Thanks comfychair!
I’ve ordered the board but I have the problem with “digikey” (Ship Rate: $120.00 for my country) :~
Can you give me other place where to order the electronic parts?
No idea, but you can use that list to find equivalent parts from somewhere in EU. They don't have to be identical (except the attiny & AOD510), any SOD-323 Schottky diode will work, any 0805 10% X7R 10-25v ceramic cap will work, any 0805 1% resistors will work, etc.
You can also get everything but the FET, switch, indicator LEDs/resistors from a donor Nanjg 105C. The indicator LEDs are completely optional, it works just fine with the standard code whether they're present or not.
I believe, though I haven't tried it, that Helios designed the switch pads to also work with the stock switch from the stock F6 driver, if you want to reuse it instead of buying a new one.
My new BLF dd_PIC drivers UI allows short press for on/short press again for off.
I could easily mod Heloi’s design to accept the needed PIC MCU (and remove the unneeded voltage divider resistors) if you’re interested in that.
You can see a video of the bad ass UI and read about the standard 17dd and 15dd in the thread here. I am out of town this weekend but if he will send me the files I can have a direct fit driver for the F6 ready to order as soon as Monday. If I have to start from scratch it will be a bit longer.
I could also build the driver for you, test and ship it to you for about $25 USD.
Edit: really wish someone would atleast try one of these (and like I said if I could get any takers I’d be happy to make one direct fit for the F6 or anything else), I put a lot of time/work into designing, building and testing these things. Someone please start using them. The FW is much much more advanced that any modded version of STAR (but still extremely simple to operate). It’s disappointing no one’s even ordered a set yet…
I’m not even pushing for someone to buy one from me, this is a dedicated open source project, just please someone install one in something!
@Cereal_killer
I’ve already started to build the Heloi’s version, but your firmware is much better and I will buy one from you. I will contact you on PM because I can’t do it by myself.
@comfychair
Thanks!
I wanted to use the stock switch and the other parts from one Nanjg 105C, but can I use this FET:
http://kelco.rs/katalog/komponente.php?q=IRLR3103
Wow, well... it would probably function, but output would suck. Gate threshold voltage is low enough & total gate charge is OK at the voltages the driver will see, but it's a 16 year old design and the on-resistance is sky high. 0.024 ohms, vs 0.0042 for Vishay 70N02 and 0.0032 for AOD510.
FWIW, I’ve got voltage detection and readout working on my Skyray King, and although I still need to do a lot of measurement to determine exact values, I think the code should also translate pretty well to the custom Roche F6 driver.
I can confirm the Roche X3 uses the exact same driver format. Plus, it uses a standard 42x31 C8 reflector, so... side switch C8!
I built one with these...
...and every time I switch it on, my first thought is "so this is what 1928 was like." :hat:
It's surprisingly nice outdoors ("90+ CRI"). Indoors, eh... not so much. :sick:
Whaoh…nice!
Haha, a 7* tint? That would almost certainly make my eyes hurt. Traditional 100-CRI incandescent bulbs are painful for me because the tint is so warm. I know some people are really fond of that color of light, but not me. If I try to read under incan, it only takes a few minutes before my eyes start rapidly inverting the colors until everything is grey and I can only see contrast lines at the edges of things. Sort of like this:
Yeah it's an outdoor-only tint, at least to me. Indoors it's pretty icky.
The ambient lighting you spend the most time in has an effect on how you perceive it too. I live in a cool white world... ~2900K is a long way off from what my eyes have adapted to and consider 'normal'.
edit: The 7C4 would be really good combined with a 4C & 2B.
When I was little and living with my parents, all the lights were ~2700K incandescents. I basically couldn’t see clearly indoors at night because the tint made my eyes bug out. It wasn’t until I bought myself a fluorescent fixture for my room that I was able to read comfortably at night.
It also occurs to me, just now, that this probably explains a common theme from my dreams at the time. I’d often be trying to see something but the light was too dim and no amount of fiddling with the light switches would fix the situation. Only recently did that change; these days I’m so used to having a light with me that even in dreams I can generally illuminate anything I want.
I’ll agree with the indoor outdoor statement. I trial ran this tint in an s6 for a while and actually became fond of it. Just bought another bare emitter to fit into something else (I’m short on hosts at the moment). The original found it’s way into my s2 triple. 2B, 5A1, 7C4. At times it’s almost a bit cool for my taste. Probably coming in around 4700K. It’s very nice and I rotate it and my 5B1 XML2 S6 as my EDC.
After looking up a couple things in the attiny reference manual and calibrating some voltage values a bit better, I have red+green indicators working in a Roche F6. It’s only a first pass, but this means the “hard” parts are done and now I can play with the interface.
Currently it’s running my SRK code, plus red/green voltage indicators. So, six levels plus “off” with hold-until-desired-level to ramp up and repeated clicking to step down. There’s a semi-hidden battery check mode if you click quickly through all modes and back to off (or ramp up to the first and immediately click to turn it off), which blinks out the following voltage ranges:
- 0 blinks: < 3.0V (red, and the light will auto step-down)
- 1 blink: 3.0-3.4V (red)
- 2 blinks: 3.4-3.7V (yellow)
- 3 blinks: 3.7-4.0V (green)
- 4 blinks: 4.0-4.2V (green)
- 5 blinks: > 4.2V (green)
Oh, and when it’s right at the boundary between two colors, it’ll flicker between them. This is a side effect of the attiny getting slightly different values at each measurement. It seems like a happy side effect though.
I think it works pretty well, but I still have some other interfaces to write for e-switch lights with red/green aux indicators.
If all you wanted was single mode it would be easy enough to use STAR momentary with only 0,255 setup in the modes (off and 100%). That would achieve the stated goal but probably isn’t what priest77 meant.
Apparently STAR Momentary 1.4 adds a mode that might do what priest77 is asking for, I don’t have a documentation link but I guess it’s probably discussed somewhere in the 100-post range of 424 through 524 in the STAR Firmware by JonnyC - Source Code and Explanation thread. Here is the direct link to the actual source code for 1.4.
I think a more permanent solution should be easy to implement. That might actually be something I’d like to use. I’ll have to think about it a little bit. Something like:
- Short press for on/off
- Long press from “on” to advance modes - with offtime memory ideally.
- Long press from “off” - special function. Compile time option for: 1. direct high 2. direct low 3. unlock disco modes 4. no action
Like mokkadrv? I could implement memory instead of high for a single tap when off. It's not open source though.
Nice.
Still early days... since it has the indicators on at all times, and since this thing pulls 10 or whatever amps on high, it's displaying the voltage under load which may not be all that relevant. Should the indicators only be active in the lowest mode, for a more accurate idea of battery resting voltage?
Right now the color changes happen at 3.7v & 3.4v, I'm unsure where to go from here. If those points are lowered to make it more accurate when using the higher modes, it could fool you when using the lower modes. You could have a green light that changes instantly to red just by moving up a few levels. It will also be affected by the type of cell used, one with more sag under load would give a lower reading even though it still has perfectly fine open circuit voltage. Ideas/suggestions?
Oh, and the STAR low voltage protection stuff is still in there, the indicators are for information only and aren't needed to prevent damage.
edit: And here's both LEDs on at the same time... was supposed to be yellow, but orange works too.
I got a chance to calibrate the voltages better today, and adjust the thresholds down for more even spacing. Now the levels are 3.0V, 3.3V, 3.6V, 3.9V, and 4.2V. And 3.3V, 3.9V, and 4.2V match up with my DMM in real time, so they’re pretty close (at least, on my hardware). The other two aren’t directly tested yet, just approximated based on the other values.
comfychair, I think the reason it looks orange is because the red LED shows through the window a lot more easily than the green LED. It’s just due to placement. A clear, angled plastic extension on the window should make the colors more balanced.
As for showing the real-time voltage sag under load, I’m not convinced it’s a bad thing. It matches what my DMM shows, and makes it obvious that the cell capacity actually changes based on load. I’ve watched a weak cell drop from 3.9V to 3.3V in a matter of seconds while it’s running at maximum on direct drive, and then when the load is gone it quickly goes back up near the original voltage.
