Finally got my hands on XP-L recently. It feels like much brighter version of XP-G2 rather than XM-L2. XP-L is definitely the LED that I am going to stock up right now.
The only dislike right is the "XM-L to XP-G reflector converter" (gasket for centering) cost more XM-L model.
XP-L and XM-L2 have the same size die (the semiconductor chip covered with the yellow phosphor, the part the light comes from), throw will be the same. XP-G2 has a much smaller die. The dome makes the apparent die size larger (like a magnifying lens). Remove the dome and the die, as the reflector/optics see it, gets smaller.
pflexpro, can you test T6 3C vs V4 3D, like the 5V vs U2 the V4 should be slightly above T6.
For me as like for many others 3C has that unwanted slight greenish in it V4 3D seems like a great pinkier/neutral alternative to 3C. I've some XP-L V4 3D on the way.
If I told you I'd have to kill you! Well, I don't wanna say who it was because I'm not sure on the timeframe, and there have been delays before on this sort of stuff, but I would rate the source as "highly credible".
Could you share the data for all 4 samples instead of just the emitter averages? It would be interesting to see the spread within the emitters as a backdrop to the spread between them. Especially given all the variances just in the data sheets.
Sure - TangsFire has a U3. It's a Chinese U3 . The only real U3 in a light I'm aware of was the ArmyTek, but they ran out pretty quick. Since there was a real CREE batch of U3's released a while back, all the marketing hyped Chinese sources claimed they had them. I finally had enough of these false claims and proved it by comparing one source's claimed U3 to T6's and found the T6's equal or brighter, and U2's definitely brighter. If they claim U3, like TansgFire, chances it's a T6 at best.
- now this I'm feel'n!! "Trust in Hank" - the only trustyworthy source on that side of the planet. Illumn, IOS, MtnE, Cutter - only ones I know of to trust bins and tints from.
