Just wanted to let you all know I ordered a few more of these as Christmas gift’s for the family and two of the three flashlight’s I ordered had XML-T6 led’s and one had an XM-L2 led.
I guess for those of you that live close to a lowe’s you can peek and see what Led it has but for those of you who order like I did just be aware of this in this product—>
I’m about a little over an hour away from a lowes and I am contemplating doing that but I just did a beam shot comparison and there realy isn’t much difference indicating this flashlight isn’t driving the led very hard none of the family member’s that are receiving them know anything about flashlight’s two of them just have halogen bulb maglites and my grandparent’s still have a silver metal flashlight that uses a bulb that look’s like it came from the 1950’s…lol,so they will all be impressed as is so I’m just not sure at this point.
Guess Lowe’s was angry I bought the light’s at close to half off then slapped a 10% coupon code on top of it using a trick,here is a post about this trick in case you all want to try it it realy does work was able to make it work for me a couple of times to get coupon codes—>
On Black Friday I got an email from Lowes about a $14.98 deal on this Direct Drive ratchet wrench and sockets. Regular price is $29.98. Well, with everything else going on that day it went right over my head. Sometime later when I thought of it I checked it out.
As some of you may know, there are coarse toothed ratchets and fine tooth ratchets. Of the 2, fine tooth ratchets are usually preferred as they allow the wrench to ratchet with less backward motion to engage the next tooth. This “Direct Drive” wrench in effect has infinitely small teeth to alow ratcheting in tighter spaces. IF it works, this could be a very useful tool.
I have been watching the display since BF and the have NOT been selling, At All! They were reduced to $19.98 and still they didn’t sell. Now I see that they are at $9.98 so I picked 1 up to play with.
Yes, in “effect” but there’s no teeth or paw used. If there were, they’d be so fine, that they’d fail under load. It uses a one-way clutch like in most motorcycle starters (spring-loaded rollers on ramps). If you don’t have one, get it.
Great deal alert dchomak. I use ratchets probably more than any other tool. All mine are the old style with standard teeth. Really like this direct-drive concept.
Unfortunately, those don't appear to be in the stores around me.
Between this and the HD thread you cost me a lot of money dchomak hahah.
I picked up 3 of the ratchet sets. One to play around with and two to fill in for nephews Christmas gifts, their flashlights are staying with me instead haha.
You know it’s funny, I know I said I picked up 1 to play with. I lied! I also picked up 3, one for me, one for MY nephew and one for a friend. The really funny thing is that when I went to check out the cashier asked me “why is it everyone buys three of these?”
Thanks dchomak. That did the trick. I'll be picking up a couple tomorrow. One for me and one as a gift. That is, unless a 3rd jumps into my shopping cart while I'm not looking.
Picked up a couple this morning. I can tell I'm really going to be appreciating it when I have my arm deep in a transmission tunnel trying to remove a 5 foot long, fine threaded bolt, and there is like 1 inch of ratchet movement space.
Breaking news, this just in……
I told a friend of mine of the Direct Drive Rachet deal at Lowes and he just called me from his store.
It seems that item #607976, the item # that ImA4Wheelr was unable to locate is really the pairing of the set we got, #607975 and the Thumb wheel rachet. He got both for the $9.98
EDIT: He showed them the page below from Lowes.com on his smart phone. This deal just got even better.
