Nice review…Zeusray really is one of the top contender zoomies (stock it holds its own against one of my modded SK98 clones)
But Daheq you did to that car…is that a Camaro with donut rims…yikes!
Great review CD, you’ve pushed me over the edge and I ordered a Zeusray from dealmetic. Totally against my will.
WOW
superb pictures and review!
oh shit! now I must buy one for me!
Have have resist for so long… :bigsmile:
nice work, thank you very much.
Dealmetic have sold 10 of these lights since this review was published and now only have 4 left.
They do seem to re-stock fairly quickly though. I think they are going to need a lot more stock, quick!
Definitely a contender for this years BLOTY* award. (If there was such a thing)
*Budget Light Of The Year
Thank you for the review. Such good pictures that really show what is what here. TY :-)
For those feeling that advanced modding itch I'll post some results of other modding endeavors to undertake on this host for us addle minded light nuts over the holidays.
Suddenly noticed that there’s a yellowish circle band at the outer edge in all zoom modes. Is this normal?
Only one left now…
Let me try a handwaving answer; someone I hope can point to a source with a proper picture of the structure and light path that will be clearer.
All “white” LEDs use a blue-white emitter underneath a layer of phosphor that glows yellow-white.
The light path going through all that plus the lens is giving you an image of the original source.
If you were to look very closely at the emitter (don’t do this without a filter, it’s too bright) you’d see that variation due to the difference in thickness of the phosphor (and maybe of the dome as well) and the variation of brightness of the emitter underneath. If you look closely at the tightly zoomed image of the emitter it’s slightly brighter on the side where the wires connect, and slightly bluer.
If you look at the widest zoom you’re seeing almost none of the central, slightly bluer, direct light, and more of the edges that are lit mostly with the phosphor color.
You also get bands of bright/dark/bright along the edges of the circle, there’s a name for that effect that I’ve forgotten.
Checked my other zoomies and they all have varying amount of yellow band. With Zeusray this effect is more pronounced because it’s the brightest zoomy and thus contrast is more pronounced. Thanks for the answer.
Ordered. or pre-ordered…
Is there a De-domed Chimney shot? I see only Domed one.
The first 2 distance shots are domed and de-domed.
Somehow missed those. Comparison of the illumination of the tree by domed and de-domed shows the marked brightness improvement with de-domed.
I just haven’t had the time to put it back together, yet :~
I dedomed one of my zeusray’s yesterday, so far i am not sure how i feel about it.
A bit less output but nicer warmer beam but i think i messed up the heatsinking by dissolving the heatpaste because it get much less warm now and thats possibly the reason for less output.
I will try to reapply some and see if that improves things, another issue i had was i just dunked the whole pill in gas for like a day but i forgot to remove the o ring, so it got completely stiff and i had to use the bottom one instead, and it is slightly to small so the head wobbles some when i zoom now.
Do anyone know where i can buy some o rings that would fit?
Dealmetic got another batch in but the numbers are dropping fast……
Any update on why de-domed did not perform better?
Tis the season. The new batch is sold out and it is on backorder again.
I think Dealmetic owes Chicken Drumstick a free light, or, at least, a very big thank you.
