Lowes website does show the 2D XP-G2 on sale until the 26th. The 600 lumen XM-L is only down $5 to $24.97.
-Garry
-Garry
The light you posted about is only discounted to 24.97, not such a big deal. You stated your price point was $20.
Guys, it is important to note that these deals are on NOW and end on BF. I am assuming that if there are any left after that they will price at the original.
While you’re there check out this deal/
And see if they ring up for 49 cents for you.
Wow, I didn’t even realize those lights were on the floor before. I guess the regular price was just too high and I didn’t even give them a second look
It will be interesting to see what makes this thing tick. I hope they don’t use glue on these lights.
Thanks for the reminder on those vise grips. What I actually need (and can't believe they are so hard to find) is a pair of straight jaw ones (full size). Seems I lost mine and they were the good "Vice Vise Grip" branded ones.
EDIT - just dawned on me minutes later that they're not "vice Grips" but "vise grips" LOL!
-Garry
I saw 2 Lux-Pro flashlights at Lowes that they have brought into the Holiday Gift section.
One is a 180 lumen at $9.97 http://www.lowes.com/pd_569176-51336-LP470C_0+2z8vj?productId=50193509&Ntt=flashlights&pl=1¤tURL=%3FNtt%3Dflashlights%26page%3D1&facetInfo=\$5%20-%20\$10
The other is about a 90 lumen for $7.99
Both are advertised as being marked down. I don’t know anything about them, so perhaps someone else can comment.
Thanks, Ed.
I guess I missed quite a few of the Lux Pro lights when I was there, I will look for them when I am next there.
The reflector and lens is plastic, the lens is held in place by a threaded ring. I have also seen that used in the Defiant 3D light from last year.
That is a good sized pill and the driver is secured in place with a threaded ring.
Lots of thread to make good thermal contact between the pill and the head of the flashlight. BTW, all threads were lubed or had thermal paste on them.
The pill is solid for good heat transfer from the star. Unfortunately the driver is potted. That compound is rock hard and I don’t think it could ever be removed without destroying the components underneath. Maybe the part # of the board can give us a clue as to what it really is. I know this, there is an inductor underneath all of that. I can see parts of it protruding from the edges.
The star with the XP-G2 LED. To me it looks like too much thermal compound was used. It is soft and I will remove the star and fix that later.
The plastic reflector and the centering ring.
I tested the tailcap current with the supplied Alkalines and got 2.05A on high, 0.45A on low. I was worried that this light wouldn’t work with NiMH but it turns out that is not a problem. In fact I measured the same exact tailcap current with them. In fact even at a 3.6V partially depleted Li-Ion cell gave the same tailcap reading. Lastly, running the light on just 1 NiMH cell, I measured a tailcap current of 1.82A and there was a very decent amount of light coming out of it.
For the past several years Lowes has offered the LED MagLites for their BF promotion. It could be that this year this is the light that unseats MagLite on BF. For that reason I have decided to compare the 2 with pictures and their beam shots.
Now the beam shots:
Lux Pro, 280 Lumen
The 2D MagLite with the reflector adjusted for maximum throw. Approx 130 Lumen
Conclusions? I like them both, decide for yourself.
http://www.lowes.com/pd_503198-51336-LP90A_0?Ntt=503198%7C&UserSearch=503198&productId=4774883&rpp=48
Anyone see this light?
dchomak,
That's a pretty cool looking light. Liking that beefy pill. I think that light deserves it's own thread. Members will be doing some cool things with it and they shouldn't have to wade through this messy thread. It really is a cool light with a great feel in hand.
dchomak
wrote:Wow, I didn’t even realize those lights were on the floor before. I guess the regular price was just too high and I didn’t even give them a second look . . .
Yes, they have had an XP-G version of this light in the tool section for quite a while in a cardboard stand alone. I stopped at a Lowes' on the way home and they still had a tray of the older xp-g version, but now sitting in the flashlight isle. The one you alerted us to is a new XP-G2 version. Other than the emitter it looks identical.
I like that 2D; heck of a thick pill and a decent looking light. Not bad at all for $13.
One is a 180 lumen at $9.97 http://www.lowes.com/pd_569176-51336-LP470C_0+2z8vj__?productId=50193509&Ntt=flashlights&pl=1¤tURL=%3FNtt%3Dflashlights%26page%3D1&facetInfo=$5%20-%20$10
Thanks, Ed.
Without actually looking at the lights, I would say they don't seem like much of a deal. They will likely be coming down in price. AAA have very limited capacity to start with. 3AAA does not have enough voltage (after sag) to properly drive modern emitters. If you like the lights, you could drop an 18500 in them without modification (well, a cardboard wrap to prevent rattle).
Now this chunky, masculine light sold like hot cakes for $20 last year. They were discounted to $10 today at the store I hit. With 4AAA it can better drive an emitter, but will still have limited capacity. The great thing is this light can easily be changed to fit a 26650. I still carry mine in my whatever car I'm driving everyday.
I modded one here.
I imagine 26650 cells don't fit this light. (I didn't get a chance to stop this evening.). The 2D LuxPro light.
-Garry
26650 generally will not fit a “C” cell light. There is plenty of width in a “D” cell light.
Oh duh! But what about length of two 26650's?
-Garry
Maybe shorten the tail cap spring, there might be just enough there. I don’t know if the stock driver could handle the extra voltage. I didn’t even test mine on a fully charged Li-ion. I didn’t want to blow it on the first night
Oh I wasn't thinking to use the stock driver. Just wondering about it as a host.
-Garry
Use one of the AA to D adapters with a AA dummy cell inserted and then just use 1 26650.
But if you are going to change to a Buck driver, then it doesn’t matter.
I’m gonna go out and try to find one tomorrow.
If it blows up, oh well, but doubt it will on one 26650 cell.
Later,
Keith
I know so many of the members would just pass over a “Lowes thread”
After all they’re just a hardware store, right?
I see my Lowe's now has more holiday stuff out. The Utilitech #0569183 light is a 3C light with XM-L2 and advertised at 500 lumens and there is a Utilitech #05969178 3X XP-G2 light there as well. It takes, get this - 9XAA batteries in it. It is advertised as 1000 lumens. They are $29.97 and $39.97 respectively.
I also want that Lux Pro LP1200C with 6xAA and the half OP, half SMO reflector. It would be great with 6 Eneloops and an MT-G2 at 3 amps.
I bought a couple of the Lux Pro 2D lights and I happen to have some 41mm glass lenses, so these will get modded.
Remember this deal? Hammer, 25 foot tape measure, knife, pliers and cutters. Normally $12.95 on clearance for $3.60. Now they are $1.80, got 5.
This was what the clearance cart looked like. No price, I had to bring one up to get it price checked.
This one is NOT a good deal!!!
A set of 2 Dorcy clamp lights for 49.99
But look, from now until BF it is half price, 24.99. Let’s see what it uses for emitters
First the larger of the 2, then the smaller clamplight
The really sad thing is that they will probably sell thru, bought by people because they look like they would make a nice gift. Yeah, right.
Now some stocking stuffers.
and the pouch’s for the locking pliers that was clearanced a couple of months ago.
First of all Happy Thanksgiving to you all
Old-Lumens-Thankyou for the heads-up on the new Utilitech light’s I went to Lowes website and noticed they are having a half price off the two light’s you mention.
I ordered two of the 500 lumen C battery xm-l2 flashlight’s as I do not own any that use this battery and I will let you all know what I think of them.
If they work out I will keep 1 and give the other as a Christmas gift if they don’t work out then both go as Christmas gift’s…lol
But for $15.97 each it was to much to resist.
The 3X XP-G2 model is half price to so anyone interested it’s a good time IMO to get one.
