BTU Shocker Triple MT-G2 with a twist -- Aiming for >100Watt ~9000Lumens -- With external 2S power pack, handle etc...
377 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 5 days 2 hours ago
Looking forward to seeing this running!
MRsDNF
MRsDNF's picture
Last seen: 1 hour 32 min ago
Did you plan all this or is it just happening? My head is spinning.
RaceR86
RaceR86's picture
Last seen: 4 years 3 months ago
Great work!
Keep going and keep the updates coming. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
LinusHofmann
LinusHofmann's picture
Last seen: 10 months 2 weeks ago
Bit of both Wink
But to be honest I had a fairly solid idea of how all this was going to go together and it’s mostly going to plan, no nasty surprises yet…touch wood!
If I had a lathe I’d have turned down the back of that aluminum slug holding the drivers a bit. Just to give me a few more mm of breathing space on the rear side of the driver cavity.
But considering it’s just a random part I found in a box it’s actually pretty close.
Here’s the rough 3d plan of the driver setup from a year ago, turned out pretty close. Smile
LinusHofmann
Massive image dump incoming!:
Sorry…but I’m pretty pleased with how this is coming together and it’s hard to show how it all works without a bunch of angles Silly
The driver assembly is done!
Barring a few last bits of insulating heatshrink this element of the light is ready to roll :bigsmile:
The MCU board is connected to the rest of the driver and the contact board by three detachable pin connectors.
Black is battery negative/ground, Red is batt positive switched by the clicky switch and Black/Red Stripe is the PWM signal going to the slave drivers.
Contact board, MCU and wiring. Hmm will all this spaghetti really fit in that driver cavity??
All of it should go together something like this. I need the extra length of main power cables to let the assembly twist down while tightening up the center contact board. It’s only a half turn or so at most but important that none of the cables are too short and get in the way. I also want to be able to undo and move the contact board out of the way enough to get access to the MCU later for reporgramming, more on that further down…
These are the main power cables coming from the contact board and the copper contacts that will get bolted to the driver assembly. Small black wire coming off this goes to the MCU ground connection.
And this is how it connects up to the driver assembly. (Still need to properly insulate the positive connection before final assembly)
Here’s another angle showing the wire carrying the switched positive from the clicky switch through the aluminium contact board holder and to the MCU
Not much room to spare! Silly
Just to prove it all works and goes together as it should, here’s a crappy gif showing the assembly process.
And again I want to be able to get to the MCU for easy reprogramming so here is what the in-light reprogramming process would look like.
it’s just a matter of unscrewing the contact board retaining ring, wrangling the power cables out of the way and fishing for the MCU board. Smile
Job done!
Now…where did I put those Mt-G2s? Wink
wight
LinusHofmann wrote:
Job done!
Smile
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
MRsDNF
MRsDNF's picture
Orsm. RBD has your MTG-2 leds. They are with the reflector he last 18 months ago. Wink
LinusHofmann
I guess I’ve been away too long, who or what is an “RBD”?
And more importantly how do I go about liberating my MT-G2s from such a thing? They’re kind of important to this build…can’t be waiting another year to get this thing finished Silly
Actually I wept slightly seeing the newest MT-G2 Q output bins on IO, mine seem rather antiquated in comparison.
Can I get this thing finished before the MT-G3 is announced? Wink
MRsDNF
MRsDNF's picture
RBD would be Rufusbduck. He lost from memory a reflector along time ago and its just stuck in my head for some reason so put two an two together rattled it around in my head for a Nano second and came to the above conclusion. I had the same problem when I built my shocker with the MTG-2 led being updated. I wont tell you what I ended up doing.Wink As far as finishing before the MTG bazillion comes out will I suppose depend on how quick the mailman comes.Smile
M4D M4X
M4D M4X's picture
Last seen: 2 hours 41 min ago
i cant wait to see it finished…
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
feilox
Last seen: 6 months 5 days ago
any new updates? JW if u gonna mass produce a few.
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
LinusHofmann
Aha yes of course, the master of looking so sternly at a piece of copper it cringes into an elaborate heatsink. Wink
Well considering I haven’t even finished the first one, talking of mass production is a bit early methinks. Haha Silly
But hey if someone is really serious about wanting a light like this and is realistic about how much it would cost for me to hand make them one. Then sure, I’d be up for building a couple more, why not.
Parts cost alone is over $300 last time I checked, so that should give you some idea.
Oh and Updates are ^^ there… I’m afraid you’ll have to look through the thread to see the latest stuff. I can’t update the first post anymore since the thread is so old… :~
feilox
I don’t plan on LED/MTG change or Driver change. Just the tactical handle and otterbox & rc batteries. I’ve already gotten a BTU-Shocker. So i thought it would be cheap (under 100). Also thinking of doing a shoulder mount like camcorder’s in the past. A u or clamp mount on an old shoulder pad camcorder pad.
LinusHofmann
Ah right so you’d be interested in a kit something along the lines of this?
Yeah I could see that working but it does require a modified BTU tailcap or getting a run of custom tailcaps made up. And for the whole thing to thread straight onto a stock BTU, unlike on my light, the handle rail would have to be bolted to the tailcap instead. But in theory yeah that could work fine. A plug and play battery pack kit for BTU owners. Smile
-2× 3S rc packs in parallel probably around 10,000mah (3s and much lower current requirements from stock BTU would allow for a thinner power cable)
-Main power switched by a Fet in battery carrier driven by clicky in trigger
-MCU in battery pack for automatic overcurrent/undervoltage protection cutoff etc. (still haven’t gotten around to adding this functionality to my pack either but should be relatively trivial)
But for under $100, I’m afraid not.
Quickly worked it out and the cost for just the parts in the image above is over $150!
I’m sure you could source things for a bit less but that’s what it works out for my build, big ticket items such as the battery packs alone will run you around ~60bucks.
feilox
yea that’s fine the only big problem would be finding another tailcap without buying the whole thing.
LinusHofmann
Yep definitely. I could send Ric at cnqualitygoods a mail and ask if he has any BTU tailcaps lying around unused. Maybe he can check down the back of a couch or something, who knows… Silly
lionheart_2281
lionheart_2281's picture
Last seen: 4 hours 57 min ago
Vinh modded a few as well, might be worth PMing him too
MRsDNF
MRsDNF's picture
I swear I did not clean Ric out of all his left over Shocker parts.Surprised
LinusHofmann
So you’re to blame! Hah, good thing I swiped them from you just in time then! They’ll be worth their weight in gold soon enough Wink
Did he actually say those were the last bits he had laying around?
MRsDNF
MRsDNF's picture
No I'm no sure. He did not have any lenses as I broke one and he had none left. He did send me some misc o'rings and a few other parts though I guess he had kicking around.
LinusHofmann
Internet broke so couldn’t upload any progress.
It’s alive! Finally Smile
Running off the battery pack fully assembled for the first time was a really great moment.
But it’s already back in pieces, for final tweaking and assembly.
Measured 15Amp draw from a single partly charged pack and Lordi does it pump out the heat! I definitely need to spend some time maximizing the thermal path into the reflector and out to the front of the light because the BTU pill and body is completely overwhelmed by the heat these three emitters pump out. Not unexpected really and I’ll definitely have the turbo timer enabled on this light, probably set to 1.30-2min max but I’ll see how the thermal properties are when everything is fully assembled. Then I’ll find a medium/high mode power level that can allow for continuous operation and go from there for low.
Very pleased with the STAR off timer driver UI and Moonlight mode works great. I’m pleased with the output level set to 12, but I do notice a bit of the usual moon mode flickering. Wondering if the phase correct PWM leads to more stable moon modes at very low levels? Has anyone got any experience with this?
After running on high for 2 mins I also saw some output throttling/flickering even though the pill surface wasn’t above 50degs, so I need to make sure the 7135s aren’t getting too hot inside and throttling back. All told it’s a bit of a nuclear reactor this thing, especially since the battery pack doesn’t give in at all under these power requirements and just keeps feeding the juice! Shocked
Well as you can see still lots of tweaking and tuning to do but it’s getting there.
Oh and it’s quite a bright Mule this thing Wink
MRsDNF
MRsDNF's picture
At 15 amps although each led is on getting 5 amps that will still be generating enough heat to use in a steel foundry. I reckon the pill could possibly be getting a lot hotter than 50 degrees in that time. I have a single MTG-2 at 9 amps on a large copper pill and copper star and that chucks a mental after a few minutes because of heat. Getting closer to being finished. Again thanks for updating. Smile
RaceR86
RaceR86's picture
Its alive. Its alive! Smile
Some really neat looking work you have been doing. A joy to watch.
LinusHofmann
I looked into it a bit more and running the pill separately from the driver I noted that a few of the 7135s were getting too hot and started throttling back within a minute.
This was running the driver direct from a single pack without the long cable so the vF difference that the chips need to burn off was exaggerated (I drop ~0.6v across the cable at 18A so max vBatt the 7135s should ever see would be around 7.8v or rather 7.6v with sag) but it resulted in the same issues I was noting before.
Mostly the chips on the bottom of the slave boards without a direct heatsink link where hitting the limit rather quickly but all of the chips were inadequately heatsinked (-sunk? -sank? -sunked?). I underestimated how much heat these chips produce and expected a single solid solder point from the top ground ring to also sink the bottom of the driver adequately. Should have known really.
So anyway I spent the evening soldering copper tabs between the ground rings of the three slave boards top and bottom and reinforcing the connections to the copper posts. I’ll probably also pot the bottom of the boards to the aluminium assembly with fujik once I’m happy things are working well enough to be more permanently mounted.
Urgh it’s a mess tbh, don’t look too closely. It’s more flux residue than driver at this stage… Wink
Was tempted to just start the thing from scratch and use those new Nanj 105d drivers instead. They have a great layout for this type of thing and much more generous grounding ring, not to mention I’m pretty sure the copper is thicker on those than on these crappy KD drivers…might still end up going that way if I can’t get this to work well…
It’s not a solution to the mental heat the Mt-g2s put out, actually they’ll just be running at high power for longer now…doh …but at least the driver doesn’t start going mental before it’s own heatsink has even had a chance to heat up to match the rest of the pill. After that it’s just a matter of tweaking the turbo timeout for sensible operation.
This is why I focus on making things easy to disassemble, I certainly don’t trust myself to get things right first time even with all the testing I do along the way. Generally it’s time well spent. Silly
Bort
Bort's picture
Last seen: 2 months 17 hours ago
Are you telling us Kim Kardashian succeeded?
j/k, the light looks great
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
LinusHofmann
Not unless she was the one working in our garden and snagging the cable with a shovel. Silly
Well think I’ve hit a bit of a speed bump here. Even with the thermal path reinforcements some of the 7135s are still getting too hot. Honestly wasn’t expecting this to be an issue, never really had any overheating issues with these chips before as long as some basic heatsink considerations where undertaken.
Especially the stack of chips on the outside of the puck, where I had to file down the solder blob and ground ring for clearance issues, are getting very toasty. Hard to get extra copper connections on there too.
Will probably have to rebuild this thing from scratch to maximize the thermal paths… Sad
Last thing I’ll try before going that route though is potting the whole thing in fujik…but urgh that’s really a last resort since I wouldn’t be too happy with such a messy solution…
MRsDNF
MRsDNF's picture
Welcome to the MTG-2 on heat club.Tongue Out
LinusHofmann
Haha, let me get the hose!
LinusHofmann
Ok, let’s see if this will work. Hacked up Nanjg 105d with extra copper thermal pathways.
Basically I used one of those new layout Nanjgs and instead of stacking an extra layer top and bottom I triple stacked the top because that allowed me to solder a copper ground band all around to maximize heatsinking. I noticed before that the 7135 chips on top of the stack and only connected to the heatsink through a thin solder bridge where the ones that couldn’t dump the heat quick enough. This should no longer be the case, all 7135 ground tabs (at least on top of the board) are now solidly soldered to the copper band which in turn is soldered down to the ground ring. Finally I will solder two copper “ears” to the band which will be bolted and possibly also soldered to the copper posts on the assembly to complete the heatsink/grounding path.
I guess I just like pain… haha…but I’m not going to jump in and make three of these things before I’m absolutely sure they’ll work! Silly
Time to test this thing and see if it can dump the heat fast enough! Fingers crossed! Glasses
Cheers
M4D M4X
M4D M4X's picture
LinusHofmann wrote:
Fingers crossed!
+1 !
deals.m4dm4x.com
