I purchased mine on the evening of the 17th and it arrived on the 24th.
The Hong Kong postage paid decal on the bubble mailer envelope was dated 18.12.2014.
That’s a new record for fast shipping from China based businesses for me.
Sorry i haven’t tried yet, i had 2 zeusrays and i gifted the unmodified one for Christmas so i can’t compare domed to dedomed anymore but i have ordered a new one.
All my modding time was spent upgrading some Enlan & Sanrenmu knifes for gifting, but i will get back to the zeusray when all my family & relatives leave after the holidays i update here when i do.
Chicken Drumstick said that it pulled less Amp, 3.75A for domed and after the dedome 3.43A, so that could also be a factor, or that i perceive the light as less bright when it is less blue, it is hard to know because it is my first dedome.
I wonder if the hot dedome lower the Amp like the gas one?
It could also be that a warmer light is less contrasty than the more blue white light so that is why i perceive it to be less impressive outside, i still like it more as a in house light now when dedomed because it is less jarring blue and a nicer warmer light.
There is a marked brightness difference if you look at the illumination of the tree by domed and de-domed. The tree by de-domed is markedly brighter than the one by domed in the above pics by Chicken Drumstick. I am just puzzled why you don’t get the marked increase in brightness when all involves is simple de-doming the emitter.
But thats the throwyness aspect of it if you look at the house roofs beyond the foliage it is clear that the beam is like half as wide so it is a lot brighter in the center only and the warmer hue could also illuminate the green shrubbery more intensely.
If you look at the sky part of the beam in that picture you see that there is a lot more green in the hue than the domed much bluer beam so guess it fits that it looks brighter also from that it now contain more green in the light.
EDIT
I just have to add that i am not discounting that there is something wrong with my light the heatsinking is still of or it dropped the Amp a lot, i wonder if Chicken Drumstick dedomed also got a lot less warm in the hand after the dedome?
There is a lot of excitement about the Zeusray, but the increase in performance over the old SK-73 is not large. The SK-73 still has advantages. The biggest improvement is the price.
Ok thanks for the answer, but that i can use protected batteries i see as an advantage for the zeusray, i gifted one plus a evva protected battery and a charger for Christmas and it was very well received for just 25$ that is a very affordable deal.
If the SK-73 has low volt protection it could be an option, do you know if it has that on the stock driver?
Can you measure the tailcap current? Noticed that with the stock light tailcap, in addition to body tube, also get slightly warm. Does the de-domed tailcap get warm up?
I did just with super short fat wires, i got 2,43A but with the battery at 3,80v
I will recharge my battery to take measurement at full charge and update.
And thanks for getting me to fix some proper wire for my DMM, i foresee lots of accurate tailcap measurement in my future
New test, battery Panasonic NCR18650PF at 4,16v the dedomed pulls 3,3A with the same test wires i used before.
BUT i found some even thicker wires and those show…….4.0A…….
what…… i couldn’t believe it so i charged up the battery again after i used it some and got exactly the same results, for some reason messing about with it taking it apart and putting it back together + multiple times of measuring the tailcap current seems to have fixed it somehow, now i don’t believe i get 4A with the tailcap on because this switch is known to induce losses and it still takes longer to get nice and toasty in my hand than i remember my domed ones did.
At first i thought i had just been stupid and used different charged batteries for the domed & dedomed but i clearly remember double checking, by switching batteries multiple times and using the same battery in both just to be sure, always with the same result.
I am not really sure what to think of this it feels brighter outside now but it is a very different weather out now –15 celsius and much moisture in the air now vs 3+ and very dry air so i can’t really compare before i get my new stock zeusray.
And i charged up a Samsung 20R to 4,19v……….but the Amp reading on my DMM is dead i don’t know what happened but it doesn’t work anymore i guess i shorted it somehow? so no more reading before i get a replacement and i learn how to not destroy my equipment, any pointers guys?
I don’t think it has low voltage protection. I would also choose the Zeus and a protected cell as a gift. It is not a boost driver, so the cell can’t get more discharged than slowly approaching the XM-L’s minimum forward voltage.
I did it without the brown reflector and Chicken Drumstick said his got slightly damaged when he did it without taking of the reflector, and i you do the entire pill, please remember to take of the o ring, mine got damaged by the gas because i didn’t remove it.
