Olight Javelot M2X-UT Review *Pic Heavy* ---===11/19/14 Updates===--- Dual Power Supply Capability
The instruction manual for the Javelot shows a 8.4V max voltage range.
I don't have the instruction manual and cannot find that information anywhere on Olight's site.
Thanks,then it is safe?!
Calvin,
I bought my light off of you and Craig! If I get this extension do I still have a warranty?!!
I have this light[M3X] it takes 2 X 18650……That is what I run it on. True,it can use 4 X CR123a w/ sleeve provided.
I would wait until we confirm with Olight. None of our updated catalogs show an accessory tube like that. I took a look at the Ebay listing you linked and the extension tube doesn't seem to have the same knurling design as the rest of the light.
That looks like a Convoy L4 extension tube, they're pretty new on the market. I have no clue whether it fits this Javelot or not.
Edit: Taking a close look at both my Convoy L4 and Olight M2X-UT, the threads are not the same. The Olight has square threads. In that pic from ebay, that extension tube seems to also have square threads. The knurling is similar to the Convoy but the threads look different. Seems to me that putting an extension on the Javelot makes it a Triton. Same design, same head diameter, probably same reflector. So I'm not sure why you'd want to. But whatever floats your boat! :) Odd though, that Olight doesn't show that extension.
Ok Calvin.
No problem! I am glad I called earlier and talked to Craig! I will wait,I do not want to take a chance and ruin my light!
Thanks for your help!
s. I noticed the different knurling also. For some reason I did not register,that is where you come in!! lol!
True,except the Triton[which I have] is Not de -domed!! It is 91Kcd compared to 164Kcd!
I agree that otherwise it would be the same. I think the only reason someone would get the ext. tube is for longer run time[that is what is for] realizing that they would sacrifice compactness.
It came in a typical Olight plastic case.
Emitter is really clean:
Beam tint is on the neutral to cool white with a green cast. I wish there was a magenta filter to whiten it up, but could be a cool hunting light with a green filter.
Super clear image and they definitely did an excellent job de-doming that one!
Wow,that is clear image and a very clean de-dome! I hope mine looks like that!
I was wondering about that box Dale got! My M22 and M3X came w/ that plastic briefcase!!! lol,.
That was just a sample/review version!
That dedome is so perfect! And imagine they can make it so clean and neat on thousands of their M2X! :open_mouth:
I didn't know that at first. I've never seen the plastic case. The box looked neat and all, and of course I got no holster, no o-rings, no lanyard, no instruction manual. I had little to go on. And I wrote, as a Con, that it didn't come with these things. I got a fairly quick reply from Neal that I got a review sample, not shipped with accessories. Geesh, an instruction manual might have been nice! Then I'd have at least known what it was SUPPOSED to do, so I could test it more thoroughly. Oh well.
I measured everything I could think to measure. Metered everything I could put in a box or hook a wire to. Then tore it apart and rebuilt it. :bigsmile: Gotta admit, 278.75Kcd sounds better than 164Kcd. Right? Gained more than a football field in throw, like beyond both endzones. Works for me.
Gotta say, that image makes me want to break out the 5DMkII and the Hybrid IS Macro lens and have a go at it my own self! Pretty sweet, that!
Here's the emitter out of my Javelot. Obvious that it came with a dome on it...
I am hoping mine looks like jeter68’s!! We both got it from Illums,then again, they ALL came from Olight in China!
I will find out tomorrow. Bottom line is as long as the beam profile is not affected, it shouldn’t matter,I hope halfway bent bond wires would stay stable!
Oh, did you want to see bigger? I reduced it to about 70% (shot with A77/150mm macro) :wink:
you gots a messy one :smiley:
I am watching too much emitter porn today lol.
Great picture from you too Dale, it looks like Jeter68’s emitter is cleaner.
The bit of silicone stuck under the wire sure indicates to me they de-domed it themselves. Remember that this one is off the star, has been re-flowed and replaced.
The 5D MkII is a full frame sensor with 21MP. My macro lens is only 100mm.
This looks to be one for my collection! Is a group buy possible?
Mine looks and works perfect!! Can not wait until it gets dark!
My LED looks like jeter68 except[this is picky/critical!] both my bond wires are perfectly straight!! lol.
As I mentioned to other people, it does NOT have that big of a head. The pictures make it look bigger. Just like it does w/ most lights. It is very compact.
For the hell of it I connected the entire body of the M3X and it worked. So those threads are compatible. the tail cap is NOT.
