Luxmeters: thoughts, findings, comparison
Maybe it’d be easier to pass around one meter, everyone takes readings with the same device we’d all be on the same page. In theory.
RaceR, you are right that it is debatable if a 4C tinted light would be the best light to send out, it depends on what you want to check. It is a tint that measured close between the Mobilux and the Tondaj, being less sensitive for errors in the blue region it may be a good tint for calibration comparisons. To reveal wavelength response errors a cooler led could be more useful. I am thinking now of sending two lights, one is the 4C-tint light and another could be 1C or so. But I may be building a new integrating sphere this fall/winter, one that incorporates the Mobilux meter and is a bit bigger so that calibration of the conversion factor is less important with every light measured. Then measure the lumen and throw of the two lights before sending them. The relative differences between the two lights should be correct then.
The XP-L was tested in my integrating sphere, so that was not the Tondaj meter but the Ceto meter. The Ceto corresponds better with the Mobilux in the blue region, so I would expect the effect of a tint-shift on the luxreading smaller than with the Tondaj meter.
The colour filters of the Tondaj and Ceto meter are clearly different, these pictures (that I posted before) show left the Tondaj sensor, right the Ceto. The colours of the filters show quite correct on the photo, the tondaj green/blue-ish, the Ceto very green:
(I am not going to open up the Mobilux sensor!)
Sorry for not reading it right sooner. I skimmed it earlier but had nothing to add of value. Not sure I do now. The inherent issues of measuring lux or even lumens are daunting to say the least.
@ mudgrips: Try changing the battery. My meter underreads when it has anything but a fresh-ish battery.
Yep will do ledsmoke. Bought a new battery for the meter yesterday to try as its the only variable I can really check.
Will test it tonight.
Well … did retest last night on 2 lights with new battery in lux meter - but no difference in readings.
Meter remains accurate over 100kcd but still reads 18-20% low in that 30-80kcd range - have no idea why.
Dam! - meter must be b*ggered!
How will make make sure that your lumen calibration is more precise compared to others?
How will you make as many people as possible join in on using your lights/numbers as reference?
The goal is not to dictate my calibration to other people, I have no calibrated light source either (I call my calibration 'djozzlumens' for a reason), but to get a pretty exact idea what differences there are, so that you can perhaps define a standard 'BLF-lumen' ;-) . I must admit that the incorrect wavelength sensitivities of probably many luxmeters very much complicates the idea of a standard calibration.
I just hoped that people find it a neat idea and want to participate. The costs are no more than sending a small package to the next in line.
BTW, my lumen-numbers are uncertain, but I think that my lux-numbers, coming from this very good once calibrated meter, are indeed more precise than most other lux-numbers around.
Maybe you could talk with say 2-3 meter suppliers as we do with torch manufacturers, ask for some sample product, and test those particular lux meters for best accuracy. Then its a matter or referring blf people to those meters/suppliers. Could be basis for group buy and would also standardise readings for alot of us who use meters.
Would be matter of thoroughly testing 2-3 meters rather than sending ‘calibrated’ torches around alot of people. I’d certainly buy a tested and recommended meter - especially if it has been referenced against good expensive meter equipment. You might end up with two recommended meters in different price categories eg $0-50, and $50-150?
I’ve got to buy a new lux meter and would be keen to buy a make/model that someone has carefully calibration tested. Could help bring alot of blf readings/reviews into line.
Hoping this is an all right place to say this.....
It seems that in order to get a good idea of what a flashlight will do in terms of light output (quantity vs beam pattern) a better way to show this would be to use a 3D graph such as like the following describes:
This kind of graph showing beam spread and the colours representing intensities as from a flashlight shining upwards the highest portion being an arbitrary fixed distance from the emitter
added to this graph showing the beam intensities as on a flat wall for example at a certain distance
resulting in something along the lines of this graph (but other side up and much better and clearer)
These things can be plotted by any amateur physics hobbyist who can do simple trigonometry and calculus. Additionally specifying the light in the area under the cone would result in the quantity of light within the beam at a specified angle and distance.
This is just a thought as the light meters mentioned above are being used to obtain a smaller portion of what is mentioned here. If we can create these kinds of graphs then only the emitter colour temperature measurement will be left to solve.
Any ideas? If there is a better place to post this please advise. This was posted as a thought having read about the light meters above and additional thoughts were solicited.
There's not many rules at BLF, usually you can post things where you like and this thread is quite appropriate I think.
I'm not sure exactly what you mean but it looks an awful lot like the first flashlight test that I ever did a few years ago and that I posted on CPF :
I did use the geometry of the flashlight beam but did not do any computer work, just simple calculations, to measure the lumen-output of a light directly with a luxmeter. I now think it was a bit of luck but the actual output of that light as I later measured was within 10% of that measurement
That post was also a disappointment about CPF, the test was a bit of work, I had not read of anyone else doing it that way on CPF, but it attracted only one reply. It was a kind compliment from HKJ by the way
Because it was a quite easy test, I did a rough test on temperature effects on the reading of the Tondaj and Mobilux luxmeters. Method: I put the sensors (not the body) in the fridge, next to each other together with a thermometer. After 3.5 hours (the thermometer read 12degC) I took them out, attached them to a cupboard and measured the lux of the hotspot of my k10 constant output reference light at an arbritrary distance (1.2 meter or so) clamped in a stand. Then I took the readings of the meters the next 40 minutes with the sensors warming up to -hopefully- room temperature (in this case 24degC).
time after taking sensors out of fridge
Tondaj reading Mobilux reading
0 201 201
30s 201 201
1minute 201 201
2 200 201
3 200 200
5 199 200
7 199 199
10 199 199
15 199 199
20 199 199
25 199 199
30 200 199
35 201 201
40 85 85
Now that was a lot less exciting than I expected. Both meters did not care less about the temperature difference. I can think of two reasons:
1)The reading of both luxmeters do not suffer significant from a 12degC temperature difference. This is good news!
2)Or, the actual sensor of the Tondaj and/or Mobilux luxmeter is so well thermally insulated from the surroundings that they were not enough cooled down in the fridge/warmed up during the measurements to show the errors that would arise from a temperature difference. This scenario is also good news, it means that if you start a measuring session with the luxmeters at -say- room temp, it does not matter much if the temperature fluctuates, the insulated sensors will not notice that.
Conclusion: Warned by the DIN-norm I expected a significant worse temperature performance from the Tondaj compared to the Mobilux, but I do not see it in this test.
(And I never did a runtime test on my -two7135,XM-L2,0D- K10 before, 40 minutes runtime on an Efest 14500 of which 35 minutes flat regulated: you gotta love those 7135 chips for their constant performance )
Thanks for the continued testing djozz.
While the test equipment itself might not show much change due to temperature variation, do the lights perform the same? I know a light that makes a lot of heat at ambient 90 degrees F can’t make enough heat at 40F to warm the hands. So a chilly or cold night might allow the lights to run brighter, longer.
In the end, the hot rod I build here in Texas will behave far differently in Amsterdam. And this would tend to skew results as well, even if we all tossed our meters and jumped on a Group Buy to standardize.
So, RaceR86’s idea of standardization might we unattainable due to the wide degree of variances from multiple source points…emitter, star, driver, host, ambient, cell, meter, paint, lightbox and even individual testing variances from person to person.
Good idea, but it’s not looking good for making it work.
You are right DBCstm. Only possible if the module is connected to a thermocouple and the first tester makes a graph with output at certain temperatures.
What does my idea (more discussed in this thread) have to do with small details you mention. My idea of calibration is only about getting everybody closer based on averages, and eliminating the large differences. Averages based on various peoples calibrations who again are based on countless of lights that have been measured.
The good thing with my idea is that there is no right or wrong when it comes to standardization because its just based on averages, and the goal is not to get perfection, but only to minimize differences. There is no cost involved. Many people does not even have to change a thing about their numbers.
The two main issues with my idea of calibration is that its based on averages on many different lights, so its not easy for people to join in on the calibration without having a couple (the more the better) of lights that is comparable with others. Most people who often does reviews or share numbers will over time be able to overcome this, and adjust their numbers accordingly to others (if they want)
The main problem with my idea is that most people does not seem to know how their numbers compare to others. And even if I try to show (read the part directed towards rdrfronty and you guys) that some on average have higher numbers, there seems to be no interest in doing changes in the calibration in order to become closer to other peoples numbers. So unless people put in a little bit of effort, there will be no improvements, and we will continue to see these large differences.
Another way of getting people closer would be for many to join "djozzlumen/lux", which could become "BLF lumen/lux" over time. I would not expect perfection with that either, but it would be another way to eliminate the larger differences that we have today. But as with my idea, the main problem is to get people to join.
I can say I would not join in on that unless many others do. And if many others did join djozz numbers my calibration would "automatically" adjust closer to it. This is simply because my current calibration (which is something Im always willing to tweak, and still is tweaking) is very close to other peoples calibration. As good as Im capable of making the numbers. Basically my numbers are currently in between the "two camps". (Described better in the thread I linked to.) I have some preferences about where I want my numbers to be when it comes to both lumen and lux compared to others (in order to make my numbers as comparable to others as possible), but that will be tweaked over time. And if certain others change their numbers, that will affect my numbers as well. The fact that I can play with my numbers in between the "two camps" says it all about how large the differences are.
so maybe I can attached some pic about mavolux 5032B sensor, I just tear down my sets.
Thanks leowood, and welcome to BLF :slight_smile: . It is pretty cool to see that the setup is pretty similar in a high-end sensor. Even the little green window looks similar and nothing special, although I bet that it is a way different quality than in the budget meters.
And thanks for reading my (old) article, I still think I did some special hobby-work on luxmeters 10 years ago with the make-shift equipment that I have. At least I never found anything remotely similar on the internet. Nowadays I’m less into this hobby, but I still read what is going on.
all your article is extremely informative for me, thank you! I recently bought 3 sets mavolux 5032B for USD 30.00 each(in order to verify each other :)), I have no prism-monochromator to verify the V/lambda correction,so I just verify the monochrome RGB of OLED screen from samsung galaxy test mode, compare to other budget meters, the green is alway close, red is also close but not good enough, but blue is always way too different. the calibration date of all 3sets mavolux is 2014, but the RGB test data from 3 sets is pretty close, I believe at least the mavolux is very stable and solid meter.
A while ago a djozz thread inspired me to get out the screwdriver.
The sensor in many of these looks to be the same photodiode.
Inside my Dr. Meter
I found this as a sensor.
The sensor is hidden under the expected filter. Looks fairly centered on my meter.
It looks awfully familiar…
To the OSRAM BPW34 PIN photodiode.
This is the sensor made famous in Terry Oregon’s sensor thread for use in measuring PWM:
And my build using it based on Terry’s thread:
I have found the OSRAM diode to be linear until the circuit starts to clip on the high end.
Its fast response time (and low price) makes it a good choice for getting a look at the PWM character or driver artifacts without having to try to get a physical connection to the driver circuit.
djozz - a pass-a-round light of known output is a great idea. It will be interesting to see how the various measuring “spheres / tubes / boxes / contraptions” compare.
All the Best,
Jeff
