And I love that you just went ahead with it. You must have known this would be a "stretch" of your hobby that would not necessarily sit well with the missus.
But here you are, posting a wonderful picture of a nearly lab-grade IS...
You a mad man.
But you have my vote. And my confidence in you finishing this and setting a helluva high bar for us amateurs that mess with measuring light in our free time :-p
I assume you’re building a scale model of the infamously accurate “Integrating bathroom” measuring device. When will you be tiling the walls and installing the miniature bathtub, sink and toilet?
Seriously though, very impressive looking IS. Is the larger size important to it’s accuracy or simply allows you to measure bigger/floodier lights perhaps?
I have no clue about integrating spheres (or rather integrating shipping crates!) so I’m sure I’ll pick up a lot. It actually looks quite attractive to me so stick it in a corner and stack your flashlight collection on top
Information on the interiors of my integrating spheres is strictly classified, although I can reveal here that one key to succes is an inbuild jacuzzi.
I'm not sure if the larger size makes for a much better integrating sphere. I have seen an professional integrating sphere (for lasers) with a 2.5cm inner diameter. A rule of thumb is that the total surface area of entrace and exit holes must not exceed 2% of the inner surface (or else you will loose too much reflectance to get a proper integration). With my entrance hole diameter of 80mm the small size of my first sphere would not suffice. But given the size of our three-room apartment and the need to accomodate a 3-person family life perhaps a 30 or 40 cm sphere would have been a better idea .
Well, the tech that I put into it is mainly pretty low: pine wood, plywood, a 50cm styrofoam sphere for hobby use, some glue, screws and some floor lacquer. And a quality luxmeter of course. What I hope will make it stand out is that I try to characterise its performance in as much detail as can be done in a non-lab environment.
Perhaps the result of it all will be that it appears that using a simple and small styrofoam ball with two holes and a cheap chinese luxmeter gives equally accurate measurements as big impressive balls carefully coated with a sophisticated () bariumsulfate formula and a snobistic top-notch luxmeter. I actually hope that that will be the outcome, it makes life easy for us at BLF .
Hmm, I'd love a garage, it will be especially convenient for the hobby since we do not own a car . But coincidently we were at our financial adviser today, and I can say with certainty that that is not a probable scenario ;-) .
Well, it is if we (city folks) move to Oost-Groningen, which is as rural as it gets in the Netherlands, there's earth quakes ruining houses because of 50 years of natural gas exploitation, and there's no jobs...
I made a (so I called it) conversion-factor-correction-light for the second sphere (cfc-light from now on), as I did for the first sphere (I called it an adjustment light then). It is a constant output light source in a fixed position inside the sphere of which the luxmeter-reading differs when something (like a flashlight) is positioned at the the entrance hole, because objects in that position alter the overall internal reflectivity of the sphere. This way you can correct the readings for different objects at the entrance hole (every flashlight has a different influence on the reflectivity). This sounds theoretical but different flashlights can make a difference of many percents in the reading, and with your sphere's integrating properties getting better, this variance gets worse. Or the other way around: if your sphere/box/pipe does not suffer from this you can question the integrating qualities. Unless your sphere/box is way bigger than the entrance hole, because that reduces this variance. But I already found that although I hoped not to need a cfc-light in this bigger 46cm sphere with 80mm entrance hole, the variance can still be several percents of the reading of the sphere, so I made one after all.
While in the first sphere this correction light had to be very tiny and narrow to hang at the side of the top entrance hole together with the to-be-measured light, in this new sphere I have the luxury of an extra entrance hole at the side for it. I already measured that the reading of a constant output flashlight when measured through the top port is within 1% of the reading of the same flashlight from the side port :-) .
The cfc-light that I made is very ugly and has burnt and molten bits from the soldering torch (I even burnt the led dome, so I had to slice most of it off), but everything works, so that's fine by me. It runs on 1 14500 battery, and a nanjg 101-AK-A1 driver with all 7135 chips but one removed (so constant 350mA). The XM-L2 led is on a 10mm Sinkpad directly soldered onto the copper pillar that in turn is soldered to the copper body of the light. The pillar of the light is slid into a hole through the insert that I made for the side-port of the integrating sphere, the body hangs outside the sphere. So although the led is very low-driven, it is very well cooled. Some pictures:
So does it pay off making it? How does it perform as a constant light source? Here are some readings when it is in place inside the sphere. I started with a fully charged Efest IMR 14500 750mAh, let the light run for half an hour, taking readings underway (the body gets very slightly warm within half an hour). Then I let it cool for 10 minutes (to see warming-up effects) and let it run for another half hour (actually 50 minutes). Then I took the battery out and charged it again. Two hours later I did another run for half an hour, to see how reproducable the results are (they are :-) ). As you can see the light is not perfect constant output under warming-up and battery-drain effects, but stays within 97.5% of initial output for an hour, and if I'm extra keen on accuracy for a reason, I can use the light between 10 and 30 minutes, the difference is just 1% then. But for its typical use I will take readings just seconds apart so it will do its job fine in any case. A partly drained battery is even better than fully charged.
Eehhmm... in case of this sphere project, perhaps I do it for some folks here, but it is more a challenge for myself than anything else. I do not think that the BLF-community benefits much from it except by making people uncertain now, who were thusfar quite happy about their light measurements .
I have a proposition for you, when you are satisfied that you have it working to it’s optimum performance let me know. I will send you a light that I have built and tested in my pvc lightbox. Then we can see how my box, and duplicates of mine used by Richard and Tom as well as manxbuggy1 and rdrfronty, stacks up by comparison.
You will be free to keep the light I send you for your efforts.
Then we will all know how to adjust our conversion factors if/as needed.
Or, as you say, we’ll be more confused than ever before.
Oh, let me add my keen observations from this point….You Are F’N Brilliant! That cfc light is impressive too. Amazing.
DBC. I'm going to build a light box sometime in the future and need you to send me a real hot rod light. When I've finished testing I promise I will send it back to you. You can trust me. No seriously you can, just dont ask my wife.
Tracking says it was delivered on…lets see…yeah right here, Dec 3rd. That one is awesome, I clocked it at 4487.34 at start on Efest 35A’s. That particular UI was kind of experimental, hope you like it (or hope your wife likes it, apparently)
I'm honoured to have made it into your sig-line, Ledsmoke
And Dale, let's make it a swap, you send me a light you measured and I will send you a light that I measured. But I still need to do the coating so let's wait until that is done. But while I try to do everything to characterise this sphere and reduce any possible secondary measuring errors, there's one thing that you and others have done more thoroughly than I have done: the primary calibration of the sphere! Many use a multitude of ANSI-F1 measured flashlights for calibration and take a mean of that, I just define the 'high' output of my SWM D40A (rated 550 lumen) as the holy truth (I do that for very practical reasons btw), if my copy of this light is off, the djozz-lumen is off. As DrJones suggested, in the end I need a NIST-calibrated lightsource to finish the characterisation (or have my D40A measured officially), but that is way too expensive.
There's three answers to the question how much it is worth:
1) materials+wages. It is a hobby so wages are not there, I enjoy the work that is in it. The materials: I guess about 150 euro, this is including 5 new-build test flashlights with constant output. If I ever have a lightsource officially calibrated for it, another 325 euro's is added. (for the luxmeter alone I payed 425 euro's second-hand, new and freshly calibrated this one goes for 1500 euro's. But I had the luxmeter already and use it for other measurements as well, so it was not purchased exclusively for this sphere).
2) the functionality. If this sphere performs close to the performance of a professional sphere, it could be worth over 1000 dollars. A professional sphere goes for many thousands of dollars (think 30), but it comes certified, which will never happen to my DIY-thingy, and it has all kinds of convenient computer-outputs and software.
3) relevance to what we do here at BLF. Well, probably it is worth close to any white-painted cardboard box with a cheap chinese luxmeter (so say: 20 dollars), meaning: if you get within 10 to 15% of the real lumen-value which is what such a box probably achieves if you build and calibrate it carefully (and more accurate if you measure only cool white flashlights with similar beam profiles), the difference is not noticable by eye and therefore good enough. My goal of getting within 1% for all beam profiles (from mule to thrower) and colour temperatures is purely for my own enjoyment (and I must admit that I do enjoy posting about it as well ;-) )
