USB Charge Booster - Passthru DCP Enumerator [Final]
Boards are at fab…ordering the components
Sorry if this is obvious to learned souls like Warhawk, but there is nothing to flash right? Just solder paste and heat. I think this would make a nifty little gift or “stocking stuffer” for folks this Christmas season and I intend to make a bunch. Just going to wait to see how Warhawk fares with his tests after building.
What does this device do?
It ensures your device charges at full speed.
A device will not charge at full speed unless it sees the coding it wants on the usb pins. Problem is, there is no standard. Android wants one code, Apple wants apple code and a few others want different codes.
This chip will adapt and always present the code needed for max charging speed. It switches among 6 different coding schemes.
And as a side effect it will prevent juice jacking. A USB charging port stealing your devices’s data and/or injecting malicious code.
Took me 6 tries to get simple board made, not that learned, but what halo said, automatic ranging of charge scheme, also have tested the chips on my dual port DCP enumerator I made, that one unlike this one needs external power source, this one uses power available and provided by USB port it’s plugged into
Forgive my noobness…but how does this connect to an item you want to charge? Is it a board you install internally, or does it have some sort of USB in/out and connect via charging port, between charger and item to be charged?
Yes, USB male in on left (in), USB Female on right (out), looks like this
But automatic due to chip, not static based upon resistors
Just plug and play!
Standard usb female port at one end, standard usb male plug at the other end.
AKA it just works. Whatever you plug in. Max charge speed + juice jack protection.
That $10 usb condom does not do full speed charging. It prevents juice jacking but they don’t mention it does slow charging only. No intelligent chip.
Yup yup
:bigsmile:
Thanks for the quick response.
Can this be ordered as a complete item, build kit, or…just a board, and we buy the parts separately from digikey/mouser/ebay? Will a housing/cover be part of the get-up, or is the board just left exposed?
I am amazed at the talent an ingenuity of BLF members. Nicely done, WH!
So far just board, I put BOM on OSHPark page and here for DIYers, but I am sure RMM might pick em up and sell em, I did it creative commons license no commercial, but put BLF on it because it’s “ours”
No cover as of yet. Need to get one for meaurements then try to figure out printable case
Very interesting, i may want a few of these, especially if RMM starts selling them
Clear 18650 shrink wrap from FT works great.
Oh yeah, al my TP4056 charger modules get that treatment now :slight_smile:
WarHawk, you might want to think about selling a couple!
What about a JB Weld case, of course it would not show the pretty parts so it wouldn’t be perfect…
So do you have to flash the pertinent data to that mcu? I’m not sure I’m understanding how it’s “Automatic” unless the various codes are put in there.
Like the idea, slow on figuring out just how it works. lol
Get Richard to sell em and I’ll just pick up a few, don’t have to know how to build it just have to know how to plug it in… :bigsmile:
Go look at data sheet, it’s a resistance/volts signature on the data pins, there is nothing to flash, the IC does it all
Rather than being programmable such as attiny13 or other mcu, chips like this USB charging controller are hardwired at manufacture.
Warhark, remember data sheets are klingon if one doesn’t normally deal with them. :davie:
Ah, sorry my nerd was showing again: p
They are klingon to me too when they get to The maths… my brain catches on fire
