w0w!
Well done , sir .
Congratulations .
Nice work on the output and creating a white laser light!
I didn’t see you using any light recycling. Your numbers could be quite a bit higher if you are not.
probably will do it or will upload a newer one but have to find time one of this days. thank you.
thank you, i just love throwers you know :bigsmile:
thank you, i will try to do it.
I like how you were putting it in peoples windows too Try some of this stuff- it’s what I used to use in cooling cpu/gpu components and it lasts forever. Doesn’t work on aluminum I found- which is basically all the pills out there xd But copper it really can’t be beat. Doesn’t degrade either over time.
http://www.coollaboratory.com/en/products/liquid-pro/
Not sure about thier other products but I can say with confidence that stuff is the real deal when it comes to tim. I like the beam is perfect You just did a mustache ride on all of vinhs lights
hahahah I am short of places to test the light for the moment, so for now I am forced to bother my neighbors
its interesting your suggestion about that specific tim, and I have searched a lot on this subject forced by my goal on the latest project and I have already bought PK1 to test. only Prolimatech seems to attract my interest, we will see.
I have used cool master tim with good result in my project, several bad no name tims that give worse results than without anything…. if i like what i see will upgrade definitely to what you suggest. but this subject its a little bit complex, a lot of factors to take in consideration…
about vinhs I have to say that from what I know vinh upgrade factory lights which is different from my project that is entirely projected and made from scratch. the time invested here is incomparable too, i have 6 months that work for this single light :weary: but thank you for your suggestion and good words
w0w!
thank you
Well done , sir .
Congratulations .
thank you
thank you very much DBS
well that is an interesting argument. and of course i have taken in consideration recycling tech, but i chose not to use it for several reasons. first of all its inappropriately expensive in my opinion, its complicated and difficult to implement in the right way, and i was after an more balanced beam between throw and lumen numbers and dimensions. I am under impression if i use one will lose lumen. yes i believe that including a collar will rise output throw in the end product, maybe i could hit ~1.5 Million cd… maybe next project will use one but as I said I am not to much fan of recycling tech for many different reasons . will try to touch this subject in more details when i review my light with more photos and schemes one of this days. thank you for the suggestion
YAY for aspherics!
Can you tell me more about how the pre-collimator lens work? So the first lens is an Aspherical, and the second is a planoconvex lens?
I have many aspherical lens, but many of them are bad quality. Where do you get yours?
Maybe you can go to a glasses store and get those lenses AR coated!
I will explain in detail how pre-collimator lens work, what it can do and not do, just gave me some time to prepare some diagrams and photos. Pre-collimator is an uf t20 lens and second lens an 100 mm diameter from fasttech.
I am in awe, that is an incredible build.
Gives the word, scratch build a whole new meaning…
You win greatest build of 2014 from where I sit.
Well done!
thank you very much for the nice words, but lets be fair here, Syri pure throw have almost double the time at disposition, the contest have been closed from a long time now and I still work and improve the light. So what you see here is different from what i was able to realize during the contest time.
first post updated, hope to have been able to share some light in likevvii questions.
What a great light! I love how it looked during the competition and now you have made it even better. Thank you for taking the time to make video and pictures and borrow cameras and all this. What a great build. TY :-D
I did not see this thread earlier.
This is factinating. So if you add some kind of wavien collar around that first precoolimator lenses you could gain 20 or more % of throw.
I dont recall seeing this thread either. Simply amazing, the whole show that is. A bit lost for words to be honest. All the best for the health.
I would be happy with 500kcd(or a bit less) throw in 50mm aspherics. So If calculated right by your build precoolimator needs to be 2,631 times smaller than main lens?
What is degree of precoolimator lenses and distance in mm from emitter to that lens? and what is distance from precoolimator to main lens?
It could be done in smaller package and I pressume that 50mm main lenses in combination with right precoolimator will project even larger beam(lumen) than in your picture.
by my quick calculations with an 50 mm aspheric and everything else equal like in my setup u should have around ~320 kcd throw. by default u should benefit from a bigger spot also.
u don’t need to make precollimator smaller, i am pretty sure that even with my existing precollimator u could use an 50 mm lens. but to work well u should find one with a long focal length. in fact what you are asking is almost this (little bit smaller with less output)
UF-T20 REVIEW Hi, Ordered one from Wallbuys, shiping was fast i think from their part but my local postal service seems to slow thing a bit. However the flash now is here with me Build quality at first look seems good. I have an M2 which is the upper standard in terms of build quality and finish, and T20 is almost there in finish and in build, M2 still I find it superior overall. ![image] [image] [image] [image] [image] [image] [image] [image] [image] [image] [image] …
in pure throw setup precollimator is very near the led maybe ~4mm. i don’t know exactly, have to take apart and find a way to measure.
one more photo of the light i made yesterday :
i have changed house lately and unfortunately now i am short of places to test throwers
just have to put up in the sky
i have a 2bbl aspheric lens sitting in my drawer it will throw a pencil beam when done just waiting on a host to be made for it................nice job
Damn, that is a cool looking light and the output is awesome. Wish I could understand what I'm looking at. It lookslike most of the final lens is covered by something. What am I looking at? I'm so curious.
nitro it would be cool if u finish your project and post some beamshots. it could be even more cooler if we have some sort of place when we meet lets say annually and compare self made and unique throwers and super throwers from all over the world. of course this is just an wishful thinking bc i know practically it have zero chances to be realized in practice
ImA4Wheelr tomorrow from work i can post more photos from diferent angles to get a more clear idea. its just the light that reflects on main lens. its funny but when u ask this i was playing with a small lens in front for more usability. but in the photo is just the 2 lens ordinary setup i use for play around.
Really incredible, and by the way, one of my best friends did Peace Corps in Albania and really loved it.
cabfrank thank you. my country is little bit unique in that regard, its very small but despite that, have a lot of sea with some very beautiful beach and in the same time some very rough mauntines with some interesting views and places.
ImA4Wheelr some more photos for you from different angles
for comparison i have put in one side ledlenser p7
and in the other side convoy M2
looking to the the led thru 2 lenses its not that easy job for the phone camera:
funny thing is when u ask what it has on top i was in the desk playing around with different setups.
I am from some times searching easy way to transform pure throw in one ordinary short search light. not that i need one but just for fun
and one interesting result is this from yesterday:
like this on my desk it project this spot in the ceiling :
when u ask i was just putting this lens on the top :
in the same position on the desk :
and the result on the ceiling :
like an ordinary flashlight with reflector
that’s why i like to play around with lenses. with the right ones and with imaginations you can do pretty much all you want
now i can control how much spill i want in both ways in diameter(changing to other lens with the same diameter but different f ) or in intensity which mean how much of the entire output will go to spill (changing the diameter of the lens but with constant f ) or both of them (changing both diameter and f )
right now i am looking for a way to mimic corona we see with traditional reflectors
with the right ones and with imaginations you can do pretty much all you want now i can control how much spill i want in both ways in diameter(changing to other lens with the same diameter but different f ) or in intensity which mean how much of the entire output will go to spill (changing the diameter of the lens but with constant f ) or both of them (changing both diameter and f ) right now i am looking for a way to mimic corona we see with traditional reflectors
I tried 5 precollimator lenses so far but they degrade the throw... Distances from 2-8mm above de domed emitter I tried to ask some other guys about this precoolimator thing and non of them had success, and some of them are in this job since very beginning of led flashlight.
No matter what lenses they tried throw was degraded a lot or just bit less than without precollimator lenses.
So it seems that you got some special lenses in your build. Is here any secret like polishing or something?
