Ultrafire F13 at $11.39 - with Coupon Code - Gearbest
Thanks for the heads up, couldn’t resist at that price!
Anyone know if the battery tube or tailcap could screw onto a HD2010?
Nice one OL. I think it’s a good purchase for the price (as a 26650 host) based on the last go-round. Remember folks, these can happily take a 26700 like the 70mm KK cells!
Unfortunately I think not. The threaded section on both tailcap and battery tube have smaller diameters than those on a Yezl Y3 extension I just checked against (because JaredM
Thanks for checking that, too bad.
I was hoping to one of those exact extension tubes to build a nice 2x 26650 mt-g2 beasty out of this thing. I do have another 26650 extension tube here that might do the trick, one of those sold by cnqualitygoods back in the day that was a bit too narrow at the threads to fit the HD2010. Chances of it fitting are slim but who knows.
Thanks for posting. I ordered one. :slight_smile:
Can this run on 3xAA also? If so, how? Would I need a case like this:
http://www.gearbest.com/diy-parts-and-tools/pp_89760.html
If it possible, I will buy that flashlight, so please if anybody know it tell us :bigsmile:
(I have to make a gift to ordinary people, so I prefer not to buy Li-on cells, just Nimh)
Thanx OL!!
Terrible UI, but with a different driver…
I like 26650-flashlights -> handy & long runtime! This one has a glass lens and an aluminium reflector, perfect.
I wish you a healthy happy new year! 8)
Nice deal, sorely tempted but are 22mm drivers readily available? Had a quick look and couldn’t seem to find any.
I got an F13 from GB in May,still XM-L then.$9.99 and it came with lanyard,18650 spacer and triple AAA battery carrier.See photo 3 in the customer photos.3 AA cells will not fit in any 26650 battery tube AFAIK so that is about 700-1000 mAh :~
I ordered one of these as well.
If this doesn’t fit that AA battery holder, does anybody know of a light that will fit it?
XinTD/Convoy X3
Use a contact board and attach a Nanjg 105C driver on the contact board is one of the solutions.
Or resistor-mod the driver?
EDIT: As for the stock driver, simply move the positive wire to the OUT1+ pad, as shown in here to achieve DD.
Find this spec, just 18650,22650 and 3xAAA.
Newest!! UltraFire F13 1200 Lumens
Item Type:
Flashlights
Lumen:
450
Charger:
Rechargeable
Brand Name:
OEM
Body Material:
Stainless Steel
Light Source:
LED Bulbs
Zoom:
Yes
Battery Type:
AAA,18650,22650
Certification:
CCC,CE,RoHS
Waterproof:
Yes
Color:
Black
Lighting Distance:
50-100 m
Switch Mode:
High/Middle/Low
Support Dimmer:
5-8 files
Function:
Shock Resistant
Body Color:
Black
Focal Length:
Adjustable
Flashlight Type:
Camp
Model Number:
E-237
Model of LED Beads:
U2
Nope.
There are at least two 22mm designs freely available on BLF for you to assemble yourself:
Your other option is to use a smaller 17mm or 20mm driver. You can either use a contact PCB (like these 21mm ones from IOS?) as bibihang suggested or you can just strip the stock driver and use that in lieu of a contact board. IIRC there is enough space for any 17mm driver you want.
I was really hoping for a more budget option, to give as gifts
One that I know is the SH-3AA (Aurora/Ultrafire)
you must remove the spring
Some links for more info on the stock driver or mods.
https://budgetlightforum.com/t/-/26433
https://budgetlightforum.com/t/-/23188
https://budgetlightforum.com/t/-/19164
and the tear down video
Thanks for all the great information guys.
I had wondered what those contact boards were used for. My soldering skills are not up to making my own driver, but that contact board idea looks doable. Thanks.
I think I’m about to acquire my first 26650 light. :slight_smile:
I just tried to move the positive wire to the OUT1+ pad and I got 3.0A measured at tail. All the wires were also replaced with 22awg one.
Still doesn’t give any ‘rocking’ performance, but surprisingly the PWM pattern of this stock driver can hardly be noticed so I will just stick to it.
