Current goes up even for the 3 cell? That's interesting. Should mean it's able to fully drain a set of alkalines while maintaining maximum possible output all the way to the end.
I wonder if the 2 cell & 3 cell drivers are actually the same? Can you try 2 cells in the 3 cell light, and 3 in the 2 cell light?
As for why you don't understand how it works, I think that's normal as long as you try to work it out without converting your tailcap (input) numbers into watts. Do that and it makes it easy to make a meaningful comparison between two lights, no matter what they're powered by. Volts x amps = watts. 4 volts at 3 amps is exactly the same as 3 volts at 4 amps, even though the number/type of cells used to get there could be totally unrelated. By converting to watts it clears away a bunch of stuff that just adds confusion.
Oh snap! Maglite stepping up to the plate…BIG TIME!
Running XM-L/L2 correct? (Can’t watch the video’s yet)
Wonder if a descent buck driver could be build in the space of the “stock” driver but with modes like that…not on the ATtiny13 or even 25, maybe the 85 or on the PIC
Wicked cool OL…thanks!
I would think some conformal coating (nail polish or clear spraypaint) overt the components (not on the contact pads for the switch) would definitely help “weather proof” it even though maglites are pretty darn waterproof to begin with
I just got the 3 cell apart. The driver is totally different. I will take photos when I can, but it’s the same size, with totally different components and circuits.
Thanks OL for the teardown. I’m disappointed with the heatsink design: Knurling on both heatsink and tube, :Sp I’m pretty sure no knurling would have been cheaper.
The knurling may allow for slightly larger tolerances in the base tube keeping things to a reasonable cost but at the same time doing enough to get rid of whatever heat is generated.
Yeah, Im sure that added at least $15-20 to the total cost for the millisecond long CNC operation.
Thanks for the great tear-down on both lights OL. Lets hope these appear in the Lowes mega-discount annual maglite sale. Im sure Costco will probably be another contender around Christmas. Its great to finally see mag step up and deliver a decent stock light.
I’m curios, can you check if the heatsink is ferrous or non-ferrous?
The forum is so lucky to have members of this caliber, they get a brand new flashlight and the first thing they is rip it apart, and take the time to make a video, so everybody here can see what makes it tick.
I just took off the R050 resistor on the board and didn't have what I wanted, but I put back two R056 together. It now pulls 3.4 amps with two Alkalines! I am in the process of making two of the 3xAA holders into a 6xAA 2S/3P and I will see how that goes. The 2D is now very bright!
I also added some mass to the heat sink. If you look at the pill that holds the led, you see there's sort of a cup there. I filled that with copper shot and solder. It adds some mass at least. About quadrupled the weight and it should help with heat for a little while.
Might not be any real visual difference, but here's a couple of mouse overs. Mouse OUT is the Stock 2D. Mouse OVER is the mod.
