and what kind green led it uses ?
My Yezl Y3 arrived a few days ago. Shipping was relatively fast. Overall I like this light, but the threads are the worst I’ve seen in a flashlight. Had a hard time trying to screw the battery part into the electronics part again. That’s really too bad since it’s such a nice light apart from that, but like this I wouldn’t recommend it to my friends.
Mach die Gewinde mal sauber (Klopapier, kleiner Spritzer WD40) - wirkt Wunder.
Die Frage ist auch, wie oft man die Lampe da öffnet… eigentlich nie
Clean the threads with a piece of toilet paper and a bit WD40, makes it way smoother.
WD40 is standing right beside me on my desk, I’ll give it a try. Thanks for your advice!
Edit: Made it a bit better, WD40 is great stuff, but unfortunately it can’t make imprecisely cut threads right.
http://www.gearbest.com/diy-parts-and-tools/pp_119294.html
Discount Coupon: New2S2P
Discounted price:$9.99
Hi djozz, it has a driver.
Hi nofearek9, it’s Q5.
Hi chouster, I’m really sorry about, do you mind PM me with your order number and the pictures about the problem, thanks.
Does this light also not have a driver, like the red one where the batteries appeared directly wired to the led?
The red one without a driver was from a different vendor.
You got me for three of the coupon specials, It would have been nice if I could have ordered all three in the same cart and still gotten all three discounts, It would have also saved on paypal fees and shipping.
Welcome to enjoy the Black Friday deals :party: , 22% off with the coupn bfcm
What does the code work on?
Xmas products.
I just tried it on a light that is currently $86. The price when up to $99.xx. I guess it's 22% off the original list price.
very difficult to find anything that is not "discounted"...
I agree…The discount should work irrespective of other discounts…CMON GEARBEST!
FlashPilot: gearbest:Today’s new deal Jetbeam HC20 Headlight
coupon: JetbeamHC20
price: $27.99Does this include the free 18650 cell?
Hi FlashPilot, it doesn’t include the free 18650 cell
GB, if the battery is not included, then it is similar price to those on Ebay. If you include the battery i will get one
Hi MRsDNF, it does work on these items, 22% discount off from the original price.
Black Friday deals list
1.Exquisite 6m LED String Light Water Resistant 40t Base RGB Lamp
2.Exquisite 3m LED Snowflake Rope Light 78t Base Lamp
3.Exquisite Christmas Ornament 11cm LED Light Snowman
4.Exquisite 6m 40t Base Mini Corn String Lamp Crystal Light
5.4Pcs Popular LED Electronic Candle
6.Fantastic Dazzle Colour Rose Lamp
7.Fantastic Colorful Blooming Rose Lamp
8.Fashionable Design 4M 40 x LED White Light
9. LEDs 4M Flexible Crystal Ball-shape RGB String Light
” “:http://www.gearbest.com/led-strips/pp_76231.html
10. 9M 20-LED Colorful Fairy Christmas Balloon Shape Solar String Light Lamp
11.CIS-57364 RGB Remote Control LED Christmas Tree Candle
12.CIS-58260 60-LED RGB Outdoor Solar Fairy Lights
13.10M 100-LED AC110V LED Light String
14.GU10 4W 60 x 3528 SMD LED 220-240V 400lm White Spotlight
15.GU10 6W 29-SMD 5050 LED 600lm 3000-3500k Ball Bulb
16. E27 3W 5630 SMD LED AC85-265V 300lm Warm White 3500K Ball Bulb
17.GU10 60 x 3528 SMD LED 4W AC220V 400lm Spotlight with Lamp Shade
18.GU10 4-LED 4W 400lm AC85-265V White Spotlight
19.GU10 60 x 3528 SMD LED 4W AC220V 400lm Spotlight with Lamp Shade
20.E27 5W SMD-5630 Energy Saving White Light 9-LED Bulb Lamp - 6500K 450LM AC-220V
21.G24 60-SMD 5050 LED 6000-6500K White Corn Lamp - AC85-265V
” “:http://www.gearbest.com/led-light-bulbs/pp_19584.html
22.MR16 3-LED 3W AC12V Warm White Spotlight
23.KeepPower 4200mAh 26650 Rechargeable 3.7V IMR Flat Lithium Battery Max 50A
24.Dual Torch Holder Clip Mount Bracket for Flashlight Headlight
25. Aluminum Alloy 25mm Flashlight Laser Sight Barrel Mount Clip Clamp Holder
26.UltraFire 501 LED Torch Remote Pressure Switch for 501A 501B 501C 501D Flashlight
27.High Power Military Laser 301 532nm Green Light Zoomable Laser Pen
28.High Power Military Laser 303 532nm Green Starry Light Zoomable Laser Pen
Hello Gearbest, is this one a 3.7- 4.2V like in the description or 3v-18v like in the pictures?
http://www.gearbest.com/diy-parts-and-tools/pp_24042.html
Thanks.
I only see < 4.2v mentioned for that dropin. ?
( although I am also looking for one that will accept 8.4v or more for multi cell use)
