Thanks! I’m pretty happy with the functionality, just not the aesthetics. I hoped to at least have enough space to line up the 7135/MCU/MOSFET down the center, but no such luck. Beggers can’t be choosers though, I’m thrilled it all fit w/ my normal goals and on one side.
Thanks djozz. I’d like to do a boost driver, but low-voltage boost is off my list until I get a buck driver working. :~
I don’t have any 14500s or 10440s, all my stuff is 18650 and larger or runs on a conventional AA.
Is there something holding you back about this driver in particular? It should be a very simple reflow. (The only thing to watch out for of course is putting a little too much solder paste on the gate/source pins. No big deal though…)
It is very easy to disassemble, and it has a hollow pill. There's a great dislike for hollow pills on BLF, but I use my leds on copper boards, and for small lights (and most 18650 lights for that matter) the (thick and copper, if Noctigon or Sinkpad) ledboard itself is way sufficient for the heat transfer to the pill. And I just use the plastic press-fit disc to fix the ledboard, alternatively you can use an adhesive like Arctic Alumina Adhesive.
No, the reflowing itself is not what holds me back, I think i can get it done quite nicely, it is the yet again new (mostly magic to me) components that I need to find in small quantities with affordable shipping to the EU, and my unability to flash my own firmware (I am not much into electronics and in computers, even do not have a proper Windows one).
I think there's many folks out there that would love to use all those great drivers, but despite of not being afraid of some DIY soldering, lack one or two skills to make a functional driver starting with a bare Oshpark board.
Oh hell yes. This is going directly into my titanium D25A. And hopefully also into the brass AA lights from CNQG, if it’ll fit. I think I have hosts for about half a dozen of them.
The D25A will probably get special firmware, since it has a sensor for fully-tightened vs slightly loose. Not sure what to do with that yet though.
Thanks djozz, i have seen your measurements all over this place so i have to be honest, when you say it is possible enough with the hollow pill it gets me curious, because you are right about the great dislike about this here, and me as new at this have almost adopted this as a truth, without any real personal experience backing it up.
So i wonder have you used any thing in that size with a fet driver and didn’t feel it lost a lot of output fast by bad heatsinking? i
thought a solid pill/shelf where almost a requirement to not have it sink like a stone in lumens output.
A DTP MCPCB is a requirement for that, and so is a decent path from there to wherever all this heat is going. Beyond that, more contact the better of course… ideally the whole chain has very few thermal interfaces and the interfaces are all good.
Interesting this means i have disqualified some possible nice host wrongly then, i will keep this in mind for future builds, thanks wight and djozz for setting me straight.
Way to step up, wight. When I get a chance I need to update the Oshpark projects thread with all this new stuff. Won’t be anytime soon though.
I think it might be a good idea to mention that one reason for bypassing the diode to the voltage ladder is to allow Zener mods that still have lvp with just a change of R1.
I figured you’d like this one; I know your mind’s been on 15mm drivers for a bit now.
Thanks RBD. It’ll be nice to have this stuff in the OSH Park projects thread, but I suspect that it’s also time for me to put a thread together just to organize my drivers, outside of my signature. RE: the bypassed diode thing - good point. That description started off a little lacking and I’ve copied it between my driver threads without improving it.
BTW, I think I’ve asked you before, but where do you like to order Khatod optics? Cutter? Or maybe a source in the US?
I haven’t picked one out (and I will not be doing so immediately).
Please use these instructions to help find one. See what you come up with by focusing on these things, mostly in this order:
I’d stick to 20-30v rated stuff
high current rating
a fairly low gate threshold voltage since it will be powered by no more than whatever the MCU gets as input. Take a look at the graphs in the datasheet for PSMN3R0-30YLD which show Rds(on) vs either Vgs and Rds(on) vs Id. Remember that our Vgs will be lower than battery voltage… it’s battery voltage minus the voltage drop in the diode and in the MCU. I usually eyeball the performance around Vgs = 3.3v.
gate charge – don’t let it be too high. Look at the other selections we’ve been discussing, but I think you should be fine with <50nC or <100nC or something.
Cutter Electronics has them but both price and shipping are high.
Both are taller than Carclo quad optics and don’t fit the same peg radius as Carclo 25mm quad even though the led locations are the same. On some mcpcb’s all that’s needed is to open the peg holes to the edge of the board.
Thanks, that’s what I was afraid of (the cost in dollars, not the peg layout).
How about:
PSMN4R2-30MLD
or SiS414DN
I’d call SiS414DN the clear winner for this application except for the fact that it’s in a flat-no-leads package. I expect that it will be very difficult to solder for most people. (Actually reflow only for most people I think…). It’s also “Package Limited” to 20A, but I don’t think that’s very relevant here. PSMN4R2-30MLD has more exposed leads and should be a bit easier to hand solder.
EDIT: Clearly I made a mistake. PSMN4R2-30MLD is not that great.
EDIT 2: Clearly I can’t read a datasheet. SiS414DN isn’t that great. I made an error with units (ohms vs milliohms).
I have not evaluated the following FETs beyond Rds(on). Listed in order of Rds(on) performance at our voltage levels:
PSMN2R4-30MLD
PSMN2R8-25MLC
PSMN3R0-30MLC
PSMN3R9-25MLC
Possibly functional, but not characterized well by the datasheet (for our purposes):
PSMN1R5-30YL
PSMN1R5-25YL
Not considered due to high Vgs threshold:
PSMN4R0-40YS
PSMN3R3-40YS
PSMN2R6-40YS
Ok I just added some PSMN2R4-30MLD to my order. hopefully they end up working for our purposes. Just to confirm, other than the FET and the 22k resistor, everything else is stock from a 105c, correct?
I was wondering when/if anyone would incorporate the smaller LFPAK size but resisted suggesting it because of the tight pin spacing(I barely get by on attiny’s and 7135’s). Curious to see how much better it might be than the 2502 or it’s successor(you listening Dale?).
