What is difference between H02 and H02R version? Photos show different reflector.
I can’t say what the difference is. Are there any reviews or specs on the other unit?
MHanlen, or any of y’all, do you know if there is room for a protected cell in this light?
Yes I use a panasonic 3100mAh protected
yes!
i just hoppped in my basement and tried…
the tube has 19mm inner diameter and 65mm unprotected flat top pulls work as do my 70,5mm protected panasonic
(i have the old model with round optic)
oh - btw: i have a code to get it for 39,99
At 1:42 in the video I show using a 3400 shoshine protected cell or a panasonic 3100mah unprotected cell. I have a variety of cells at home and it takes every protected or unprotected 18650 I throw at it.
Thanks for all the information, I just pulled the trigger with on this with a great discount code. Should be a great worklight for inside electrical cabinets.
Once again, BLF rocks!
-Ford
Glad you liked it! I’m currently working on a review for their new color headlamp- if you don’t need RGB then this is a great choice.
I like this type of review.
Showing me how the light’s use with magnet, outdoor, stream, etc.
Good video commentary.
Thank you!
which btw you can now find here:
Current ones come with better mode spacing :)
5 - 110 - 380 - 820 lumens.
Glad they finally improved it. They seemed to have made their low, lower- in their new light too.
wow. Great review and pics…I assume this is a floody headlamp?
Nice review!!
I have the newer version from the group buy, with better mode spacing, and I have to say the latter mode spacing is truly spot-on! I’m enthusiast of this light, very versatile and well made. I advise everybody to join the GB while it’s active, I ordered a second one a few days ago because it’s too good a deal for such a useful lighting too.
I have just ordered a Skilhunt H02 headlight/flashlight and wondered if any of the extension tubes that are available would fit so that I could run it off 2 x 18650 cells to lengthen the run-time.
The Skilhunt website states that the torch runs on 3 to 9 volts, so 2 x 18650 cells should be possible.
It is just a matter of finding an extension tube with threads that fit.
Can anyone help please?
Thanks
You may want to rethink this a little. Not sure if you would want to run 2 x 18650 cells in a headlamp. It will be long and heavy. It will feel awkward while on your head. Just thinking outloud.
Would it not be simpler to carry another cell in the pocket, instead of on your forehead? Just thinking out loud :bigsmile:
I really do want an extension tube!
I might not want to use it every time I use the light, but I definitely want that option.
Does anyone know which of the available extension tubes will fit?
Thanks
Maybe an E-mail to the company would help you out?
The trouble is that Skilhunt themselves do not make extension tubes. The available extension tubes for 18650 lights that I have seen are made by 3rd parties.
Once my light has been delivered I could then identify in engineering terms the thread needed for the extension. But I still would not know what threads the available extensions have and I would be very surprised if a seller of them would be able to tell me.
Looking at various extensions on sale and reviews from purchasers, I can see that there are AT LEAST two different threads used. One is used by an Ultrafire light and the other by a Convoy C8 light.
