Efest IMR-26650 4200mah Green
Do anyone have any info or reviews of these new green Efest IMR-26650 4200mah batteries? Are they the same as the KeepPower IMR-26650 4200mah batteries?
Surely someone has to know something about these batteries? :)
I will pick up a few with my next order and see how they perform. I have a feeling they might just be a re wrapped King Kong, but the only way to know is to test it.
Re-wrapped king kongs? I thought [as far as batteries were concerned] Efest was on the up-and-up. Or are these outside the normal Efest source?
Would there be something wrong if that were the case? King Kongs are great cells. Efest does have good cells, but they don't make all of them in house, especially with a lot of the 18650s. For example, their 16650 is a Sanyo cell.
King Kong is a ICR, and that cell pictured is an IMR. King Kongs are good cells but why buy a re-wrapped King Kong?
I guess we don't really know what the King Kong's chemistry is. Even the high drain LG HE2's product code is ICR18650HE2. It isn't clear cut anymore since all of the chemistries seem to be a hybrid. The ICR King Kong performs better under high drain than the INR King Kong. I think that the simple distinction between ICR and IMR is no longer valid.
Just to make it clear: I don't know what cell is inside of the Green Efest 26650; it was merely a guess, and an unsubstantiated guess at that. If it is the same, then no, I wouldn't pay more for it.
I think that Efest 4200mAh,Keeppower 4200mAh,Vappower 4200mAh... use the same internal cell because specifications are practically identical.
I will be very excited if these are they same as the Keeppower IMR26650 4200mah. I'm in need of some IMR26650 cells and were considering the Efest IMR26650 3500mah's, but will rather take these if they are the real deal.
Just as an update to my earlier statement: I have tested a few of the Green Efest 4200s, and they are not the same cell as a King Kong. They seem to perform slightly better under a heavy load.
Here is a test from a vendor, comparing it to the Efest purple 3500mAh, at 35 amps. It performed surprisingly well.
http://ukvapers.org/Thread-New-Efest-26650-batteries
Does anyone know if a magnet will stick to the top of this cell?
Efest on the up-and-up? What the hell? Efest is a rewrapper with a sort of an elitist appearance, but a @#$% rewrapper after all. They can decide to change what is inside of the wrap without notice, a very bad practice. And they already have a certain bad reputation for overspeccing some of their sh1te.
And what is more, if they are waiting for me to pay twice the price for one of their inferior products, better tell them to find a comfortable seat and proceed to sit, because it's gonna be a looooong wait (too long LoL!).
26650 Battery Bench Test Results and New Ratings Table @ E-CigaretteForum
That green Efest performed good. But, you know, there are better and cheaper cells.
Thanks for the link. Always love an independent test :slight_smile:
Do you happen to know of any of the better cheaper cells that also have a raised top and that a magnet will stick to?
Wow! What a messup with the quote LoL!
vestureofblood, if willing to attach a magnet over the hollow plus terminal I have to say that, in my experience, there's little problem with the all-the-rage LiitoKala 26650-50A:
Raised tops may be puny metal sheet casted large buttons spot welded with flimsy nickel tabs over the actual flat top:
For a clean, ultra-low resistance button top I recommend soldering a wide neodymium magnet, pooling additional solder over the top as a wear and tear reinforcement if required (NdFeB magnets oxidize quickly if their plating is removed). Without aggressive flux this may not work.
A good solder blob is cheap and easy, but not as cool.
This guy Mooch does all kinds of tests on batteries, almost all Efest’s are rewraps of other batteries.
Check him out on the ecigarette forum https://www.e-cigarette-forum.com/forum/blog-entry/list-of-battery-tests.7436/
Also check out his facebook page for the latest battery updates. https://www.facebook.com/batterymooch/
Related discussion at E-CigaretteForum with regards to my observed delta between HKJ and Mooch discharge curves: https://www.e-cigarette-forum.com/forum/threads/samsung-inr21700-30t-35a-3000mah-21700-bench-test-results-an-incredible-40a-3100mah-battery.798683/#post-19461187
Briefly speaking, Mooch doesn't measures battery voltage right at its terminals, which results in a non-compensated voltage deviation equal to current over sensing leads times sensing leads resistance. Slightly higher effective cutoff, too.
