I know all that, but don’t believe that a designer adapting a reflector light shape to a zoomy would miss a small change that would improve both the heat flow and the mechanical strength.
Honestly, I don’t think the designer really cares. Its cheap, lights up and doesn’t burn out within the 45 day paypal dispute window, its perfect! Next.
Looking in Alibaba, the first listing I find for an SK-68 says “Supply Ability: 50000 Piece/Pieces per Month”. I don’t suppose the designer expected that much success but I think he must have taken the project seriously, probably more seriously than the one who designed the obscure Nitecore Extreme took that design. He relied on Nitecore for style, but did his own engineering. And he got the most important part right, at least, the production cost.
This is the most informative review I’ve read on flashlights. Congrats and thanks.
Now, I’d love to see a more high end flashlight reviewed in the same way, but that would be too much to ask.
I’d certainly not be willing to pay 100% by myself, but I’d gladly participate in a crowdfunding project. I’d be willing to participate with, lets say 0.05 Bitcoin (roughly $25). If this “review” project is backed by 20 people the funding would total to 1 Bitcoin. I think this would suffice to “review” a $100 flashlight. Anyone else interested to participate?
Perhaps the design flaws of the more expensive lights run more to unnecessary difficulty of production, but I still argue that if you are going to sell a few hundred thousand lights, or even ten thousand at $10 each, it is worth putting a lot of effort into the design. A simple example is the shape of the fins. Tapered fins are more common in cheaper lights and obviously cool better, as well as being easier to make, at least in large numbers. One of the things that makes flashlights interesting to me is that even complicated shapes are cheap to make with numerical control tools, at least as long as they are axially symmetrical. I expect it will be just as easy to spot flaws in expensive lights if we get one cut in half. The lack of an effective patent system must work both ways. One makes less money from a good design, but on the other hand to get a good design a Chinese designer apparently has only to correct the flaws in an existing design and adapt it to his needs, like free software. I wonder if the designers would sell their cut in half flashlights after they are done with them.
This is precisely why I’d love to see a “naked in-depth review”
If there is enough interest I will open another thread, or someone else can, I don’t mind.
I am pretty sure that we can raise funds to motivate a reputable reviewer to “see into it”.
I’ll stick to my promise and contribute 0.05 BTC (Bitcoin), or 5 LTC (Litecoin), if this is acceptable for the reviewer.
On this thread: 15mm SK68 Nanjg 5*7135 V1.0 [final] I describe filling the gap between the pill and the thick battery tube with metal, with minimal tooling and material. It would be nice if someone with more stuff would make some rings of copper or soft aluminum and sell them.
The discussion ended up on that thread, because the ring is incompatible with using a 17 mm. driver, so building a good 15 mm. driver was by far the hardest part of the mod. There seems to be little difference between an SK-58 and an SK-68 around the bottom of the pill. I consider 1.8 A too low current to require cooling fins.
