OK thanks to all.
I prefer things that are easy to get.
¿can I use lithium grease? like the one used to lube garage doors, car chasis, suspension, etc...???
(in a small quantity, of course)
OK thanks to all.
Ordinarly lithium grease will be fine.
A small can of lithium grease should last almost forever. Just don't get the stuff with molybdenum disulphide in it - it is black and nasty to clean up.
I use sawing machine/precision machine oil (very cheap and works fine) and technical vaseline (still cheap) from electronic parts shop. Vaseline is better, because it's thicker and stays on threads and gives better slip.
I use Vaseline for the same reason as rzezniq.
Clear silicone grease for O-rings is often used for scuba diving maintenance and can be bought over Ebay.
For example HERE .
I have this stuff called "Super Lube" (http://www.super-lube.com) that I got at a hardware store in the US. It says it is a "synthetic grease" and contains PTFE (teflon). It is in a squeeze tube and looks similar to vaseline.
interesting...............
I use vaseline, tried silicone grease but found this too thick, was not that smooth.
It will be fine but is awfully expensive for 5g of generic clear silicone grease.
And any site to get it cheap????
I can probably get 50g of the stuff for the same money - I'd be happy to post it to you. I will get back to you with prices.
Personally I'd just use lithium grease which should cost a lot less and is available at every car place.
I have that lithium grease. I will test in an old flashlight and see the results!
However I will continue waiting a good price on clear silicone grease
Thanks Don
I have an account with them and am about to order some networking gear. I will need some grease for the job so the customer will be paying for it. I have about half a tube that I am happy to send to you for the cost of the postage since I'm getting the replacement basically for nothing. There is about 25g in the tube which ought to be enough for about ten years. Just PM me your address and I will post it tomorrow. Since I am also in the EU the postage won't be more than 3 euros I'd guess.
Hi Don, thanks.
For the moment I inform that I have tested my lithium grease (yellow colored one) and it works!!! Is not like the liquid substance used in the A3 eos but does the job.
I tested a an old flashlight, and screwed and unscrewed it about 50 times and goes very well. I dont know how will react the silicone or rubber orings.
I will take your offer if the lithium grease destroys the orings. But for the moment, appears good
The cleanest stuff I've found for metals is mineral oil. I use it for tools/blades/etc. It's also everywhere and practically free. AKA Baby oil (which has a tiny bit of fragrance added). Food safe just in case you like to lick your lights. LOL.
I think that's also what's in the little bottle of oil which is included with my Philips shaver. The tiny bottle, which is great as an applicator has lasted forever on flashlights.
I've also tried fairly pure silicone oil. That stuff works well on plastics, but I find can stick slightly with metals. No idea why.
Well I went to research this a bit. It turns out mineral oil is petroleum based, similar to the vaseline/jelly Don describes above. I think the oil is preferable since it penetrates better (get all the gunk out of those light the first time you use it), and ends up looking very clean. I'm not sure why Don says they'll attack natural rubber; wouldn't they attack any petroleum rubber rings since they're essential a petroleum solvent in order to be liquid? Sorry I'm not knowledgble in chemistry.
WD-40 FTW!
Don't you agree Don?
Most petroleum based substances in liquid form will harden and eventually destroy natural rubber. The higher the temperature, the faster this will happen.
Since natural rubber is expensive it hasn't been used to make O rings in years. The stuff used for O rings these days is invariably synthetic and is much less likely to be attacked by lubricants - it is normally a butadiene-styrene copolymer or some sort of carefully controlled molecular weight silicone polymer. This will not be damaged by any lubricant that I know of.
If a light needs cleaning of factory lubricant and general mess, WD40 works well to dissolve and shift it. However, WD40 is not really a lubricant so it needs to be wiped off. I prefer to use heavier lubricants as they don't end up on my clothes as oils tend to. Others may have better technique than I do...
I was kidding about the WD-40 (just making fun of your sig).
I use hobby R/C lubricant for my lights and it works great. The stuff is lightweight though so I have to wipe most of it off.
