED insulator to fit around all 5 emitters, and put it in place under the reflector. This was necessary to match the original height stackup which puts the necessary pressure on the pill from the front bezel.
And done! This light runs version 2.13 of my MELD firmware. A few improvements have been made since, but this demo video gives an overview of the firmware
Update: here’s an overview video of MELDv2.13 firmware:
And here’s the configuration menu:
Edited by: tterev3 on 07/30/2015 - 10:56
zeremefico
zeremefico's picture
Last seen: 42 min 22 sec ago
Really nice, I follow your projects for some time. I hope one day I purchase a flashlight with that interface.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
wdkingery
wdkingery's picture
Last seen: 1 day 21 hours ago
Jesus Christ. That was a lot going on for a flashlight! I loved the darpa puke light, and most of the modes in the 6-8 minute frame.
You should consider selling a light like that.
tterev3
I do sell microcontrollers programmed with the MELD firmware for those who want to make their own like this, and I also do mod jobs for hire for those who just want the completed light.
light dispels d...
Last seen: 3 years 5 months ago
how did you get the pill and the driver out? are they just pressed in? did you have to pull the switch boot and retaining ring? is the retaining ring a press fit?
tterev3
It was really easy. The whole pill is very lightly pressed in, and the switch boot can stay in place the whole time. After removing the bezel ring, lens, and reflector, you can just push the pill out by putting a battery in the tube and pressing on it. The driver is a loose press fit in the pill and pries out easily.
light dispels d...
thank you for your reply. you did a beautiful job on the light. the intricate wiring is very impressive. I have several SC series lights including a couple that don’t work and plan on doing some mods of my own.
DBSAR
DBSAR's picture
Last seen: 5 days 22 hours ago
if you plan to build more stars like that one with the 5 emitters, i would definitely buy one.
RaceR86
RaceR86's picture
Last seen: 2 years 3 months ago
Epic!
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
DanielM
DanielM's picture
Last seen: 1 day 2 hours ago
That is beyond cool, so many modes, I like it.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
Cereal_killer
Cereal_killer's picture
Last seen: 3 days 9 hours ago
Dude I have the same light apart on my bench right now, guess what I’m doing to it lol.
Edit I’ve always wondered, what’s the white wire you use? It looks solid core.
Edit2: having worked on both original S20’s and these this is the better light in every aspect but glass quality and ano, the inside if the switch is a way better design (that doesn’t rip when taking it apart) and the pill presses in with much more contact.
tterev3 I went ahead and designed a board for mine using a QFN, once I finish it up I’ll send you the files.
Always remember SPC Joey Riley, KIA 11/24/14.
tterev3
Sounds awesome, did you use the transistor arrangement that you used on your other drivers? How will you mount the switch? It would be great if you managed to reuse the stock switch daughter board on yours.
The white wire I use is 30AWG solid-core wire wrap wire. I can’t remember the exact one I bought but it’s similar to this one: http://www.mouser.com/ProductDetail/OK-Industries/R30W-0100/?qs=sGAEpiMZ...
tterev3
The boards themselves are open source, here’s the XP version and the XB version if you’d like to build one yourself, but I’d be happy to make some for you. I keep all the parts on hand to do both the basic and the metal-core two-layer version I used in this light.
DBSAR
DBSAR's picture
Note sent.
Muto
Last seen: 16 min 35 sec ago
Can’t get over all the options.
Fantastic.
PM sent.
Thanks,
Keith
All men are equal when their memory fades
Cereal_killer
Yes for the main white emitter then one 7135 each for the colors. Yes I used the factory daughter board for the switch (it’ll be interesting to see if I did the slot right, I know its in the right location but I’m a little worried about if its actually gonna be cut out, I submitted the design before I read the stuff that just got posted yesterday about how to make sure cut-out’s get done correctly, may have to end up doing some file work once they get here, the render looked right but that thread about wight’s contact plate’s coming out solid concerns me).
I was considering making a new daughter board with one or two 7135’s on the bottom of it but I was concerned about the thicker boards from oshpark not working for some other reason and I also never made a daughter board that uses connections like it does (only via header pins) so for now other components on the bottom lost out even tho I really liked that idea.
One thing I’m really not thrilled about is I couldnt fit a 1206 for the sense resistor, only a pair of 0805 pad’s, what is the next size up from 0805? I plan on standing 3 or 4 0805’s on their sides on the 2 pad’s (not touching) to try to have good enough dissapation to air but I’m thinking current is going to be limited to about 1.5A for white so it doesnt burn up, calculations say anything over that needs minimum 1W ‘s (which is why my 17mm 4ch transistor driver uses a stack of 1206’s per ch to be able to add up to the power level I needed for 2.25A)
are you MCPCB’s DTP or with a mask under the main thermal pad?
edit whats the size of the R030 sens resistor on the stock board?
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 4 days 3 hours ago
Incredible!
tterev3
I just used a standard MCPCB with dielectric layer. The stock current sense resistor is a 1206
blueb8llz
Last seen: 7 hours 26 min ago
never seen anything like this. super!
tterev3
I did a new firmware overview video for v2.13:
saypat
saypat's picture
when I first saw the firmware/UI for this, it was on a Sky Ray King if I remember correctly. I went nuts! I didn’t care, I had to have it. I contacted Everett. He put it all in an Olight S10 for me. Yep, WRGB and UV in a tiny little light. Of course it’s my favorite. Can’t have more fun with a flashlight. Keep the mode/configuration sheet handy! Everett is a great guy and his work quality! Order one from him…..
tterev3
Thanks Pat!
jacktheclipper
jacktheclipper's picture
Last seen: 1 day 43 min ago
As usual , outstanding work , sir .
Thanks for sharing .
DanielM
DanielM's picture
group buy
saypat
saypat's picture
DanielM wrote:
group buy
too funny, this brought a chuckle to me Silly
Cereal_killer
Watching the video again now so I know what I’m doing when I fire up my T4 for the first time.
This is also my first completely-on-my-own circuit and driver design so really excited!
Edit: its alive!!!
tterev3
Sorry to dig up such an old thread, but I recently built up another of these and created a build video of the whole process:
It’s a bit long, but I had to compress down 4 hours of build time! I hope some other modders here will enjoy it
ImA4Wheelr
Last seen: 9 hours 12 min ago
^ Great to see you're still around here tterev3.  I can't really play video here, but look forward to watching it later.
Tom E
Tom E's picture
Last seen: 13 hours 20 min ago
Look'n fwd to it too! Love your firmware and multi-color mods! Would like do maybe take a shot at building one.
Neilyboy
Last seen: 8 months 3 weeks ago
I just have to say this is fantastic. Is there a way to create a pcb and populate it ( possibly two sided) that would save from having to float the components (i trust my reflow oven over my solder skills lol). I would love to create an all in one drop in package. If I didn’t have 4 kids and some free time ( oh the good ol days).
Awesome work man I would love to own one of these, excellent mod buddy.
Neil
tterev3
Yep I do have a complete driver PCB: https://www.youtube.com/watch?v=rPRKWXJtHH8
I don’t tend to use it on 18650 lights like this since it’s geared towards single-cell CR123A lights and floating 7135s gets me a bit more current and a simpler driver. I also made a 7135-only version of the PCB to fit in a very small host one time, so that could work for the SC02 with some slight changes to mount the switch
