Yep definitely. I could send Ric at cnqualitygoods a mail and ask if he has any BTU tailcaps lying around unused. Maybe he can check down the back of a couch or something, who knows…
No I'm no sure. He did not have any lenses as I broke one and he had none left. He did send me some misc o'rings and a few other parts though I guess he had kicking around.
It’s alive! Finally
Running off the battery pack fully assembled for the first time was a really great moment.
But it’s already back in pieces, for final tweaking and assembly.
Measured 15Amp draw from a single partly charged pack and Lordi does it pump out the heat! I definitely need to spend some time maximizing the thermal path into the reflector and out to the front of the light because the BTU pill and body is completely overwhelmed by the heat these three emitters pump out. Not unexpected really and I’ll definitely have the turbo timer enabled on this light, probably set to 1.30-2min max but I’ll see how the thermal properties are when everything is fully assembled. Then I’ll find a medium/high mode power level that can allow for continuous operation and go from there for low.
Very pleased with the STAR off timer driver UI and Moonlight mode works great. I’m pleased with the output level set to 12, but I do notice a bit of the usual moon mode flickering. Wondering if the phase correct PWM leads to more stable moon modes at very low levels? Has anyone got any experience with this?
After running on high for 2 mins I also saw some output throttling/flickering even though the pill surface wasn’t above 50degs, so I need to make sure the 7135s aren’t getting too hot inside and throttling back. All told it’s a bit of a nuclear reactor this thing, especially since the battery pack doesn’t give in at all under these power requirements and just keeps feeding the juice!
Well as you can see still lots of tweaking and tuning to do but it’s getting there.
At 15 amps although each led is on getting 5 amps that will still be generating enough heat to use in a steel foundry. I reckon the pill could possibly be getting a lot hotter than 50 degrees in that time. I have a single MTG-2 at 9 amps on a large copper pill and copper star and that chucks a mental after a few minutes because of heat. Getting closer to being finished. Again thanks for updating.
I looked into it a bit more and running the pill separately from the driver I noted that a few of the 7135s were getting too hot and started throttling back within a minute.
This was running the driver direct from a single pack without the long cable so the vF difference that the chips need to burn off was exaggerated (I drop ~0.6v across the cable at 18A so max vBatt the 7135s should ever see would be around 7.8v or rather 7.6v with sag) but it resulted in the same issues I was noting before.
Mostly the chips on the bottom of the slave boards without a direct heatsink link where hitting the limit rather quickly but all of the chips were inadequately heatsinked (-sunk? -sank? -sunked?). I underestimated how much heat these chips produce and expected a single solid solder point from the top ground ring to also sink the bottom of the driver adequately. Should have known really.
So anyway I spent the evening soldering copper tabs between the ground rings of the three slave boards top and bottom and reinforcing the connections to the copper posts. I’ll probably also pot the bottom of the boards to the aluminium assembly with fujik once I’m happy things are working well enough to be more permanently mounted.
Urgh it’s a mess tbh, don’t look too closely. It’s more flux residue than driver at this stage…
Was tempted to just start the thing from scratch and use those new Nanj 105d drivers instead. They have a great layout for this type of thing and much more generous grounding ring, not to mention I’m pretty sure the copper is thicker on those than on these crappy KD drivers…might still end up going that way if I can’t get this to work well…
It’s not a solution to the mental heat the Mt-g2s put out, actually they’ll just be running at high power for longer now…doh …but at least the driver doesn’t start going mental before it’s own heatsink has even had a chance to heat up to match the rest of the pill. After that it’s just a matter of tweaking the turbo timeout for sensible operation.
This is why I focus on making things easy to disassemble, I certainly don’t trust myself to get things right first time even with all the testing I do along the way. Generally it’s time well spent.
Not unless she was the one working in our garden and snagging the cable with a shovel.
Well think I’ve hit a bit of a speed bump here. Even with the thermal path reinforcements some of the 7135s are still getting too hot. Honestly wasn’t expecting this to be an issue, never really had any overheating issues with these chips before as long as some basic heatsink considerations where undertaken.
Especially the stack of chips on the outside of the puck, where I had to file down the solder blob and ground ring for clearance issues, are getting very toasty. Hard to get extra copper connections on there too.
Will probably have to rebuild this thing from scratch to maximize the thermal paths…
Last thing I’ll try before going that route though is potting the whole thing in fujik…but urgh that’s really a last resort since I wouldn’t be too happy with such a messy solution…
Ok, let’s see if this will work. Hacked up Nanjg 105d with extra copper thermal pathways.
Basically I used one of those new layout Nanjgs and instead of stacking an extra layer top and bottom I triple stacked the top because that allowed me to solder a copper ground band all around to maximize heatsinking. I noticed before that the 7135 chips on top of the stack and only connected to the heatsink through a thin solder bridge where the ones that couldn’t dump the heat quick enough. This should no longer be the case, all 7135 ground tabs (at least on top of the board) are now solidly soldered to the copper band which in turn is soldered down to the ground ring. Finally I will solder two copper “ears” to the band which will be bolted and possibly also soldered to the copper posts on the assembly to complete the heatsink/grounding path.
I guess I just like pain… haha…but I’m not going to jump in and make three of these things before I’m absolutely sure they’ll work!
Time to test this thing and see if it can dump the heat fast enough! Fingers crossed! :nerd_face:
Cheers
I just ran the new slave in free air with no additional heatsinking and it didn’t throttle back at all even after 2mins @ ~6A! Yay! Pack voltage was around 7.6v in this test which should represent the kind of voltage the slave would have to deal with in the light. Obviously the whole thing got quite hot (over 60degs C ) because the heat had nowhere to go, but no drop in power during that duration so all the chips seem to be getting evenly hot, awesome. Same conditions on the old slaves would see instability and step down after about a minute.
With a fresh pack at 8.4v the slave stepped down after about 20s! Haha lots of energy being burned off there but that’s obvious (I think that’s around 6W of heat being dumped into the poor little slave)!
Ok feeling optimistic that this will work well in the light, let’s get to building the other two
But these 7135s are very well sinked now and soldering thermal pathways to the outsides is a piece of cake so getting the heat away from the slaves quickly will be much more easier than before.
