There is a marked brightness difference if you look at the illumination of the tree by domed and de-domed. The tree by de-domed is markedly brighter than the one by domed in the above pics by Chicken Drumstick. I am just puzzled why you don’t get the marked increase in brightness when all involves is simple de-doming the emitter.
But thats the throwyness aspect of it if you look at the house roofs beyond the foliage it is clear that the beam is like half as wide so it is a lot brighter in the center only and the warmer hue could also illuminate the green shrubbery more intensely.
If you look at the sky part of the beam in that picture you see that there is a lot more green in the hue than the domed much bluer beam so guess it fits that it looks brighter also from that it now contain more green in the light.
EDIT
I just have to add that i am not discounting that there is something wrong with my light the heatsinking is still of or it dropped the Amp a lot, i wonder if Chicken Drumstick dedomed also got a lot less warm in the hand after the dedome?
There is a lot of excitement about the Zeusray, but the increase in performance over the old SK-73 is not large. The SK-73 still has advantages. The biggest improvement is the price.
Ok thanks for the answer, but that i can use protected batteries i see as an advantage for the zeusray, i gifted one plus a evva protected battery and a charger for Christmas and it was very well received for just 25$ that is a very affordable deal.
If the SK-73 has low volt protection it could be an option, do you know if it has that on the stock driver?
Can you measure the tailcap current? Noticed that with the stock light tailcap, in addition to body tube, also get slightly warm. Does the de-domed tailcap get warm up?
I did just with super short fat wires, i got 2,43A but with the battery at 3,80v
I will recharge my battery to take measurement at full charge and update.
And thanks for getting me to fix some proper wire for my DMM, i foresee lots of accurate tailcap measurement in my future
New test, battery Panasonic NCR18650PF at 4,16v the dedomed pulls 3,3A with the same test wires i used before.
BUT i found some even thicker wires and those show…….4.0A…….
what…… i couldn’t believe it so i charged up the battery again after i used it some and got exactly the same results, for some reason messing about with it taking it apart and putting it back together + multiple times of measuring the tailcap current seems to have fixed it somehow, now i don’t believe i get 4A with the tailcap on because this switch is known to induce losses and it still takes longer to get nice and toasty in my hand than i remember my domed ones did.
At first i thought i had just been stupid and used different charged batteries for the domed & dedomed but i clearly remember double checking, by switching batteries multiple times and using the same battery in both just to be sure, always with the same result.
I am not really sure what to think of this it feels brighter outside now but it is a very different weather out now –15 celsius and much moisture in the air now vs 3+ and very dry air so i can’t really compare before i get my new stock zeusray.
And i charged up a Samsung 20R to 4,19v……….but the Amp reading on my DMM is dead i don’t know what happened but it doesn’t work anymore i guess i shorted it somehow? so no more reading before i get a replacement and i learn how to not destroy my equipment, any pointers guys?
I don’t think it has low voltage protection. I would also choose the Zeus and a protected cell as a gift. It is not a boost driver, so the cell can’t get more discharged than slowly approaching the XM-L’s minimum forward voltage.
I did it without the brown reflector and Chicken Drumstick said his got slightly damaged when he did it without taking of the reflector, and i you do the entire pill, please remember to take of the o ring, mine got damaged by the gas because i didn’t remove it.
I did the dedome on this light easily ! Just let it run on high for 5 minutes with a fresh battery and then use a wood toothpick to lightly lift the dome off all-around the LED !
The throw is rather nice for such a small lens (just a few millimetres larger than SK68) but a C8 size reflector light is much better at everything, expect flood of-course.
You can’t use it on high for very long or it will burn your hand ! Even worst if you use copper DTP star. But for the price and the good build quality (except the cheap anodizing) its an incredible value.
Interesting, i want try something like that on my next dedome.
You said on coppar it is even hotter? i bought some diffrent xp-l & xm-l2 on noctigon from hank that i had planned to try in the zeusray when i get some better driver for it.
Did you take the stock led and put in on a coppar mcpcb?
The LED will be cooler but the flashlight body will be hotter much faster with noctigon.
I did it with the stock LED, its easier to do it with a aluminium star because you want the LED dome to be very hot so it become soft.
You should try XP-G2 1D for dedome, better tint and better throw. There won’t be much change compared to stock with another XM-L2 or XP-L.
