I've measured when driver turns on yellow and red status leds indicating power exhausting stages. I've measured figures at battery side. There is some voltage drop involved at higher currents. The lowest current at level 1 is probably the nearest to the voltages at the driver terminals. At level 10 there is significant difference due to voltage drop in wires and connector.
Level 1 and level 10 voltages
Yellow turns on at 6.15V and 6.7V respectively
Red turns on at 5.9V and 6.3V respectively
Red blinking at 5.7V and 5.8V respectively
Difference is not linear as the light starts dimming due to voltage drop below of the leds Vf.
At red blinking stage light tuns to level 2 or 3 and doesn't come up regardless if you raise the voltage. You would need to disconect the light from the power to get green status again. This is good if you're almost out of the power, but you'll still get low light for quite some time for safe return. Of course you can select lower levels by hand immediately when red status light turns on.
Thanks ledoman for your review. As I said over at MTBR, I may ditch my exact looking model from KD (though 4.2v with different driver) and get this one instead. I think I will practice the potting method on my old one though. My unit (without coil) has 6.3mm of empty space between the driver and PCB for potting. The thread on modding my light's driver (with pics of light) is here.
siata94, I have this headlamp at FastTech on my wishlist for its 2 cell battery case (buy a battery case and get a free headlamp! :) ).
Thanks Garry. Would love to see how your modding turns out also all about potting stuff.
Battery case from Fasttech you pointed out is 2P1S (4.2V) while with this "KD2" you would need 2S1P ie. 8.4V, so no go. But it could be good for your KD version.
I contacted KD about buying this lights driver (this "10-step user programmable" one). They will sell the driver for $8. They also reminded me that for my 4.2v version light the LEDs would need rewired to series (I appreciated hearing this from them as it showed me they had some knowledge on what they were telling me about driver replacement). If interested, you would just have to contact them and say you wish to purchase the driver used in bike light sku#S023788.
^ Thanks garrybunk for getting that driver available. I just bought one.
ledoman,
Thank for this very informative review. Nice work. Although the thermal path to the housing appears limited, it might do the job fine at moderate currents. Depends on if that copper trace covers the whole MCPCB and how thick it is. Also, there appears to be some room for upgrading behind the MCPCB.
EDIT: Guess I didn't look at the pictures close enough. I just noticed this post by ledoman:
There is not much space left. Coil is almost touching the PCB. Then there are the wires, too. There is only some small space left on the both sides. PCB could be cut away on sides since on the other side there are TIR lenses leaving some space. Using artic alumina bond it is possible to stick there some small chunk of copper. I might just do something in this direction in the future.
I recall reading elsewhere that the original Gemini Duo and the earliest clones under the Yinding name had a solid aluminum wall across the middle of the housing as a thermal path, ’til early in 2014 somewhere — but those have disappeared, because people copied the outside appearance while cutting material and build time, gutting the insides. Somewhere I saw someone had just weighed the good ones vs. the recent ones — lots of material gone away.
Has anyone tracked down the early design anywhere?
This is like the ‘solid pill, hollow pill’ thing, I guess.
I was talking to them to get one to test. Will see in a few days if I'm going to get one. Also I think we can get some coupon afterwards. It is just light head no other shitty accessories. If it's really good one price is not so high. Combining with this battery case can make really good light setup for helmet use.
> Yinding
OK, we need something, I’ll go with that one.
I don’t see anything specific about the included battery pack — I know those are iffy — any idea how good that part of the deal is?
Well, I’ll know in a while.
Unfortunately I don't know the battery. We think we have found original manufacturer of Yindings and the first batches, before clones came out, and even my 2nd gen. have had quite good batteries. Not the best, but reasonably good. At least I can speak for mine sample. I can ask over at MTBR if the manufacturer can give some figures about real capacity.
Thanks, I figure on supplying my own good batteries, but I’m wondering about the battery box — does it have a protection circuit built in, so I can use unprotected cells?
And of course is the included charger a threat to life, or acceptable, since so many cheap chargers fail HKJ’s tests I don’t trust them much.
I’ll comment when mine gets here, but it’ll be next year sometime.
About battery box you should read this thread and yes it has protection built in. It is safe to use unprotected but brand cells. Can't tell anything about charger. I've found reasonable good ones at ebay. Search for "8.4V charger P7". Still would test each if it is CC/CV.
> Battery box
Thank you! that’s a good one. I’ll have two, because I’d ordered one of those weeks ago that’s en route.
Oh well, never hurts to have a spare.
> test if it is CC/CV
If you have a pointer to how to test that, I’d like to know. I’ve never known how to test chargers
See post #12 in this thread. Perfect cheap solution. (They are cheaper from China, but I linked a good fast US Seller.) To look for CC/CV just watch that the current is constant during the beginning up to somewhere around 8.0v (I'm totally guessing on the 8.0v part) and then see that it switches to maintaining constant voltage with current slowly dropping down from where it was. You may not see the constant voltage on the display (because I'm guessing you'll be seeing the battery voltage rising), but you will see the current dropping. The only two chargers I've tested this way just maintained CC right up to full charge / termination voltage.
Ledoman (or others), please correct me if I'm wrong.
More or less correctly, yes. This dual led device can be used to measure power to the light or from charger to the battery. It is just the matter how you set the connectors (male/female) - you should follow the current flow. It is not highly accurate, but good enough to get the feeling what's going on. I'm using 30V/10A device expecting it being more accurate than 100V /50A for example. You can see the pictures in the first post of this thread where the power to the light is measured. Of course you can use 2 multimeters instead.
When want to test the charger you are watching voltage and the current flow to the battery pack. Voltage should gradualy raise up to 8.4+/- 0.05V (it is OK a bit more because of the voltage drop in wires and connectors down to battery). The current at some point (at 8-8.2V is a guess) should start to decrease slowly towards the 0A. Until 8V the current should be constant, but some cheaper chargers are starting to drop the current even before. Nothing wrong with that except the charging time will be longer
You should also watch the status led on the charger when it turns green. If it doesn't turn green or/and the current stays relatively high (> 50-200mA) for longer period even when the green turns on then you have an issue. It should follow CC/CV type of charging fo Li-Ion batteries. Read more at batteryuniversity.com.
First to test - without load charger shouldn't put out more than 8.4-8.5V, lesser is better.
