Some real nice work going on here, love it!
I think the trick to singing like that is to always be squeezing one out then you become micheal bolton…
This is gonna be pretty cool looking… I know CK knows his stuff on the rgb end- I like that copper block you made.
Two great modders joining forces is too much awesomeness for a saturday morning!! If you guys don’t mind I would like to know if instead of going RGBW, is it possible to add a UV emitter (or whatever they’re called)? Something like a RUVW? Sorry for hijacking the thread, looking forward for the results.
Modders union wow , now i wish to live in the US nice and creative mod you doing there my eyes will be on this build
If I put a clock on my light builds and/or charged by the hour, well, it wouldn’t be pretty.
I will post the file work, by the end of Monday, because the light will be done, to the point of awaiting a driver by that time.
These are all TIR optics, so the beams will be smooth across and floody. Just an even lighting. It won't throw, but it should light up a good wide area in front.
I imagine UV could be used, but C_K would know better about that.
Very awesome. Two powerhouse modders at work.
11-08-14 More progress in the OP.
Pretty cool. I have some of those charge modules on the way myself. Great file work as always.
Congratulations! Great job thanks for sharing
Fibre what? Yes I need pics to understand it, thanks. I'm a bit bedazzled to be honest.
Finished the brass cover for the optics.
I'm done for the night. Going to go sit down and relax.
Fiber who?
Seriously O.L. somebody at Maglight should put you on payroll as a Consultant, Chief Designer, something ....
There sales would explode, (in a good way) .
Thanks for sharing, looks AMAZING.
Why is the cover plate looking immaculate? It should be full of crease marks and an odd looking shape. Are you sure you dont have a laser cutter out back hiding with your elves? So the light is going to have fibre optic feelers. Neat.
We don’t always get the luxury of a lot of new & different stuff around BLF. This project is refreshing!
You can’t really do UV behind plastic windows or TIR lenses as I understand it. You must use a reflector and a glass window.
hmmm. You say the light is going in a specific vehicle, my first thought was a charger. Am I right?
Nope!
Amazing work!!!
OL, can you tell which optic are you using for the nichia?
Thanks!
Amazing work!
Out of curiosity, what happens if the user plugs in the module to the USB and turns the light on? Will that be ok for the charge board? Will it be the 1 amp from the charger plus whatever the battery gives to power a given mode? And if less than 1 amp then the battery will still charge? If so, this will take the title of coolest USB-powerable light ever. Slap that onto a car charger and you can throw a disco party everywhere you go.
Also, do some nichias have that little square on the base board because 1 of the LEDs looks like it has it while the other 2 don’t in the LEDs shot.
