Difference between Opus BT-C3400 & BT-C3100 v2.1?
So many similar versions of basically the same charger, just with slight revisions to improve the product. Very confusing.
Will there be a BT-C3500 as very final revision version?
Yet there is still 3 amps output on the supplied PSU. On one of the links supplied, this makes no sense…
Unless it means each channel can do 1 amp (1 amp to two channels at a time max), but not all 4 at the same time???
Am I doing this right??
I have sent Henry Xu an email about this. No other guy is more qualified to answer this question.
The comment on Amazon is from a random user and should not be taken as gospel. I wouldn’t be surprised if the C3400 is the same as the C3100 V2.1.
I don’t like how they are having all these minor updates and different versions within a few months. I think it is better to update every year with substantial changes and a different model number.
My take on this is exactly as yours, that the 3400 is identical to 3100 v2.1
I think it is actually better marketing wize to differentiate this way.
+ 1, as there was neither a 1.0 or 2.0 BT-C3400
I knew it :slight_smile: Well getting back later this month so by then there’ll probably be a 4000
My guess is that is one is updated hardware.
The 3000 did get some software updates to fix the problem with current pulses. This made the current pulses small enough that the power supply could handle it, but they where still above 3A.
The 3400 probably has changed hardware to get rid of the current pulses.
At the current time I have not been promised any review copies of it.
No, it’s from the seller, and called out as such.
I suspect that you are right though about it being the same as the C3100 v2.1. Someone realized that giving it a new name and label is a lot better way to clearly communicate that it is the new and improved version, and avoid people passing off old stock as new.
Or it could be as simple as they wanted to first use up all the cases that they had made up that said BT-C3100. I don’t think they expected to update the unit so soon after the release of v2.0
HKJ suggested that maybe there is an included hardware upgrade. From the Amazon site this C3400 has been in their hands since September. Is it possible OPUS could have made a hardware change that quickly after the release of v2.1?
Maybe it now possible to change the charging end voltage (3,6, 4,2, 4,35V) without opening the charger. It's crazy, that the feature is inside and not changeable without removing the screws.
Anyone find it officially from Opus? I looked over their alibaba pages, and couldnt find a BT-C3400.
Just emailed Robert ( rdana from ebay)
This is what he said……
The BT-C3400 is essentially the C3100 V2.1. This model number is exclusive to me.
Thanks,
I’m gonna buy one from him since it is the new 2.1 version.
Thank you, Electrified, for doing the leg work and getting us all a good answer.
This group buy ENDED mid Sept. I tried contacting gearbest on oct 1st but they will not honor the price.
Oh, sorry, I didn’t know. You are correct, I just checked.
Edit: Just now, the OP3100 coupon (promotion) code still works for a net price of $42.
perhaps I interchanged the codes, they should be:
v2.0 - gb3100 for $36
v2.1 - btc3100 ($45), this code no longer used
v2.1 - op3100 - code to be used for $42
So, there is no group buy for BTC-3400 this time :bigsmile:
Good. My BTC-3100 is still in waiting for final delivery from the post office. Maybe I’ll receive it in 1-2 days.
I’d better kill myself if there is already another groupbuy for a newer version even before I receive my BTC-3100 2.1 |(
Confirmed by Henry Xu from his reply to email inquiry.
Is the BT-C3400 still considered a relabeled BT-C3100 v2.1?
