Sweet deal — thanks!
Order made. Thanks!
THANKS OL.
Thanks and Happy New year OL!!
Nice…even using 18650’s w/ the sleeve, these are some rather nice lights…quite beefy and plenty of meat in the body to absorb heat if modified into a barn burner…at 3A these things barely even heat up.
Thanks OL!!!
Thanks for the heads up, couldn’t resist at that price!
Anyone know if the battery tube or tailcap could screw onto a HD2010?
Nice one OL. I think it’s a good purchase for the price (as a 26650 host) based on the last go-round. Remember folks, these can happily take a 26700 like the 70mm KK cells!
Unfortunately I think not. The threaded section on both tailcap and battery tube have smaller diameters than those on a Yezl Y3 extension I just checked against (because JaredM
- FOUND! HD2010 extension tubes). The tailcap won’t even start to thread. The body tube just spins inside the female threads of the Y3.
Thanks for checking that, too bad.
I was hoping to one of those exact extension tubes to build a nice 2x 26650 mt-g2 beasty out of this thing. I do have another 26650 extension tube here that might do the trick, one of those sold by cnqualitygoods back in the day that was a bit too narrow at the threads to fit the HD2010. Chances of it fitting are slim but who knows.
Thanks for posting. I ordered one.
Can this run on 3xAA also? If so, how? Would I need a case like this:
http://www.gearbest.com/diy-parts-and-tools/pp_89760.html
If it possible, I will buy that flashlight, so please if anybody know it tell us :bigsmile:
(I have to make a gift to ordinary people, so I prefer not to buy Li-on cells, just Nimh)
Thanx OL!!
Terrible UI, but with a different driver…
I like 26650-flashlights -> handy & long runtime! This one has a glass lens and an aluminium reflector, perfect.
I wish you a healthy happy new year! 8)
Nice deal, sorely tempted but are 22mm drivers readily available? Had a quick look and couldn’t seem to find any.
I got an F13 from GB in May,still XM-L then.$9.99 and it came with lanyard,18650 spacer and triple AAA battery carrier.See photo 3 in the customer photos.3 AA cells will not fit in any 26650 battery tube AFAIK so that is about 700-1000 mAh :~
I ordered one of these as well.
If this doesn’t fit that AA battery holder, does anybody know of a light that will fit it?
XinTD/Convoy X3
Use a contact board and attach a Nanjg 105C driver on the contact board is one of the solutions.
Or resistor-mod the driver?
EDIT: As for the stock driver, simply move the positive wire to the OUT1+ pad, as shown in here to achieve DD.
Find this spec, just 18650,22650 and 3xAAA.
Newest!! UltraFire F13 1200 Lumens
Item Type:
Flashlights
Lumen:
450
Charger:
Rechargeable
Brand Name:
OEM
Body Material:
Stainless Steel
Light Source:
LED Bulbs
Zoom:
Yes
Battery Type:
AAA,18650,22650
Certification:
CCC,CE,RoHS
Waterproof:
Yes
Color:
Black
Lighting Distance:
50-100 m
Switch Mode:
High/Middle/Low
Support Dimmer:
5-8 files
Function:
Shock Resistant
Body Color:
Black
Focal Length:
Adjustable
Flashlight Type:
Camp
Model Number:
E-237
Model of LED Beads:
U2
Nope.
There are at least two 22mm designs freely available on BLF for you to assemble yourself:
- WarHawk-AVG expanded Mattaus’s BLF20DD to 22mm here: WarHawk-AVG - BLF 22DD discussion thread
- I produced a 16*7135 driver in 22mm specifically intended for this light over. Sorry that the thread is badly organized, but it’s only 3 pages: 22mm 16x 7135 driver for F13 flashlights - [released]
Your other option is to use a smaller 17mm or 20mm driver. You can either use a contact PCB (like these 21mm ones from IOS?) as bibihang suggested or you can just strip the stock driver and use that in lieu of a contact board. IIRC there is enough space for any 17mm driver you want.
