My Tenergy RCR123A are 3.2 volts. I don't use them much so . . . thought I'd add this useless post.
Foy
Foy
i have 4 tenergy rcr123a lifepo4 batteries i use every day. i use them in my ecig. im not sure how they compare to other rechargeables, but 2 last me a day. i have been using the 4 i have for over 6 months, so say 180 days, 90 charges each
id recomend them. you can get um fairly cheap on ebay too
from what ive gathered, 3v are non rechargeable, 3.2v are the lifepo4, and 3.7v are li-ion. the lifepo4 are supposed to be a safe, rechargeable, direct replacement to primary cr123a cells
Rat Shack in Portsmouth had the last 2 of them on the shelf pretty dusty. I charged them up and they work fine in the laser xenon Glock light. They give off 3.2 volts when fully charged so they don't fry anything, regular lions give 4.2 volts.
Hey E1320,
PM me your address....I've a half-dozen or so 3V rechargeable batteries that I'm no longer using. Some are fine, some may not hold a charge....but you can have 'em, if you would like. Free to a good home, or even yours.
Thanks man i appreciate the offer but this post was resurected from May so I am all set now, but thanks again.
No prob. Let me know if you change your mind.
Sorry about hijacking your thread, but has anyone tried these 3V rechargeables in Solarforce Skyline I?
Common sense says 2 x ~3.2V should be inside "tolerances" for 6.0V maximum. OTOH Solarforce sales support said that anything over 6.0V will fry the led.
I started using the Tenergy 900mAh 3.0 "RCR"123s over a year ago. They are great batteries. However, they are standard 3.7 volt lithium ion cells but the PCB knocks the output down to 3.0 volts within 12ms of being loaded. they worked flawlessly in my Streamlight PT2L. Several people at my place of business were so impressed with the battery/charger/light combination that five people have the same Streamlight and Tenergy RCR123 combination.
I actually gave my Streamlight and the Tenergy batteries/charger to a friend since he liked the light as my Spark SL6 is my EDC now. He is very pleased with the combination also and carries the light with him every day. I recommend these chargers and cells to everyone.
Sounds good. Thanks for the advice!
However, I couldn't find any seller shipping them to Finland, or the shipping cost was absurd. (100-200% more, because of shipping. Wow!?!?)
Do you have any idea how to get those? Or would some friendly member in US buy those for me and ship with normal air mail? Or does anyone know any similar items, which could be bought from China or something?
I use them as well but mine are blue, had them for years now and never gave me any problems. Use the charger it comes with only. Once charge the voltage will hang around 3.2 volts so i would let it rest before you pop it in there.
I see this Thread came back to life. I bought the 17335 3.0 V to use in My SF SKYLINE 1. It has a IC in the Driver with a 6 V Max. 8 V will Fry it. Is this 6.0V or maybe 6.4-6V. The 17335 3.0V will charge up to 3.2-4V , x 2 = 6.4-6.8v. I used the 2 batt. in a 2nd Light to drop the OV to 6.0V. SKY1 Tailcap Current was1.40A .With a 18650it is .90A. There has to be some Voltage Drop under Load with this small Battery so 3.2-4 OV may be 3.0V LV with a 1+Amp load.
My $.02 on this situations is, i bought a 12pack of Streamlight CR123a about a month ago. Every single cell is putting out 3.22v, so i would assume that all the rechargeable 123s sitting at 3.2 is well within the tolerance of any device intended to be run off of 123s. Otherwise, i got a full bad batch of batteries :)
So these rechargables can bi charged with ordinary Li-ion charger, up to 4,2V?
Holy thread revival
Nope you need a special charger or a charger with a low voltage cutoff selector switch that maxes out around 3.5 volts. I have a radio shack charger just for the RCR123s
I ended up just buying a dozen regular CR123s since this is an under the pillow piece and doesn’t get much use.
May as well help keep this tread going too. I have 4 of the tenergy RCRs also and they have been very reliable. I consistanly get 800ma for and hour before the protection cuts it off.
You are joking, right?
And im not talking about ordinary RER123s I was talking about those with 3,0 nominal voltage, just needed confirmation.
Be careful with those jokes including false informations because someone not very good in english can miscomprehend them and act upon false info.
Ecig, I guess he meant 3.5 volts, not 3.5 amps. Then his post fully makes sense, as 3.5V is 90% SOC for LiFePO4’s.
Actually a variety of “123” batteries and multiple designations for the exact same battery depending on the manufacture.
Some common ones
CR123 / CR123A 3.0v (primaries) considered non -rechargeable.
They very much can be recharged, but it is not the best idea you’ll ever have.
If you insist on doing so , use charger set a 3.0v… Or better yet, DON’T !!!
ICR123 3.0v ( rechargeable ) Use charger w 3.0v setting
should terminate between 3.2 & 3.6volts…
RCR123 3.7v rechargeable & likely has protection circuit.
Use charger setting 4.2v
16340 3.7 v In both protected & non-protected.
Use 4.2v charger setting.
Batteries and chargers are given voltage ratings for a reason.
And it is the individuals responsibility to use the correct charger / battery combination.
Just because someone read it here , or there. Does not remove that responsibility.
Thanx
