HowTo: Modify Carclo Optics for XP-L Use--For $0.25
72 posts / 0 new
RMM
RMM's picture
Last seen: 8 months 1 day ago
Using a $0.25 T25 Torx Bit - Vinhnguyen54's Idea
S2+ w/ 3xXP-L
Convoy S2+ Shorty (18350) With 3x Domed XP-Ls & Modified Carclo
1. Background
As many of you know, the Carclo 3UP & 4UP optics don't fit over the XP-L die since they were designed for the Nichia/XP-G2/XP-E2 class emitters.  Our solution has been to either dedome the emitters, or try clumsily to use a drill bit or a sharp knife to open them up.
Last week I was over at Vinh's house (Vinhnguyen54) and as I was walking out the door, he asked me "are you still dedoming your XP-Ls?" I answered, "yeah, I am--I've tried opening up the optics and haven't found anything that I was that happy with", "check this out!" he said.  He then proceeded to show me a very simple, cheap, and repeatable way to open up the base of the optics using a filed down T25 Torx bit.  This was his idea, but I'd like to share it with all of you.
It is an imperfect method--but it is cheap, easy, and gives good enough results for me to recommend using it until something better comes along.
All lit up.  Not too shabby!
2. Items Necessary
Here is a list of what you'll need:
  • T25 (or similar) Torx bit
    • A file to taper the bit
  • Slow electric screwdriver, or a manual screwdriver (fast is not good)
  • Carclo Optic
  • A bit of patience! Wink
3. Filing the Bit
The bit's face needs to be slightly tapered--too little and you will have a hard time keeping it centered; too little and you will bottom out before open up the base enough.
You can file or grind the bit--it doesn't need to be perfect.  You can see that my sample below is a rusty old bit, and that it isn't filed perfectly.
Just some rough file work will do.
Old, rough, and rusty, but it does the job!
4. Opening up the Optic
Open for business! Cool
  • You want to use a slow speed when opening up the optic (I wouldn't recommend using a regular drill).
  • Stop frequently to clear the debris so they don't scratch the inside of the lens.
  • Stop frequently and check with an XP-L to see if you have gone deep enough.
  • The less material you remove, the less the beam is affected; however, if the fit is too snug you risk dedoming/ruining an LED.
That's about as deep as you want to go!
After you are satisfied with the depth, clean out all debris, install, and enjoy!
That's all!
Looks rough here, but don't worry, once installed and fired up it looks great!
5. Requisite Beamshot Discussion
I can't really see any extra artifacts in the beam, and once the optic is installed in the light, it looks pretty good.  The dedomed emitters offer a bit tighter beam--more like the domed XP-G2--than the domed XP-Ls which offer more flood.
Not much to see here...except for bright floody goodness!
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Edited by: RMM on 11/22/2014 - 00:07
DB Custom
DB Custom's picture
Last seen: 11 hours 21 min ago
Or would it be beneficial to get a end mill bit? Like a 6 flute end mill maybe? Then it would cut clean... might be a centering issue then I don't know.
Thanks for sharing. You'll be sure to sell a lot more optics now! :bigsmile:
RMM
RMM's picture
I'm sure that there is a cleaner, better way to do this, but it surely won't be $0.25! Wink  This is BLF, after all!
Default Username
Last seen: 4 years 4 months ago
Thanks for sharing! Have you tried sanding and buffing the remaining burrs for a cleaner end result?
bdiddle
Last seen: 2 years 2 months ago
Have you compared light loss between dedomed emitters and dined emitters using this method?
Newb
DB Custom
DB Custom's picture
I guess I am not a good member here, just ordered an 11/64" 3 flute ball nose end mill bit. Smile
Dog ask me, cow should I know?
Edit: Ain't it purdy?
FlashPilot
FlashPilot's picture
Last seen: 3 hours 24 min ago
Regardless of the method, its nice that these can be opened up without changing the beam pattern. Thanks for posting.
DB Custom
DB Custom's picture
But I'll use it for some of my other projects so it won't be for nothing either way. Wink
LightJunk
Last seen: 4 days 16 hours ago
Cool. Thanks for the tip.
texas shooter
Last seen: 4 hours 42 min ago
Thanks, that’s what I’ve been looking for. Any idea if the rough finish hurts the % of light much?
RMM
RMM's picture
texas shooter wrote:
Thanks, that's what I've been looking for. Any idea if the rough finish hurts the % of light much?
There is truly no way to know without having a perfectly polished one to compare it to.  I'm sure it isn't optimal, but my 18350 powered S2+ measures over 2,000 OTF, so I'm pretty happy with it!
Mike C
Mike C's picture
Last seen: 4 weeks 9 hours ago
RMM wrote:
The bit’s face needs to be slightly tapered—too little and you will have a hard time keeping it centered; too little and you will bottom out before open up the base enough.
Thanks for posting!
I’m think it should be “too little and it will be hard to center” and “too much and you will bottom out” ?
M4D M4X
M4D M4X's picture
Last seen: 8 hours 32 min ago
cool idea!
ai laik!
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
18sixfifty
18sixfifty's picture
Last seen: 1 year 1 day ago
Very cool. Nice to know it can be done without messing up the beam profile.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
dchomak
Last seen: 2 years 3 months ago
DBCstm wrote:
Or would it be beneficial to get a end mill bit? Like a 6 flute end mill maybe? Then it would cut clean… might be a centering issue then I don’t know.
Thanks for sharing. You’ll be sure to sell a lot more optics now! :bigsmile:
Acrylic edges can be flame polished, I don’t know if that can be done here.
bdiddle
is this really an advantage over a dedomed xp-l?
Newb
Mike C
Mike C's picture
Massive advantage. Cereal_killer explains it perfectly here: http://budgetlightforum.com/node/35436#comment-674837
DB Custom
DB Custom's picture
Keeping the domes on is most beneficial in maintaining tint. De-doming costs some lumens but most importantly it degrades the tint, sometimes in a way that is too much to take...the pea green hue.
Say you absolutely LOVE the 3D tint (I absolutely LOVE the 3D tint!), you really can't de-dome an emitter and wind up with that color of light. De-dome the 3D and it changes pretty drastically to orangish warm. The warmer tint emitters aren't as prone to show the pea green color, but they do shift away from the preferred tint. It's been pretty common with the XM-L2's to de-dome 1A tint emitters to keep the color as nice as possible. But are there 1A XP-L's? 2A, 2C, 3D...I haven't seen a 1A yet. The 2A's aren't horrible when de-domed, if you don't mind a slight off yellowish-green hue. (very slight usually, but still)
Legolas Jr.
Legolas Jr.'s picture
Last seen: 1 day 15 hours ago
Thanks Richard! Like Dale, I LOVE the 3D tint, and now I can have it in a 20mm triple! Could you show a comparison beamshot between the modded dome-on triple and a de-domed one? And do you know the approximate OTF lumen difference?
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
Cereal_killer
Cereal_killer's picture
Last seen: 10 months 2 days ago
Whichever way (this way or my way with a knife blade) the key factor to watch out for it to not bottom out the tool in the optic cup- if the in inverted dome get’s scratched it’ll screw up your beam badly.
My recommendation is to buy extra optic’s to practice with.
RMM
RMM's picture
Now you're asking a lot of me, lol.  I actually have a dedomed XP-L V5 2A triple which I could use to compare in the same light.  I'll try and get some beamshots/output comparisons, but it might be a while until I can do so.
The dedomed XP-L's beam is very similar to a dome-on XP-G2 beam.
The big deal here is keeping the tint, since I'm guessing that the lumens difference is under 10%.   Also, not everyone is comfortable dedoming emitters.  This is much easier and cheaper if something goes wrong!
Firelight2
Firelight2's picture
Last seen: 41 min 57 sec ago
Hey RMM… you should offer opening up the optics to fit domed XPL as an extra add-on service with all your Carclo triple optics Big Smile
DB Custom
DB Custom's picture
Even if the XP-L stays within 10% of it's output when de-doming, with a triple light that's a 30% loss in output! With a hot rodded triple, that can be a very significant lumens loss.
Say we're seeing 1400 lumens per emitter for 4200 OTF lumens with the domes on. Take the domes off and lose a mere 10% and we have a 520 lumen loss! Yeah, I'm all for keeping the domes where they belong, on the emitter instead of on top of my computer. (I have a little collection of hot de-domes. Smile )
Edit: Obviously, even more impact on a Quad.
Halo...
Halo...'s picture
Last seen: 4 years 2 months ago
DBCstm wrote:
I’m all for keeping the domes where they belong, on the emitter instead of on top of my computer. (I have a little collection of hot de-domes. Smile
Let see your collection! :bigsmile:
DB Custom
DB Custom's picture
Couldn't resist trying, so I modified a Torx bit and gave it a shot...
I used a cordless Makita hand drill with variable speed and did most of it at very low revolution. Then I set it to high speed mode and ran it fast to sort of polish the cut. Works so so. There was a bit of slag along the cut edge that I scraped off with the razor sharp tip of my Sage 2. Now I'm gonna have to build a light! Smile
DB Custom
DB Custom's picture
Just ordered a shorty S2, I swear those weren't on the site last order I placed just day before yesterday! Now I'll have to wait for that to come in so I can complete this quad. Smile
RMM
RMM's picture
They weren't!  Added them last night.
RMM
RMM's picture
Firelight2 wrote:
Hey RMM... you should offer opening up the optics to fit domed XPL as an extra add-on service with all your Carclo triple optics :D
Been available since yesterday for the triples and quads. Wink
WarHawk-AVG
WarHawk-AVG's picture
Here is one that might work…might need to remove the outer ledge in order to expose the cutting blades
http://www.harborfreight.com/reamer-deburring-tool-65338.html
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 10 months ago
Good idea. I just use an exacto knife and taper out the openings with that. Same way as I trim off the metal in the ID of a pipe after cutting it.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
wight
Last seen: 7 months 2 weeks ago
DBCstm wrote:
Even if the XP-L stays within 10% of it’s output when de-doming, with a triple light that’s a 30% loss in output! With a hot rodded triple, that can be a very significant lumens loss.
Say we’re seeing 1400 lumens per emitter for 4200 OTF lumens with the domes on. Take the domes off and lose a mere 10% and we have a 520 lumen loss! Yeah, I’m all for keeping the domes where they belong, on the emitter instead of on top of my computer. (I have a little collection of hot de-domes. Smile )
In response to the text I bolded: It’s still 10%. A triple of 100-lumen emitters where each emitter puts out 10% less light (90-lumens each) is now putting out 270 lumens. 270/300=0.9, or 90%. 30/300=0.1, 10%.
The output loss is still noteworthy of course!
@RMM – thanks for posting this.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
