Budget White Bike Headlight ( Cree XML-L2 5 - 7.4V )
coupon code: GBLIGHTCM
Price: $8
hmmm does that work on a USB port on a PC as well?
it shows a USB cable.
Quick teardown of the $8 Cree XML-L2 5 – 7.4V Quick teardown: Cree XML-L2 5 - 7.4V LED White Bike Headlight Flashlight with USB Charger
thanks for the link!
Glad to help ChibiM
I preordered the Neutral White Yinding YD-2XU2 http://www.gearbest.com/led-flashlights/pp_133573.html
It’s $25.14 with Yinding coupon.
My bad, I ordered http://www.gearbest.com/led-flashlights/pp_126086.html and it’s already shipped.
That’s the same Yinding — that page now shows a button to select Neutral, which wasn’t there before.
I’d much rather have gotten the neutral white, if I’d known it was coming available.
EDIT, so I went and read the threads at MTBR and bought a neutral white, too.
Head only, not the battery box, and use “yinding” as the code: http://www.gearbest.com/led-flashlights/pp_133573.html
Dang, now I need more bicycles …
There is also a nice deal on the Solarstorm 2S2P Battery Pack pack which I hope will fit the Yinding.
$9.99 with coupon code: New2S2PCM
It’s in the first post but I almost missed it and ordered from another site
Hank, all I was able to get about the battery pack is the capacity that should be around 4000mAh which is not bad for Chinese ones. It could be good to run Yinding for about 2 hours on full.
Good news for every one, today we bring the new DQG for all of you, it’s D.Q.G Fairy ( 1 x 10180 Battery ), is anyone interested?
coupon code: DQGFairy
Price: $16.99
How about another code for package with charger kit and additional 10180 battery?
The coupon code also works for the package deal (D.Q.G.Fairy, charger, and battery) that GB has. Lets you save a little on both the charger and battery.
Mike
No trits though
darn it, can’t believe I just did that, I’m in for 2 and accessories…
I went for a Fairy too, first purchase in 2015, have been wanting one since it came out (new years resolution was: no new flashlights before the majority of my BLF-projects are finished, well that went down the drain fast :-( )
Price: $16.99
Ordered! I’ve been waiting for this for a while now!
Mike
Yes it work, I just try it, can choose NW too (pick NW first before link to the package).
Thank you Mike.
Man, what a deal! I paid $35.00 for the original, (with trit), but even without the trit, for $16.99 this is still a super bargain.
I just hope it doesn’t take 41 days like my last Gearbest order did.
What is the mAh rating on a 10180? I saw one on alibaba that said 100mAh…that can’t be right…that light would run what 1/10 an hour or 6 minutes at 1A…good grief!
I'm afraid it is, it is less than half the size of a 10440, so roughly less than half the capacity would be between 100 and 150 mAh. This light runs at 300 mA on high, so about 20 minutes runtime.
BTW, I forgot to include the charger (did not know about it :-( ) so I bought a USB charger on Ebay for a few dollars, changing the sense resistor will make it charge at 100mA (lineair as I understand). WH, is it correct to assume that the dedicated Fairy charger uses the same electronics inside?
