Yes I think with the right focus (i.e slightly out of focus, in the cross zone) and a bit of an OP it could look really nice. Of course the real thing is always going to behave differently to a sim (especially with the dome on) but I like having an empirical idea of what the physics are doing.
I actually assumed there would be a much bigger difference in the projected image between pushing the emitter into the reflector vs pulling it out, doesn’t seem to be the case here. Next I’ll add the reflector hole to the sim and see what that actually does to projected image.
I look forward to seeing some real world beamshots with various reflectors and see if the sims are true to life
This is just showing us what we already know to be the case but your mention of the faceted reflector gave an idea to quickly simulate what the hotspot would look like projected through a lightly OP/Faceted reflector.
Both projections are with the emitter at +7.5 units into the reflector (in the dim cross sweet zone), one with a rough approximation of an OP surface and the other SMO.
Looks very promising indeed, especially since the same comparison done with the emitter in focus didn’t do much to eliminate the donut.
Do you have a link to a bigger datasheet showing the proper dimensions of that reflector? I can’t find one through google and that one on cutter needs to be studied under a microscope.
Cool, good to know the results are in line with the real thing.
In obscuring the cross in the beam pattern, the faceted reflectors will likely yield the higher efficiency as compared to OP reflectors.
Although this die will never be a far thrower - regardless of the reflector, Ledil shows 27 compatible reflectors for the XHP70 in their search engine. FCN13895_SEANNA-A looks interesting (Viewing Angle 4.3° simulated) but 153mm x 79mm makes it quite large.
The Mirella is sized right, 50mm with the flange on top, 38mm with the flange cut off. 20mm tall. 17º viewing angle and only $4.11. Yeah, I’ll be trying this one out in a few days.
Edit: Wondering if a couple of Efest Purple 18350’s will get me 4000 lumens + from an Eagle Eye X6?
I gathered the facet observations back in the days that I played with the MC-E and P7 quads.
The FCN13895_SEANNA-A is an expensive reflector, but appears to be a well engineered precision piece and complex to manufacture. As a sealed unit, the base could conceivably be epoxied into a small light with the rest of the reflector hanging way out there. I hope OL didnt read that. Check out some of the data sheets the search engine finds on the XHP70. Many of the Bridgelux cobs that share the same reflectors kick the XHP70 at its own game. I didnt go any further, but they probably operate in the 24 or 36 or 52V range, so not very useful for our hobby.
While Im not getting too excited about the HXP’s, I am looking forward to more offerings from Cree and their competition that can withstand these higher heat ranges along with the claimed high maintenance values at those temps. The real advantages are in their ability to produce high lumens at higher operating temperatures, which equates to smaller/less costly/cheaper heat sinking solutions. For us, it means isolating the cells and driver to keep them cool while allowing the head to run much hotter than we typically allow them to now.
I just wish something cheap and revolutionary would come along to replace LED’s all together… with 4 times the lumens @ 1/4th the power requirements… with nearly no wasted heat. I imagine it will eventually happen, but it probably wont resemble an LED.
As an aside, I wonder what (if any) lumen increases the Olight SR96 might realize if the MK-R’s were swapped out for XHP70’s. I bet those shallow heavy OP reflectors would do well. Who has one to tear apart?? :bigsmile:
At the moment there is just the aluminium MK-R Sinkpad, no copper one but apart from extreme builds, the aluminium one will work just as well. I do not know if it is for sale anywhere.
Perhaps intl-outdoor will come up with a Noctigon for this led at some point (Hank, please? ;-) )
Except the shipping is higher than the cost of the stars. Even if you buy like 50 of them, it's still a very high shipping cost. It's just not possible for anyone outside of AUS.
