My Bike Lights - Info, Teardown pics, Beamshots, Current Measurements, etc. . .
97 posts / 0 new
garrybunk
garrybunk's picture
Last seen: 8 hours 50 min ago
I've been accumulating a lot of bike lights lately and thought it would be a good idea to create a thread where I share my findings.  I probably won't do full reviews, but will provide teardown pics, beamshots (w/comparisons to other lights), list battery pack current draws, etc. . .  Feel free to chime in.  I will just post about a new light at whatever post# this thread is currently at.  If I remember, I will try to add an index here in the O.P. to a post on a new light (please do not delete your posts and screw up this index!).  I should have started this awhile ago, as I now have quite a few lights to try and catch up on posting about (and gather info scattered around other BLF posts & PMs with users).  I'm hoping this thread could be a resource to link others to who might be looking at bike lights.
EDIT - Links don't work & need fixed.  Please just jump to the post#, BUT beware that you need to add "1" to the post number.  One day I will take the time to fix this!
EDIT#2 - Slowly updating all photo locations to Flickr.  In the meantime, here is a link to all my Flickr albums
NOTE 4/10/2018: Updating all photo locations is too tedious a task, taking too long, and for many photos I just don't care anymore.  So my plan of action is to include a Flickr album link at the top of the post (hopefully pics in that thread are all contained in the album - though you won't have the photo captions anymore).  I also expect to update photo links on my newer more important lights / posts (closer to the end of the thread).  Sorry for any inconvenience.
Index:
Post#2 - Magicshine MJ-872 Clone
Post#8 - Magicshine 808E Clone - 4 mode (L-M-H, Press-N-Hold for Strobe)
Post#13 - SecurityIng HD-016 (aka UniqueFire HD-016) from Amazon
Post#15 - Kaidomain's Gemini Duo / Yinding Clone
Post#23 - 3x XM-L2 from GearBest for Review
Post#25 - NiteFighter BT40S 4x XP-G2 (Updated MJ-872 Clone)
Post#31 - Link to my Convoy M1 Helmet Mounted Builds
Post#32 - Link to My Custom Modded HD-016 Build Thread by ImA4Wheelr
Post#39 - NiteFighter BT21 2x XM-L2 (beamshots in post#45)
Post#46 - NiteFighter BT40S Modded to Nichia 219C's - Beamshots
Post#57 - NiteFighter BT40S Driver Modded to 4A (w/Nichia 219C's) - Beamshots
Post#62 - Custom Built 2S3P Battery Pack (From Xiaomi 10,000mAh Power Banks)
Post#72 - Yinding (Gemini Duo Clone) Modded to XP-L Hi Emitters & LEDDNA 10º Optics
Post#82 - Fenix 2-cell Battery Case Upper Spring Replacement with Buttons
Post#88 - 12v Parking Lot Flood Light (For Unloading/Loading Bikes & Gear)
Post#92 - Thorfire BL01 Light Review Link
Post#95 - Ultrafire F88 +/- $9 Lighthead
 -Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
Edited by: garrybunk on 04/10/2018 - 08:24
garrybunk
garrybunk's picture
Magichine MJ-872 Clone:
I bought this light looking for a light well-liked by MTBR users which provided a good wide floody beam with good runtime.  My SolarStorm X3 (to be posted about in the future) is a great floody light, but does pull quite a bit of current off the battery, so I was looking for something more efficient.  This 872 Clone was bought from Ebay seller sentinel_cases here. I haven't spotted this light (clone) for sale anywhere else.  There is a Russian review on a similar clone (likely same light as mine) here (be sure to click on "reading->" to see the full review).  A review of the original Magicshine MJ-872 can be found here
First impressions:
-Small
-Nice controls: dual switches, up for "increase" and down for "decrease".  Press-n-hold to turn off, no blinkies at all (could be a negative for some).
-Modes are either spaced too closely, or they could have eliminated one
-Body does heat up which indicates decent thermal properties
-Cool white tint, however it is a really nice "pure white" tint.
-Beam is a wide throwing beam with wide spill (very nice!)
-Light behind switch to indicate battery level (though it is a bit bright)
-Switch button is "squishy" and you really have to press inward to make contact (as if there is too much room between the switch cover and the switches themselves.
-Seems to go to the next mode when you turn it back on (unless you were last in "high" and you turn it on via the "up" button, or last in "low" and you turn it on via the "down" button).
Current draw off battery pack:
(batteries @ 4.06v each)
Off: 0.008A
Low:   0.321A (22%)
Med1: 0.662A (45%)
Med2: 1.280A (86%)
High:  1.482A (100%)
Modes were advertised as "100%~75%~50%~25%".
Seems like the light is putting out an awful lot of light at such low current draw! It also doesn’t make sense to me. If I try to roughly figure out (calculate) current to the emitters, I come up with 740mA per emitter (since battery current is at 8.2V, I double the current I measured ,1.482 × 2=2.964A, and then take that number divided by the number of LEDs, 2.964/4 = 0.741A). Of course that assumes 100% efficiency. Doesn’t make sense to me. If it is true, how awesome would this light be to crank it up a bit!
Here are beamshots:
Distance to the tree is approx. 185 feet.  Approx. 275 feet to the house off to the left of the tree.
High:
Med2:
2
Med1:
3
Low:
1
and in the woods (the closest I can get to simulating a mountain biking trail near my house):
High:
Med2:
2
Med1:
2
Low:
2
My camera was on the same manual settings that I’ve been using lately, but the light doesn’t look as “pure white” as it does in real life. I'm also finding that the pics are consistently looking slightly dimmer than in real life.  For instance, the trees I am aiming at in the first pic above are clearly lit up in reality.
UPDATE 2018: Mouseovers will disappear when my PhotoBucket Account Use is lost.
Few mouseover comparisons to my SolarStorm X3 modded with XM-L2 T5 5B1's:
Mouse out= 872 Clone High, Mouse in SSX3 High:
1
Again, Mouse out= 872 Clone High, Mouse in SSX3 High:
1
That SolarStorm by the way is pulling 2.48A off the battery pack in "high".
I've not torn this light apart yet, but will.  I'm contemplating swapping the LEDs to a NW tint.
-Garry
MRsDNF
MRsDNF's picture
Last seen: 3 hours 15 min ago
Good idea Gary. I have a mate looking for a bike light and this will be really helpful. I'm always wary of what you actually get in a battery pack where you cant see the batteries.
NightSpy
NightSpy's picture
Last seen: 2 years 10 months ago
With the current emitters, there is little difference in multiple lights when calculating total output based on wattage. Since you are pulling nearly 12 watts, that is a significant lumen generating energy draw. Add that to some very focused TIR lenses, you get some pretty good LUX numbers to boot. Yes, there is driver efficiency and the 15% upgrades in the newer Cree offerings, but it is still nearly 10 watts worth of light.
garrybunk
garrybunk's picture
So is my rough calculation of 750mA on each XP-G correct?
-Garry
NightSpy
NightSpy's picture
I’d say so. As long as you trust your readings.
ImA4Wheelr
Last seen: 1 week 4 days ago
This is going to be a cool thread.
garrybunk
garrybunk's picture
NightSpy wrote:
I'd say so. As long as you trust your readings.
Why yes I do
-Garry
garrybunk
garrybunk's picture
Not sure how long this "deal" will last, but I just picked up a very cheap MS 808E clone, head only, for $8.50 ($7.23 + $1.27 ePacket trackable shipping) on Ebay.  The seller shipped it out immediately and I received it in 12 days (though perhaps the moon & stars just happened to align perfectly to allow this to happen).  I received the light on Monday and can indeed confirm it has the 4 mode driver (H-M-L->off, with press-n-hold for hidden strobe).  I think bike lights with this "4 mode driver" are much nicer than the 3 mode High-Low-Strobe.  Note that this is the first head only light that I didn't receive mounting bands with.  It is in fact an XM-L as shown/advertised, but I expected to swap out the LED for a nicer tint anyway.  I will say that after a quick play with the light I do see that the tint is a very nice "pure white" without hint of blue, purple or green.
Link:Red CREE XM L T6 LED 1200 Lumens 4 Modes Bicycle Bike Light Headlight Headlamp | eBay
1
I'm not saying this is a fantastic light, but it's cheap enough to grab it to try one out (esp. with Action LED's wide angle lens and a Pannova battery case) or just to have an extra light.
Current pulled from the battery pack (@ 7.98v):
Off: 0.015A (A little high compared to my other lights)
Hi: 0.833A (100%)
Med: 0.263A (32%)
Low: 0.099A (12%)
Not driven very hard, though that provides great runtimes.  I'm sure it could be resistor modded.
No other details or photos at this time, but it's a typical MS 808E clone light with a fairly tight hotspot and wide dim spill.
-Garry
NightSpy
NightSpy's picture
I have a pair of these lights. The whole kit is out for under $20 delivered in several places. I think the metal is optimized for the larger SSC-P7 emitter since the XM-L fits a little loose. Overall, for the money it is a great light. Excellent runtime even with the cheap supplied cells. And yes, the standby current is not welcome. Also not completely waterproof but good enough for a downpour. It has a “weep hole” where the cable comes out so driven water can enter, but in general use, not enough to do damage. I’ve run one for over two years and it is hard mounted to the frame of the bike. No issues.
garrybunk
garrybunk's picture
Readers may find my new "Diffusion Techniques Testing" thread useful in application to their bike lights.
-Garry
L4M4
L4M4's picture
Last seen: 3 weeks 1 day ago
What about the cooling in those cheap lights?
Is the LED good thermally integrated?
garrybunk
garrybunk's picture
Generally these lights have decent pills (for their current level) but the pills simply lay in the head (hardly worth calling press-fit, but maybe some are better than others). During the recent testing with my 3mode one the body was getting quite warm indicating decent thermal transfer which impressed me.
-Garry
garrybunk
garrybunk's picture
UPDATE: New Flickr Photo Gallery Link: https://www.flickr.com/photos/garrybunk/albums/72157692347399235
As posted in ledoman's review thread, I bought a SecurtyIng HD-016 version of the UniqueFire HD-016 "dual beam" light from Amazon.
I haven't torn it apart yet, but I've taken current readings and got some beamshots.
Current pulled from 2-cell battery pack at 8.24v:
Off: 0.020A
Flood: 0.663A
Throw: 0.665A
Flood & Throw: 1.410A (Steady, not dropping)
(BTW - I am confident current readings I make are accurate.)
Flood is VERY wide! However the "flood" mode doesn't throw out far at all. I can't imagine "flood" alone being enough to ride with (except commuting where it is used more for "be seen" use. I think I would prefer the reflector be just a tad deeper in order to get a little more throw out of it.
Here are some beamshots. Pics taken with my same manual camera settings at roughly the same location so that my beamshots can be compared one to another. In the first set of pics, the distance to the trees I aimed between is approx. 185 feet (garage is beyond the trees at an undetermined distance - I really need to determine that). Approx. 275 feet to the house off to the left of the trees. (Note: you can barely see the trees or garage in the "throw" pic.)
Flood:
1
Throw:
1
Flood & Throw:
1
Now to my wooded trail spot:
Flood:
1
Throw:
1
Flood & Throw:
1
That wooded shot above really sells this light!
Next is a full teardown and mod to XM-L2 T5 5B1's and a resistor modded SSX2 driver to run Flood & Throw LEDs at all times in a High-Med-Low (or Low-Med-High) arrangement.
-Garry
garrybunk
garrybunk's picture
UPDATE: New Flickr Album Link: https://www.flickr.com/photos/garrybunk/albums/72157664781725888
I took a chance on Kaidomain's Gemini Duo/YingDing clone.  My driver runs on 4.2v input (as stated in KD specs). I tried 8.4v input and the battery level indicator just flashes red-green-red-green, etc. . . . light won't turn on or do anything else at all. Current draw on 4.2v battery (with thick leads, which made a big difference in output) was:
Off: 0.013A
Low: 0.51A - 28%
Med: 1.23A - 68%
High: 1.795A - 100% (so about 0.9A +/- per LED)
Someone posted this mode change behaviour previously on MTBR, but I can't remember where and which light. When you change modes the light actually dims very slightly and then "ramps" up in brightness quickly until the next mode level is reached. Off happens instant though. Modes are: Off-Low-Med-High-Off. Press-n-hold for strobe.  My driver is NOT the "10 step programmable" one which has appeared in some of these.
TIR lenses from LED-DNA are interchangeable once removed from their white holder
Pics:
1
1
1
q
Beamshots:
Low:
Medium:
1
High:
1
So even though I felt it was under-driven, the beam on high doesn't look so bad. I think I will still resistor mod it for a little more output and address the lack of heatsinking. I'm intending this light to be a helmet light, so I'm keeping it more of a thrower with a floody light on the bars.
Mouseover with my standard 808E clone:
Mouse Out = KD light, Mouse Over = 808E Clone:
1
Mouseover with my stock HD-016:
Mouse Out = KD light, Mouse Over = HD-016 (flood & throw both on):
1
Some comparison photos with the HD-016:
1
1
1
This light is TINY!
Discussion on resistor modding this driver posted in this thread.
-Garry
siata94
siata94's picture
Last seen: 4 days 17 hours ago
Thanks Garry, it does look tiny compared to the HD. Not trying to create more work for you
but if you have wider optics for the KD, it’d be interesting how it compares w/ the HD.
garrybunk
garrybunk's picture
I do have these Carclo 20mm wide angle lenses now I could try.  I also have these 20mm "pinstripe" lenses from KD.  Then I have the various 10°, 25°, 45°, and 60° lenses from LEDDNA which I tested previously individually (see my signature).  One thing I meant to do and forgot was to take a beamshot while covering up one of this lights optics so I could compare it to my LEDDNA optic beamshots and try to determine which angle lens it is stock.  I'm guessing it's a 10° lens?
I'll see if I can get the time to try it out.  It's getting cold around here now and it's even starting to snow as I type.
-Garry
siata94
siata94's picture
You’re setting yourself up for more grunt work :-).
PHeller
Last seen: 2 weeks 4 days ago
Interested to hear your thoughts on the 3x XML2 light
garrybunk
garrybunk's picture
Which one?  You mean these? (Though they're usually XM-L.)  Or do you mean the top secret one I have coming for review?  (Shhh . . . don't tell anyone Smile ).
-Garry
PHeller
The one I posted about on MTBR with the purple trim ring. High>Low>Strobe, mine says 2400lm, yours is listed at 3600lm. We both know they will be about 1000lm tops.
You said you bought yours from Gearbest, I’d get mine from Amazon.
garrybunk
garrybunk's picture
Ah, yes that one.  It's on the slow boat right now (tracking isn't showing anything).  I'm kicking myself now that I didn't ask to review the one Cat recommended trying in that thread.  Actually, that light might not have been on Gearbest's site when I chose a light to review.
-Garry
garrybunk
garrybunk's picture
UPDATE: New Flickr Album Link: https://www.flickr.com/photos/garrybunk/albums/72157662737583937
Just received my GearBest 3x XM-L2 bike light for review light yesterday.  I hurried up and grabbed some beamshots last night while the weather is still decent and there's no snow on the ground.  This thing is a seriously bright flooder!  Check these out:
1
1
What really impresses me is that this light only pulls 0.92A from an 8.26v battery pack on high.  It also runs on a 4.2v pack (same two cells in my 2P1S battery carrier) and pulls 2.02A from that.  So that's roughly 0.67A per LED.  That calculates out to roughly 5.5+ hours of runtime on high on an 8.4v 5,200mAh 2S2P pack (your average 2600mAh cells)!   After reviewing in stock form I'd like to see if I can mod the driver for higher output.  I haven't torn it apart to look at heatsinking or the driver yet.  Stay tuned for a full review.
-Garry
garrybunk
garrybunk's picture
Update on the KD Duo/Yinding Clone.  Good news! KD responded to my inquiry about buying the driver used in sku#S023788 (the "10-step user programmable" one reviewed by ledoman). They will sell the driver for that light for $8. They also reminded me that for my 4.2v version light the LEDs would need rewired to series (I appreciated hearing this from them as it showed me they had some knowledge on what they were telling me about driver replacement). If interested, you would just have to contact them and say you wish to purchase the driver used in bike light sku#S023788.
-Garry
garrybunk
garrybunk's picture
UPDATE: New Flickr Album Here: https://www.flickr.com/photos/garrybunk/albums/72157691589882004
So I received my NiteFighter BT40s yesterday (unexpected fast shipping) and I'm quite impressed. It's definitely a step up from the $15 (+ shipping) Ebay MJ-872 clone.  Bought it on sale for $23.XX.
First off, the lights are identical in size; I thought the NiteFighter would be a tad longer, but it's not. They are pretty much identical in construction, except that the silicon button (one "button" works the up & down switches) is much better on the NiteFighter. Like Andy has mentioned previously, the nubs on the inside of the silicone button are in the opposite direction of the switches, but it works fine. The rear of the light unscrews and reveals the driver (which I have not pulled out all the way yet). There is a nice o-ring at these threads. The front bezel unscrews easily (tip - use snap ring pliers to remove these easily), however there is no o-ring here. The bezel does screw tightly up against the optic though which will keep it mostly water resistant.
The optic was a little tough to pry out, but after working around and around I finally got it to pop up. It's not secured by anything other than the pedestals resting in holes, the openings pressed over the LED domes, and the bezel screwed against it. The emitters are mounted on a single pcb which is mounted against a solid backing which is part of the light body!!! Woohoo! (Note - I checked the $15 clone and it is identical too.) There was even a good amount of thermal compound in place evenly spread out! (Note - the $15 clone had way too much of a very runny compound in place.)
My light tested at the following current draws on 2 fully charged unprotected cells in a Pannova case:
Low-0.43A (20%)
Med-0.95A (44%)
High-1.43A (67%)
Turbo-2.14A (100%)
EDIT - I believe the original "2.14A' measurement was a fluke (perhaps higher current draw due to lower input voltage?)  Turbo should be 1.75A for 0.875A per emitter before losses.
These currents are higher than I tested on the $15 clone (which reached 1.48A on high. The 2.14A on high roughly translates to 1.07A per LED. An XP-G2 on aluminum star @ 1.0A puts outs roughly 350 lumens (not accounting for losses), so we're talking roughly 1,400 lumens. I do believe this light could be pumped up quite a bit more. (Note: I was experiencing quite a bit of voltage sag even when I tried 4 cells, and I wonder if that is due to the battery pack / lights cabling. It's possible that the light would pull more current with better cabling, high-drain cells, or from a power supply.)
There is driver hum in all modes except high. (The $15 clone also has hum but I could only hear it when held up to my ear.) I don't believe this hum would bother me in actual use. I'm not susceptible to PWM, so I can't comment on noticing any. There is a slight fast fade up and down from one mode to the next.
I compared the tint to a XM-L2 T6 3C and an XM-L T6 4C and I'd say the NiteFighter is between the two, but very close to the 4C, a nice creamy white, definitely not orangish.
My PhotoBucket gallery is here, but here are a few pics posted:
Driver (same Andy?):
a
Bezel removed revealing star mounted with thermal compound:
v
Solid backing! Direct thermal transfer to the body!
v
For comparison, my older $15 clone:
Two side by side (NiteFighter on the right):
v
Again, NiteFighter on the right;
v
NiteFighter on the LEFT this time:
v
Sorry, no beamshots yet. On my basement wall it defintely looks like a wide swath of light as expected (same as my $15 clone, but a bit brighter).
UPDATE 10/2015
new close-up driver pics:
q
other side:
2
-Garry
raccoon city
raccoon city's picture
Last seen: 52 min 29 sec ago
This has been bothering me for a long time.
I have trouble seeing Garry's photos.
Here is an example of what I usually see:
          garrybunk_pics
If I quote Garry and maybe refresh my web browser (Google Chrome), I can usually see the images.
I've noticed that deleting "~original" at the end of the "direct link" that Photobucket gives you might solve the problem for posts 13 and later in this thread.
Is anyone else having trouble seeing Garry's photos (in posts 13 and later)?
Mike C
Mike C's picture
Last seen: 10 min 15 sec ago
raccoon city wrote:
Is anyone else having trouble seeing Garry’s photos (in posts 13 and later)?
I used to use Opera (which runs on Chrome engine) and got so fed up with this very problem that I switched to Firefox. I just did a test with my old Opera installation and could see the same problem. It took a while to get all my bookmarks and add-ons running on Firefox, but today I’m a happier man. Good riddance piece of sh*t browser!
MountainKing
Last seen: 2 months 3 days ago
This is a great thread Garry. I have to say though that after using CW on bikes so the past 2-3 years and finally getting a NW headlamp, I simply cannot be sold on a CW bike light anymore Smile NW FTW!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
garrybunk
garrybunk's picture
          garrybunk_pics
Sorry, I was not aware of this issue.  I use FireFox on a PC and Chrome on my Android phone (tried Firefox, but it was too buggy and frustrating).
-Garry
raccoon city
No problem.
I'm sure it's all Photobucket's doing.   Smile
Mike C
Mike C's picture
raccoon city wrote:
No problem.
I’m sure it’s all Photobucket’s doing.   Smile
I had issues with a few other sites. I couldn’t even see my own photos from TinyPic sometimes, very annoying.
