Olight Javelot M2X-UT Review *Pic Heavy* ---===11/19/14 Updates===--- Dual Power Supply Capability
154 posts / 0 new
wolfdog1226
wolfdog1226's picture
Last seen: 10 months 4 days ago
M25C2vn[~300Kcd] and the M2X-UT. They are close in size. The M2X is 1/2” smaller. The M25C2vn has a more cone shaped, tapered and deeper reflector. I am guessing at least 1/2” deeper.
http://i783.photobucket.com/albums/yy117/capolini1226/020_zps9e88d752.jpg
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
DB Custom
DB Custom's picture
Last seen: 7 hours 42 min ago
I wonder what those 2 wires are? The small ones attached to the star? The M2X-UT has those 2 points soldered, but no wires. Interesting.
I see yours says M31 on it, where my M2X-UT says M3X. Other than that they appear identical. And you believe the reflector is the same depth? Even though the head is deeper? Normally the longer or deeper head is only that way to house a deeper reflector. Again, interesting.
Assistant huh? Start taking em apart and putting em back together and the next thing you know you're a modder your own self. Silly
wolfdog1226
I am just guessing,maybe the wires were attached and soldered underneath?
        WOLFDOG
DB Custom
DB Custom's picture
They probably go to a thermal sensor or something, measuring heat on the star in order to step the output down if/when necessary. That's the only reason I can think of to have a wire there, but don't understand why 2 wires.
DB Custom
DB Custom's picture
I can plainly see black cows at 331 yds, and identify trees and the green leaves at 475 yds. It's even a wet hazy night.
wolfdog1226
DBCstm wrote:
They probably go to a thermal sensor or something, measuring heat on the star in order to step the output down if/when necessary. That’s the only reason I can think of to have a wire there, but don’t understand why 2 wires.
I am sure that is not it because the M3X has NO step down! Thermal or Timed.
        WOLFDOG
wolfdog1226
DBCstm wrote:
I can plainly see black cows at 331 yds, and identify trees and the green leaves at 475 yds. It’s even a wet hazy night.
I will try to be succinct! I had a minor issue with mine that I have A LOT of experience with!This happened so much with my TK75 before I found a solution w/ help! Last summer2013 I started a thread about it on the other forum.
I am not concerned it was just a bit of a bummer for the first time I used a light.
With in 5 minutes condensation formed under the lens and was there until I shut the light off. It absolutely affected the beam profile and blocked out about 70% of the light right around the hot spot.
Mr. M2X is now in quarantine like many of my lights have been. SOLUTION: SILICA Gel treatment!
        WOLFDOG
DB Custom
DB Custom's picture
Wow, with almost 80 lights in my collection I've never had that happen. Ok, never being a bad choice of words. I froze a light in the deep freeze at 0ºF overnight and then took it out and used it. Frost and haze was present on the Outside, but not on the inside.
The light is o-ring sealed against water intrusion, so the only way a haze or condensation could form on the inside of the lens is if the light is assembled under extremely humid conditions, trapping moisture inside. I guess if you open a light up and it's extremely humid (I would think it would have to be very very bad!) it might have moisture present inside when you reassemble it. I've never seen that happen though.
Strange stuff!
wolfdog1226
DBCstm wrote:
Wow, with almost 80 lights in my collection I’ve never had that happen. Ok, never being a bad choice of words. I froze a light in the deep freeze at 0ºF overnight and then took it out and used it. Frost and haze was present on the Outside, but not on the inside.
The light is o-ring sealed against water intrusion, so the only way a haze or condensation could form on the inside of the lens is if the light is assembled under extremely humid conditions, trapping moisture inside. I guess if you open a light up and it’s extremely humid (I would think it would have to be very very bad!) it might have moisture present inside when you reassemble it. I’ve never seen that happen though.
Strange stuff!
That [moisture gets inside at factory during assembly] has been the case almost every time. Every light that I have had that had a condensation issue started w/ the FIRST time I used it. It did NOT matter what time of the year it was ,,summer, winter ect.
-Silica gel treatment is the solution.I put a packet in the battery tube. For smaller lights like the M2X, I take apart into 3 pieces and seal it in a Tupperware container!
-The lights are NOT hermetically sealed. If they were, silica gel treatment would NOT work!
-One in awhile condensation will form again because they are NOT hermetically sealed. That is rare and again the silica gel eradicates it.
-I also believe extremely cold Outside temps[it was 24F last night and 17F now!] along with intense heat created by these high powered lights can contribute to it. Hence: Your freezer example!
If your interested this thread covers EVERYTHING with some repetition because of people chiming in w/out reading others responses!! That happens on most threads with some length!
Link below:
http://www.candlepowerforums.com/vb/showthread.php?368925-TK-75-quot-Con...
P.S. I ended each post with the same little quote!!.After few months I got rid of it!]
        WOLFDOG
DB Custom
DB Custom's picture
I just picked up the original M3X Triton with XM-L emitter for $49.95 at BatteryJunction on a Black Friday Special. Had to pay shipping, but still, great buy! Easy enough to put an XM-L2 in it and bump power with a resistor mod. Smile
To keep or gift, that is the question!
wolfdog1226
That is a great deal. It is nice to be able to soup it up like you and others are able to do! Now you can examine that to see if it has those Two wires like mine!
I got MINE [XML2] version last November off Ebay for $89. Still a better deal than most places. It is one of only a few I bought outside of a dealer and I still managed the warranty for 5 years.
        WOLFDOG
DB Custom
DB Custom's picture
The two wires are for thermal step-down, it's listed in the specs as being able to step down to protect it from overheating.
wolfdog1226
DBCstm wrote:
The two wires are for thermal step-down, it’s listed in the specs as being able to step down to protect it from overheating.
Is that for your version- XML?
Even though mine has the same Two wires when Selfbuilt did the review I remember him saying NO step down of any kind. He was surprised and did not agree w/ it!
Here is an excerpt from Selfbuilt pertaining to that!
______________________________________________________________________________________
All M3x-series lights are heavily driven on Hi, with no automatic step-down feature. As such, I recommend you do not run the light on Hi for extended periods of time on primary CR123A or 2×18500. On Hi, the light is really best suited for 2×18650.
As such, I continue to recommend you do not run any of the M3x-series lights on Hi for extended periods on 3x or 4xCR123A cells. I would also recommend Olight introduce a step-down feature in this light, as they have in a number of their other models (e.g. the recent M22 and S20).
On max, the M3X has very high output for the class, with no sign of any sort of step-down. ________________________________________________________________________________________
I think Battery[more like I know because I have seen misinformation by them and others!] Junction Posts some of the info. on their own when it was not part of the specifications from the manufacturer!
        WOLFDOG
DB Custom
DB Custom's picture
Key Features:
  • Two brightness levels (300 and 1,000 lumens), plus a strobe mode, controlled by a mode selector built into the head
  • Multi-function clicky tail switch with momentary activation and on/off
  • Latest top-of-the-line, highest-performing, single-die CREE XM-L2 LED
  • Aircraft-grade aluminum body with anti-scratch type III hard anodizing and crenelated stainless steel striking bezel and tail
  • Extended tube accommodates an additional battery to prolong run time
  • Reverse polarity protection to prevent improper battery installation and thermal management to avoid overheating
DB Custom
DB Custom's picture
2 CR123 cells are 6V, 2 18650 cells are 8.4V. 2 18500 cells are also 8.4V. 18500 cells are usually less capable of high current discharge.
But the specs as quoted on Olightworld.com say the ANSI ratings are achieved with 2 18650 3400mAh cells.
Why Selfbuilt would recommend to not run the light on high using the 2 lesser cells is beyond me.
* yes I know it uses 3 of the CR123 cells, which is 9V, but those little cells...even 3 at a time...can't deliver the amperage the bigger 18650's can. Or that's my experience anyway, could be wrong. Shouldn't matter, as the light is supposed to be digitally current regulated.
DB Custom
DB Custom's picture
And from Optics Planet, specifically on the XM-L version
Specifications for Olight Triton M3X Flashlight - 700 Lumens:
Output Mode 1:700 Lumens
Output Mode 2:60 Lumens
Runtime Mode 1:1hr 10min
Runtime Mode 2:15hr
Distance:475m
Intensity:56500cd
Water Resistant:2m
Impact Resistant:1.5m
Light Source:CREE XM-L LED
Battery:3x CR123A or 4x CR123S/2x 18650 w/ Extended Tube
Length:211mm
Diameter:63mm
Weight w/o Batteries:266g
Features of M3X 700 Lumen Triton LED Flashlight:
  • Crenelated bezel head and tail provided for close quarter combat
  • Multi-scattering slot design to protect LED and electronic components
  • Intelligent temperature control system to prevent flashlights overheated
  • Highly water resistant to IPX-8
  • Smooth reflector offers perfect beam and long throw
  • Shatter and scratch resistant and anti-reflective coated ultra clear lens
  • Friendly user interface - rotate the head change modes.
  • Operated by 2x18650 with extra extended tube to prolong the runtime
  • Removable stainless steel clip
  • Mountable on weapons with compatible weapon mount
wolfdog1226
Who knows! One of them is wrong!! :~
If I had to make a choice I would believe selfbuilt! What he said has been my experience w/ the light. One of the reasons I liked it so much. FULL BORE! No worries about loss of power or these 5/10 minute step downs!
This is a question not sarcasm! Are these the same as a step down?
-Intelligent temperature control system to prevent flashlights overheated. -Thermal management to avoid overheating.
Maybe it is more/better heat sinking? If there is an actual “step down” of any kind usually manufacturers state it that way?
All I know is the M3X XML2 could run on max for an hour w/ out heat being an issue, MAX output sustained regardless of season! There is NO step down,,,,,,,,,,maybe “Thermally managed” and “Step down” are Two different things??!! 8)
I think I analyzed and thought of everything I could on the topic!
Now wait!! If the flashlight never gets hot enough It will continue Unregulated on MAX with NO STEP DOWN or loss of max output!,,,,,I know, that is because it is thermally regulated!!
I rest my case ,Sir! :bigsmile:
        WOLFDOG
Rockspider
Rockspider's picture
Last seen: 11 months 2 weeks ago
Question for DBCstm, how did you managed to open the driver section without damaging the body? I have a M3X (the 1000 lm xml2 version) and a M2X is on my way too (ordered today, also due to your great review!)
On M3X I tried with hands and work gloves to improve grip but with no success.
Not really willing to use tools, to avoid nicks and scratches if possible...
Did you heat the head?
DB Custom
DB Custom's picture
I used a pair of strap wrenches. The ones I have are called “Boa Constrictor” and I believe they came from Amazon.
The threads had a blue substance, probably lock tite, and it was very stubborn coming apart. I’m more stubborn.
keengeorge
Last seen: 9 months 2 weeks ago
Good Day, Smile
FYI:
Olight M2X-UT Javelot Flashlight Extension Body Tube U$6.69
http://www.banggood.com/Olight-M2X-UT-Javelot-LED-Flashlight-Extension-B...
Best Regards,
George
DB Custom
DB Custom's picture
Are you a mind reader? Cause I’ve been looking really hard at this light and thinking “MT-G2 QO”.
I almost did it yesterday but the things such a nice thrower I took pause. But wouldn’t it really shine with a 10A big emitter? :bigsmile: 12A? LOL
Thanks for the link, appreciate it. (My wife, on the other hand, hates you. Just sayin…)
keengeorge
DBCstm wrote:
Are you a mind reader? Cause I've been looking really hard at this light and thinking "MT-G2 QO". I almost did it yesterday but the things such a nice thrower I took pause. But wouldn't it really shine with a 10A big emitter? :bigsmile: 12A? LOL Thanks for the link, appreciate it. (My wife, on the other hand, hates you. Just sayin...)
Thought You would be interested....
DB Custom
DB Custom's picture
MT-G2 standing by…
keengeorge
DBCstm wrote:
Order placed
MT-G2 standing by...
Looking forward to seeing the end result (& the Superb work that led to it)...  Wink Smile
crnkin
Last seen: 3 years 10 months ago
Isnt the m3x the original stl-v2/maxtoch etc?
Man things change so fast in this industry. So awesome
Chris
DB Custom
DB Custom's picture
Ok, yesterday I opened up the M3x Triton and found that the head is deeper because of the difference in driver. The driver does have the wires attached to the big star, those 2 little red wires out on the edge, and the star is aluminum. And the pill is hollow, there’s nothing under the big star! It sits on a fairly wide ledge though. I will be re-doing that, for sure.
I pulled the star out and heat it up to get the XM-L off, put a de-domed XM-L2 U2 on it. There is a row of sense resistors, a long row, like 7 or 8 of em. Most were R100’s but not all, there was a 2R00 among em and a couple of others. I took a stab in the dark and stacked 2 R056. Couldn’t get it to work outside of the body to test it, so I put it back together and tested it on 2 Sanyo UR18650FJ cells from a laptop pull. 2.56A at the tail…. is that double to the emitter? Or near it? With Efest 35A fully charged and rested it showed 2.43A at the tail.
Output is 1135 OTF at start, 1014 at 30 seconds. 196Kcd and 885.44M throw. So I did gain considerable lumens from the stock XM-L at 700, if the tail amperage is indicative of around 5A to the emitter, then it’s doing about what I’d expect except that the throw isn’t where I would have thought.
Still on the stock driver though, so it still has the twist head for mode changes. So, the dilemma on my hands now is which one do I modify with an MT-G2? If I’m going to have to create a large copper sink for the Triton anyway, since it has a hollow pill, then I might as well do that one with the big emitter. I did get the extension tube for the Javelot, but of course I have it set up now to run single cell only. And it’s so truly potent I’d kind of hate changing it, the smallest thrower I have at anywhere near that throw level.
Might just sell this Triton in it’s new and improved state and do something else with the MT-G2…decisions decisions decisions.
Anyone looking for a bumped but otherwise stock Olight M3S Triton?
crnkin
Sounds exactly like an stl-v2/6 with the hollow pill, but near 200kcd is doing well, mine is only 150kcd.
What are the markings on the driver?
And are you thinking it has a thermocouple input? Could be bypassed?
Chris
DB Custom
DB Custom's picture
And has the two wires connected to the star with some kind of component also on the star just beside the 2 wires. I don’t know about all that stuff.
crnkin
Will be a type of thermocouple, as the heat changes the resistance increases etc.
Interesting that its built into the star though
Chris
Rusty Joe
Rusty Joe's picture
Last seen: 1 week 5 days ago
Someone tell me how well the 2Xshooter measures up to the M2X? In brightness and throw, how does it measure up stock?
